EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997.
Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av esken. Armene virker mere solide, og den gamle antiskatingen er erstattet med en magnetisk funksjon i stedet for det gamle hengende loddet.
For de som har mulighet til å ta turen til Jørgen hos HiFi&Vinyl - så er 912HI og 912 for tondose utstilt der.
912HI er testet i Stereophile og Herb Reichert uttaler:
In my system, the EMT 912-HI arm and JSD 6 cartridge made every music genre seem like my latest favorite discovery, and that's exactly the trait I'm looking for when auditioning source components. During the course of these auditions, I played more records in six weeks than I'd played during the previous six months. I did that because I kept wanting more. That's my highest praise.
Les hele omtalen her:
EMT 912-HI - 92.160,-
Product Flyer | Datasheet | Manual
Within the new EMT tonearm technology, we were able to combine most modern bearing- and manufacturing-technology with the traditional EMT design. Thus, the sound properties are im-proved significantly, while at the same time the long history of this product-line is respected.
- High-end 12-inch tonearm with headshell for 1/2” hi-fi cartridge connection
- Precision bearing technology, advanced tension compensating mechanism
- Fine-pitch thread ring for VTA adjustment
- Contactless magnetic skating compensation device
- Counterweight with integrated scale for VTF
- Rigid headshell with azimuth correction mechanism
![EMT-912-HI.jpg](/forumet/data/attachments/933/933903-229c5da615a6e029c4d52da2e68f8f7a.jpg)
![EMT-909-Side.jpg](/forumet/data/attachments/933/933902-b069c86af61bd19f6c218db32fcc3f34.jpg)
![EMT-909-Rear.jpg](/forumet/data/attachments/933/933901-0d17488d5306df0adf819d5f122452b3.jpg)
Effective mass: | 11.4g |
Cartridge weight: | 8…25g |
Effective length: | 310.15mm |
Offset angle: | 17.55° |
Overhang: | 13.15mm |
Null points: | 120.9 / 66.04mm |
Output (Standard): | wire outlet 20cm |
Output (Option DIN): | 5-pin DIN outlet |
