Finnes det noen "tweaks" som er så "over the top" at ingen går på de?
  • E.I.A.
    "The QKORE is a parallel grounding device, which provides an artificial, “clean” earth for hifi audio systems using both an electrical and mechanical approach. This unique product combines Nordost’s patented Mono-Filament technology with purpose-built, Low-Voltage Attractor Plates (LVAPs), constructed with a proprietary metal alloy and a passive electronic circuit, in order to draw stray high frequency noise and voltage-generated magnetic fields to a manufactured earth point, leaving a clean reference behind. This passive system is contained in a mechanically tuned housing, and outfitted with gold-plated, WBT binding posts, which easily connect each component to an artificial ground. By providing for a balanced and very “clean” ground point, by-products of electrical balance imperfections between voltage and ground are no longer added to other pollutants, dramatically increasing high quality audio circuit performances."
    H J E L P !!!!!
    Sikkert noen som går på den svadaen ;)
    Husker det var en boks fra samme firma, Thor troe jeg den het, en strøm rense sak.
    Iflg krets diagrammer på nettet konkludertes det med at + og - gikk rett igjennom, skal se om jeg finner tråden.
    Edit: https://hifiwigwam.com/forum/topic/98687-nordost-thor-flashing-led/
    Litt ned på siden.....
    http://www.audiocircle.com/index.php?topic=73275.660
    Oj. En kinesisk switchmode strømforsyning i parallell med kontaktene som "strømrensing". I min verden vil den snarere tilføre støy enn fjerne den. Microcontrolleren er en slik: https://www.digikey.com/product-detail/en/microchip-technology/PIC16F54-I-P/PIC16F54-I-P-ND/613198 Koster 57 cent pr stk, 53 cent hvis man kjøper 100 stk. Strømforsyningen er denne: https://www.phihong.com/admin/uploads/PSA-05A-retired.pdf Den er utgått, men jeg tipper at den i sin tid kostet under $10. Den nyeste versjonen (med USB-utgang) koster $6,06 hos Digi-key. https://www.digikey.com/product-detail/en/phihong-usa/PSA05A-050QL6-H/993-1327-ND/5418479
    Overasker meg ikke at det kommer endel på grensen produkter fra den produsenten. Han hadde samarbeid med Paul Pang tidligere. Ikke mindre snakeoils der.
    svart-hvitt
    H J E L P !!!!!
    Nordost Qkore Grounding System - Print Version
    E.H.
    After the Qkore system was fully installed and I had done some listening, I used a line from Star Trek to sum it up, calling it "The final frontier." But Jon Baker of Nordost one-upped me, likening the Qkore units to the devices used for trapping paranormal goblins in Ghostbusters. Both fit (because they are both fiction)
    Jeg fikset litt på sitatet, slik at det passer bedre med min virkelighet.
    Som vanlig er det veldig lite troverdighet hos "testerene"...
    Et utdrag av de som reklamerer i audiobeat.
    Gjengs er at det veldig ofte er tvilsomme kabel og tweaks produsenter som legger mye midler igjen hos "testsidene. Sågar enkelte steder betales det for å få testet produktene sine.
    Forøvrig utstyrslisten til personen som tester.
    Analog: TW-Acustic Raven AC turntables; Graham B-44 Phantom Series II Supreme and Tri-Planar Ultimate U12 tonearms; Denon DL-103R and Dynavector XV-1s (stereo and mono) cartridges; Nordost Odin 2 and Valhalla 2 phono cables; Lamm Industries LP2.1 phono stages.
    Digital: Ayre Acoustics DX-5 DSD "A/V Engine"; CEC TL1 CD transport; Timbre Technology TT-1 digital-to-analog converter; Genesis Digital Lens; Toshiba Satellite laptop.
    Preamplifiers: Audio Research Reference 6, Convergent Audio Technology SL1 Legend, VTL TL-7.5 Series III Reference.
    Amplifiers: Kenwood L-07M and Lamm M1.2 Reference monoblocks.
    Loudspeakers: Wilson Audio Alexx.
    Interconnects: Nordost Odin 2.
    Speaker cables: Nordost Odin 2.
    Digital cables: AudioQuest Diamond USB cable; Nordost Valhalla 2 S/PDIF, AES/EBU and USB cables.
    Ethernet cable: Nordost Heimdall 2.
    Power conditioners: Essential Sound Products The Essence Reference, Quantum QB4 and QB8 Mk II, Quantum Qx4, Shunyata Research Denali 6000/T and 2000/T.
    Power cords: Essential Sound Products The Essence Reference and MusicCord-Pro ES, Nordost Odin 2 and Valhalla 2, Shunyata Research Zi-Tron Cobra.
    Equipment rack and platforms: Silent Running Audio Craz3 8 equipment rack and Virginia Class Reference platforms (under Lamm M1.2 amps), Harmonic Resolution Systems M3 isolation bases.
    Ikke så rent lite av utstyret hans som står på reklame listen.. Så kan man spekulere hvor kjøpt og betalt man faktisk er..
