Roysen skrev:
Hva med dp A2? Noen som vet hva den koster og hvordan den spiller i forhold til A1S? Jeg ser også at dp jobber med en A5. Noen som vet noe om den?
Roysen
En liten sak til den nette sum av veil. 220000,-
OUTPUT POWER, RMS, 20Hz-20kHz,
@ 1% THD (clipping level) :
8 ? load, 400W per channel
4 ? load, 800W per channel
2 ? load, 1500W per channel
8 ? load, 1500W bridged mono
Maximum output current:
More than 100A per channel (200A peak)
DISTORTION, THD @ 400W
20Hz-20kHz in 4 ? load:
Less than 0.0005%
DISTORTION, THD @ 35V RMS, 1 kHz:
Less than 0.0001%
IM DISTORTION, CCIR 13 kHz and
14 kHz, 8 ? load:
Less than 0.0002%
FREQUENCY RESPONSE(filter bypassed):
DC - 500kHz -3dB
SLEW RATE(filter bypassed):
Greater than 250V/us
DAMPING FACTOR:
1000 @ DC - 20kHz/8?
SIGNAL/NOISE RATIO, Ref. 400W/8? load:
10Hz-80 kHz 107dB
22Hz-22kHz 114dB
10Hz-CCIR-QPK 103dB
IEC-A weighted 116dB
INPUT IMPEDANCE:
200 k?
GAIN Pos 1:
26dB (20x)
GAIN Pos 2: (standard setting)
30dB (31,6x)
GAIN Pos 3:
33dB (44,7x)
SENSITIVITY Pos 2:
1,42 V RMS for 250W/8?
CHANNEL SEPARATION:
More than 120dB@ DC -100kHz
COMMON MODE REJECTION RATIO:
Better than 100dB@ DC -100kHz
DIMENSION (W x H x D in mm)
445 x 364 x 380
WEIGHT (kg)
65
