Finnes det noen "tweaks" som er så "over the top" at ingen går på de?
  • bambadoo
    Ted Denney har oppgradert sine blue fuse.
    Nå er det Orange som gjelder.
    https://www.synergisticresearch.com...RVzAomYIp5drl_jgf1UfkV9AVVGu-wrJ4r7QbCXA9mYg8
    The new ORANGE Quantum Fuse is a direct result of technology we first developed for our Limited Edition Galileo SX PowerCell. At its core are new UEF Technologies and a completely new multi-stage high voltage treatment process for the lowest noise floor of any fuse we have ever manufactured. In fact, ORANGE is by far the most significant leap in performance across five fuse generations. Subjective improvements include better timbral accuracy where separate instruments and voices take on a new degree of life-like realism. Other benefits over prior SR fuses include a larger soundstage with greater depth, width, and front-to-back layering. Musicality or the presence of increased detail without a hint of fatigue is off the charts for extended listening that is never harsh despite being our highest resolution fuse to date. As always, you are welcome to try Synergistic Research ORANGE Fuses in your system for 30-days risk-free and return them to your SR dealer for a full refund if you are not completely satisfied.
    Blir vel et par laken pr. stk!
    Løp og kjøp
    Når vi er inne på det.
    Du får nye veggstøpsler også
    https://www.synergisticresearch.com/accessories/power/uef-blue-duplex/
    Det er så bra at de låter godt uten innspilling og nær max etter bare 96timer?
    Built with advanced UEF Blue Fuse Technology, our New UEF Blue Duplex is the most transparent, dynamic and musical sounding duplex on the market today. We start with UEF Blue Fuse Technology including the UEF Blue Fuse Compound, so you experience the Blue Fuses' signature of explosive dynamics, holographic soundstaging, and musicality with extreme resolution. We then condition each UEF Blue Duplex with 1,000,000 volts of electricity for added resolution, clarity and soundstage scale and holography and then apply a second conditioning process first developed for our Blue Fuses to make our new Blue Duplex sound musical right out of the box while reaching near maximum performance after only 96 hours of run time in your system. Sold with a no-risk money back guarantee, audition your system today powered through our highest resolution duplex for risk-free for 30-days. So stop singing the blues and rediscover your music collection with the ultra-resolution SR Blue Duplex from Synergistic Research!
    No brainer iflg. Ted
    Her er en liten "review" fra en vital ungdom
    Han er selvsagt FB venn med Ted.
    ja kjipt å bestille "blue fuse" dagen før den mye bedre "orange" blir lansert.
    Eirik84
    Drammen
    Han er i alle fall raus nok til å gi 30 dagers returrett da :p
    Drossel
    Har Sorte sikringer. De gav så mørk baggrund at jeg tog dem ud igen. Holder mig til helt almindelige sikringer. De har alle sølvtråd. Til gengæld køber jeg plastfrie sikringsholdere.
    Snickers-is
    To understand how electricity travels without electrons ever leaving their respective atoms it is helpful to consider the spectator ‘wave’ at a football match.
    Det er bra de aller fremste hodene på strømrensing vet hva strøm er da...
    Sent fra min SM-G965F via Tapatalk
    JENO
    Saksvik - Trøndelag
    Merkelig at alle tweaks gir eksakt samme forbedring...
    Snickers-is
    Det er faktisk ikke merkelig i det heletatt. Dette har det vært forsket på. Dette er "forbedringer" som går igjen hver gang man ikke har endret noe, men bare tror det er slik.
    JENO
    Saksvik - Trøndelag
    For ordens skyld: Jeg var ironisk. ;) Endringene skjer selvfølgelig i lytterens hode.
    Snickers-is
    Det var ikke vanskelig å forstå. Jeg følte bare for å legge til at dette faktisk henger godt sammen med vitenskapen.
    Hedde
    Førr evig!
    Kan dette faktisk skje, eller?
    " ..the room gets bigger, more atmospheric, you start to see images of musicians"
    "...which brings the musicians closer to you: drier but more intimate, more apparent detail"
    Eirik84
    Drammen
    Nice, da trengs ingen målinger heller ;)
    Litt mer om UEF.
    In fact, UEF Tech is so powerful even an electrical chain several miles long is fundimentally improved with nothing more than a single fuse engineered with our patented UEF Technology.
    michell
    Frequently asked questions.