    J
    Jim I Hendriksen 2nd Edt.
    Hvis man kjøper noe som ikke svarer til hva som ble lovet i reklamen eller ikke tilfredstiller forventningene så er det best og møte opp personlig og avlegge klage. Viktig å ikke gi seg selv om selgeren ler av deg.
    ymir
    Du får tappe oljen over på små lekre flakonger og selge dem dyrt:)
    Håper ingen her inne har betalt for produkter fra akiko audio
    https://www.akikoaudio.com/en/akiko-audio/diy-products
    Nå med henvisning til coreelli effekten. Bransjen er på vei over stupet.
    FY FAEN, den der er GROV! Gud hjelpe oss, vi er over kanten allerede og på god fart ned i fortapelsen.
    Men nå har jeg ikke tid til å skrive mer, skal hente et 190 l. fat med Snake Oil som jeg har fått billig! :D
    Og her er målemafiaen verre enn snake oil bransjen,det støvsuges etter noen å henge ut,
    og da mister noen fullstendig hode og blir totalt blinde
    Finner ingen henvisning til "coreelli effekten" i linken,men at det henvises til at produktserien
    har fått navn etter komponisten CORELLI og ikke coreelli,på same vis som f.eks Marten Miles etc.
    Det henvises også til støy som dette skal ta seg av i frekvensområdet til bl a. wifi,4G ,bluetooth
    og erfaring med når bl.a wifi blir skrudd av.
    Har selv lignende erfaring når vi blir helt uten kommunikasjon,FM radio,4G mobilnett,
    radiobasert internett,planlagt eller utfall pga uforutsett strømbrudd fra timer til dager.
    Det er da bærebølgen og ikke området MHz som kan gi oss problemer.
    http://www.hifisentralen.no/forumet...-sta-y-fra-nye-stra-mma-lere.html#post2540882
    Teknikken Akiko audio bruker for stå for deres regning (piezzo krystaler?)
    I så fall ikke noe annet enn et HF filter..
    Men hvordan de måler og hvilke instrumenter de bruker skulle vært artig å vite
    Fra en tungvekter mht HF støy
    http://ltu.diva-portal.org/smash/get/diva2:990228/FULLTEXT01.pdf
    The resonance phenomena, one of the main areas of concern for LF
    harmonics, are also a concern of HF harmonics but obviously at
    higher frequencies where experience and suitable measurement
    equipment was missing.
    but most importantly the fact that this subject requires
    input from different engineering disciplines: electronics
    electromagnetic compatibility (EMC); and power engineering. The
    last few years have however seen a fast growth in interest in the area,
    with several companies and universities contacting our group.
    The absence of proper measurement techniques could be an
    important reason behind this lack of knowledge
    , but also an absence
    of comprehensive research.
    http://www.hifisentralen.no/forumet/mitt-anlegg-og-billedtra-der/72643-ymirs-audiofile-liv-31.html
    L
    larkus!
    Her er en uhyre tvilsom sak
    Bybee Room Neutralizer. Skal få veggene til å "forsvinne" i lytterommet.
    Sitat:
    "The effect the neutralizers have on the listening environment is immediate, though the full effect will develop and become more uniform over about three days. The system will achieve full musicality only after that period of time. "
    https://www.tweekgeek.com/bybee-room-neutralizers/
    Synes det er søtt når folk roper ut om den fæle målemafian og gjør ikke noe annet enn å henvise til referanser til målinger og enda værre målemafia selv :)
    Vanskelig å skille mellom målemafia og sunn fornuft her inne.
    Å herregud
    The system is a set of 8 Neutralizers, 2” wide by 6” long, with a 6” antenna tail. They hang on your walls and help them accomplish a disappearing act by use of a proprietary blend of materials that resonate with the air molecules in the room, enabling the transmission of sound without the usual time misalignment of high frequencies. They work well with other room treatments such as the Steinmusic Harmonizers, Shakti Hallographs and Stillpoints Apertures.
    Sitat:
    Kun ca 20000kr.
    L
    larkus!
    Enda en:
    Mye hysterisk morsom lesning på denne siden
    https://www.tweekgeek.com/steinmusic-e-pad-s-1/
    Smaå klistrelapper som skal plasseres på strategiske steder. Prisen er $99,95 pr. stk.
    Sitat:
    "E-Pads operate at the level of molecular interaction producing profound and measurable changes to both the mechanical and electrical properties of materials. These properties include a material's spectrum of resonances, torsion force and modulus of elasticity as well as electrical conductivity by reducing electical "smog" and interferance fields."
    Har visst effekt uansett hvor de limes fast
    "Windows and Glass-doors Windows do create extremely undesirable reflections which do distract from the pleasure of listening to music. One E-pad +S placed unobtrusively at a corner of the window-glass will help to alleviate some of the negative issues glass imposes on your listening environment. The same is valid for glassy picture frames, glassy tables and mirrors. Screens are to be treated the same way as other areas made of glass concerning their acoustic properties. "
    Medlem-
    Å herregud
    Sitat:
    Kun ca 20000kr.
