DSD - What is this?........ Nogler der kender til dette?
Balle Clorin
DSD er ofte 6dB lavere i volum enn pcm.
Dette avhenger litt av hvilken dac (chip) som benyttes bl.a.
6 dB difference is completely normal. This is becauase DSD 0 dB level is defined to be 50% of the theoretical maximum. And the specification allow temporary peaks up to max +3.15 dB DSD level. While PCM has hard ceiling at 0 dBFS.
Some DAC chips like ESS Sabre attempt to normalize the output volume by applying 6 dB gain on DSD. Then PCM and DSD have same 0 dB reference level. But that has a risk when some material actually exceeds 0 dB DSD level and goes to +3 dB or so. Then it may hit maximum voltage span of the analog section (for example if it's running from 5V supply)...
TI chips have varying DSD output level depending on selected DSD analog filter. But typically have about -3 dB level compared to PCM 0 dBFS level. AKM chips Direct DSD output level is -3.5 dB compared to 0 dBFS PCM so they have enough headroom to accommodate the allowed DSD peaks.
Because of uncertainty of behavior above 0 dB DSD level, for example HQPlayer is trying to enforce output to stay within 0 dB and don't allow output to exceed the +3.15 dB level.
OlaR
Inspirert av denne tråden har jeg lastet ned sampleren deres.
L
Lassencad
Tak for jeres svar For mange år siden hørte jeg første skæring på denne Lp
Lige siden har jeg søgt den. Men er en smule nærig.så en på .en på Ebay til 3000kr+ . Fik den så i Lørdag til 39 Euro
Lyden er usædvanlig voldsom trommer er meget troværdigt optaget ...synes jeg .
Men jeg overvejer deres andre tjenester :)
