De optiske pickupene fra DS Audio er i prinsipp analog pickuper, som bruker lys isteden for magnetisme til å generere lyd.
Pickupene fra DS Audio kjennetegnes ved en svært god bassgjengivelse, sort bakgrunn og stor oppløsning.
Den nye E3 med tilhørende phonoforsterker byr på god ytelse og en formidabelt lydgjengivelse! Den fikk også mye positiv oppmerksomhet under årets High-end messe i München.
E3 har nå flere av de samme teknologiene som du finner i DS Audio sine mer kostbare modeller, men i en noe forenklet utgave.
Vi venter å ha DS E3 klar for demonstrasjon om kort tid!
Ta gjerne kontakt med oss hvis du lurer på noe rundt pickupene fra DS Audio!
Telefon: +47 40 40 68 13
Epost: post@malaaudio.no
DS E3 med tilhørende phonoforsterker:
39.995,-
Uses a third-generation optical cartridge mechanism
The DS-E3 uses a third-generation optical cartridge mechanism, the same design as our other products.
The DS-E3 achieves an overwhelmingly low price while inheriting the merits of the third-generation mechanism, such as higher output due to independent LED and PD, improved channel separation, and the use of a beryllium light shielding plate.
Aluminum cantilever with elliptical needle
The cantilever is made of aluminum and the needle tip is a solid elliptical needle. While adopting the third-generation optical cartridge mechanism, the channel separation is set 1db lower to improve mass production efficiency.
Equalizer
New Amplification and Power Supply Circuits
In the DS-E3 equalizer, the amplification circuit has been made symmetrical, and the voltage supplied to the cartridge has been stabilized to achieve a clearer and faster sound.
Miniaturization is achieved by using an operational amplifier
The DS-E3 equalizer uses an operational amplifier as the amplifying element to minimize the signal path, thereby greatly reducing the number of components and achieving a smaller size. As a result, the DS-E3 equalizer is about 1/3 the size of the DS003 equalizer.