    Dette er jo ikke noen upris.Du må huske på hva de gjør for lyden ...;)
    Dr Dong
    landskapet uten motstand
    Å herregud
    Sitat:
    Kun ca 20000kr.
    Jeg lurer av og til på hvor stor andel fortapte som befolker vår nerdegruppe med tanke på hvor utbredt slikt er i de fora (blader/nettsted ett) som materialiserer våre interesser. I disse kontekster er det mest forstandige en kan si: Jeg er døv!
    Brummund
    Fredrikstad
    Tipper du merker mer ro i lydbildet nå, og at mikrodetaljene kommer tydeligere frem. Videre kanskje litt mer luft rundt instrumentene, og at det er lettere å plassere dem? Kanskje stereobildet er så bredt at trommisen i Dave Brubeck quartet nå sitter i naboens stue?
    Fenalaar
    Det skulle vært meget artig å vite, ja...
    Så vidt jeg greide å finne ut av beskrivelsen er det altså en svart, lukket boks, med en enleder kabel som kommer ut. Denne kabelen kobles så til jordplan i apparatet, og ingenting annet. Det er ingen andre ledere som kobles til jord, signal, strøm eller annet...
    Johan-Kr
    L
    larkus!
    Johan-Kr
    En jordleder fra chassis til en potte med standard blomsterjord fungerer garantert bedre.:)
    L
    larkus!
    Merket ingen forskjell. Jeg har sikkert hverken god nok hørsel eller godt nok anlegg........... Vurderer å legge klistremerkene ut for salg på torget. Er halv pris (ca. 450 kroner pr. stk.) for mye? :cool:
    Distinctive
    Litt sloppy med fonten her, så virkningen til dine copy cats er tvilsom >:D
    Mener også jeg har sett audiofile ropert-modeller hvor man kan snakke med blomstene mer effektivt og når disse trives, så fungerer potten mer effektivt til jording.
    H
    Hardingfele
    Jeg heter Stein. Får en slags pre-lytt effekt om du døpes til HiFi-opplevelser.
    L
    larkus!
    Hva i h..... er nå dette da? Strømstøpsel i ene enden og RCA-kontakt i den andre.
    Perfect Ground Cable fra Gutwire. Ene enden i strømkontakten og den andre i en av inngangene på forsterkeren.
    Vanlig jording via strømkabelen er visst ikke bra nok ifølge Gutwire, men denne skal etter sigende kurere støy og jordingsproblemer du ikke visste at du hadde.
    Skulle likt å vite hvordan denne kabelen er koblet...............
    Edit: Testet av 6moons med fenomenalt resultat
    http://www.6moons.com/audioreviews2/gutwire/1.html
    L
    larkus!
    Versjon med spade. Er dette rett og slett bare en ekstra jording i tillegg til jordingen i strømkabelen? Strømkontaktene i støpselet kan umulig være tilkoblet. Må visst ha 30 timer med innbrenning også før en oppnår full effekt.
    Lukter humbug og svada lang vei!
    Specifications:
    Conductors: Multi-Strand High Purity Oxygen Free Copper
    Conductor Gauge: 14 AWG X 2
    Insulation: PVC
    AC Connector: Leviton
    Connector: RCA, Clip, Spade, XLR, 3.5mm or Coaxial
    Fenalaar
    Jeg er forsåvidt ikke overraska over godt resultat i 6moons. De gutta der er glade i tweaks.
    Jeg regner med at den kabelen har en leder som går fra skjermen på RCA-kabelen og til jord-forbindelsen i støpselet.
    Johan-Kr
    6moons og lugubre produkter går hånd i hånd. Er gått til å bli den mest useriøse (av mange) testsiden der ute dessverre.
    J
    Det er sånn ca. det samme som f.eks. SR og Nordost har. Tanken er å lede vekk støy som ligger på chassis. Den RCA`en er sannsynligvis kun koblet på minus siden da den har kontakt med chassis, eller man kan koble spaden på en chassis skrue. Og så kjører man dette til jord på nettet eller til en egen jordingsblokk...f.eks. Funker det men man lager det selv for noen hundre lapper.
    L
    larkus!
    Jeg er av den oppfatning at jordingen i strømkabelen gjør den jobben minst like godt.
    J
    Sikkert sant. Men det er billig å teste ut dette selv. Man trenger ikke å kjøpe kabler og andre bokser til tusenvis av kroner.
    L
    larkus!
    Jeg ser for meg sitasjonen når en overivrig diy'er lager sin egen versjon av den kabelen og misforstår hvordan det skal kobles i støpselet.
    svart-hvitt
    Sjefen selv, Srajan Ebaen, har for øvrig et lytterom som smaker av alt annet enn high-end.
    En helt vanlig stue med mye glass og vinkler, men neppe egnet for å suge den ekstra informasjonen ut fra kabler, elektronikk og høyttalere...