    Q: Are fuses directional?
    A: Yes, fuses are directional. Electricity should flow from the left to the right when you view the fuse. If you do not know the direction of flow you should listen to the fuse inserted in both directions. One direction will sound more detailed. This is the correct way.
    Q: Do fuses have a burn in period?
    A: Yes, most products have a settling in period. The first 200-300 hours of use are the most crucial.
    :D
    Og så bare USD 159,95 pr. stk. da???
    WayAhead
    Sky No Limit....
    Bruker 2 kalibrerte Clearup Fuses i parallell i hver fase montert hver sin vei slik at de er dobbeltvirkende. Kun kr. 5000 pr stk. Only 18k 4 4.
    Edit: $
    WayAhead
    Sky No Limit....
    Hereka, endelig den hele og fulle sannhet om kanellyd, forsterkerly lyd ltd ig annrn magi
    Hi-Fi akustikk
    :D
    Må være laget for de med mye DC på strømnettet disse sikringene. Kanskje de har innebygget diodefunksjon?
    Pink_Panther
    Nå ble jeg litt usikker på om du helt forstod hva det der handlet om?
    Samme her. Det er i grunnen ikke noe nytt at ultralyd kan brukes til å riste i stykker ting (og celler) hvis man finner resonansfrekvensen.
    Litt mumbo-jumboprat, et par doser cryo og quantum toppet med referanse til N. Tesla så er det en verdensnyhet. Og folk biter på...
    4-string
    Interiore Simplicitate
    Det har sikkert blitt påpekt flere ganger allerede, men svaret er nei.
    Det finnes ikke tweaks som er så drøye at de blir gjennomskuet av alle, det vil alltid finnes noen som hører forskjell og forsvarer det med nebb og klør.
    En kompis av meg hadde en periode hvor han brettet hjørnet på den ene gardina i lytterommet (noen som husker den? [emoji849][emoji4]) og var strålende fornøyd med det lysmessige løftet.
    Dette var etter at han brukte tomme doruller som kabelløftere, noe som forøvrig også løftet lyden veldig visstnok. [emoji38]
    motoren
    Flekkefjord
    ^Forskere. Vi glemte forskere.
    Ja. En eks-rakettforsker fra NASA tilfører stor troverdighet, spesielt hvis vedkommende ikke vil si et skvatt om hvordan dingsen fungerer, bare at det er hemmelig. (Looking at you, Jack Bybee.) Noen har tydeligvis stor tillit til denslags hemmelighetsfull faglig autoritet.
    Det er bare litt snodig at jeg, som faktisk har en lang liste av helt ekte slike kvalifikasjoner, stadig blir bedt om å ikke forsøple kabeltråder med innvendinger. Nei, her vil man ha illusjonene for seg selv, uberørt av fakta om hvordan fysikken i dette universet egentlig virker.
    Jeg antar at rakettforskere fra NASA bare er troverdige hvis de bekrefter at tweakeriet fungerer, fysikk og univers be damned. I det øyeblikket de antyder at lytteinntrykkene kanskje snarere har noe med psykologi å gjøre er de ikke troverdige lenger. Rart, det der.
    AOC
    Tomme tørkeruller gir ENDA bredere lydbilde, naturligvis. :-D
    vidarje
    Rasta
    Samma som med vaskepulver nu 50% effektivare. Hur dåligt var det innan då?
    Kom til å tenke på Phillips sine reklame videoer for en del år siden hvor de brukte Beatles sin Getting Better og stoppet akkurat før de synger "it can't get no worse":)
    4-string
    Naturligvis! :)
    Pink_Panther
    Dumme meg. Jeg hadde hørt at Torky tørkeruller var meget gode og regnet da med at kjernen fra disse ville være et suverent valg. Kjøpte 20 ruller.....
    :rolleyes:
    lovemusikk
    For best mulig ro i stua, kast ut dama og hør hvordan lyden virkelig løftet seg.
    Okay, kanskje det endelige svaret til strådstarter.
    Svaret er nei!
    lovemusikk
    For best mulig ro i stua, kast ut dama og hør hvordan lyden virkelig løftet seg. :p
    Noe annet..
    For å dempe skarp lyd, sett inn propper i ørene, evnt skift anlegg.
    Får eltilsynet på besøk snart. Best å gjemme nordost kablene jeg har liggende å slenge på et rom.
