F-02 er en av de største integrerte forsterkerne fra Esoteric!
Med sine nesten 40kg og egen PSU til forforsterkeren er dette en skikkelig high-end integrert forsterker.
Nå klar for demonstrasjon i Asker.
![malaaudio.no](https://webimg.blob.core.windows.net/analogsenteret/prodimages/cardthumb/111114447.webp)
The "finest" integrated amplifier
incorporating Grandioso “X” Edition amp technologies.
[Preamplifier Section]
- A fully balanced dual mono preamp in the direct line of the Grandioso C1X
- "Ultra Fidelity Attenuator System", a stepped attenuator circuit developed by Esoteric
- Volume can be adjusted in 0.1dB/1,120* steps with our proprietary attenuator module "UFA-1792" *Preamp gain setting: at +12dB
- 3 inputs of “ES-Link Analog”, a unique and proprietary current transmission system
- Two headphone outputs (balanced 4-pin XLR / unbalanced 6.3mm) with built-in fully balanced dual mono headphone amplifier
- Dual mono phonostage preamp (RCA x 1, MM/MC)
- 3-band balanced tone control, independently adjustable for each input source
- ES-Link Analog(x1) /XLR (x1) pre-out for connecting the S-05 as an external power amplifier
- Dedicated DC power connector for connecting the PS-01F external power supply dedicated to the built-in preamp
- Preamp gain can be adjusted in 4 steps (0/+6/+12/+18dB) to match the connected power amplifier
- Simple and straightforward circuit design concept based on Grandioso M1X
- 120 WPC/8Ω
- Excellent power linearity and driving power (240 WPC/4Ω)
- All stages of the power rectification and smoothing circuit are configured with dual monaural design
- Powerful bipolar transistor 3-parallel push-pull configuration
- Huge 940VA EI core power transformer
- Channel-independent Grandioso grade custom block capacitors (10,000μF x 4/ch)
- Custom wave-shaped heat sinks to reduce peak resonance
- Independently adjustable input gains (±18dB; 0.1dB steps)
- L/R channel balance (0.1dB steps)
- AV through output (volume bypass) ensures seamless coexistence with AV systems
- Aluminum body remote controller (RC-1339) can also be used to operate Esoteric's SACD players and network players
- Displayed source device names can be programed
- Mute, dimmer and automatic display-off functions
- Control functions (RS-232C, trigger input / output)
214.3 KB Visninger: 33
48.3 KB Visninger: 31
438.5 KB Visninger: 51
438.5 KB Visninger: 26
