Franco Serblin Accordo Essence
FRANCO SERBLIN ACCORDO ESSENCE
After years of research, the Franco Serblin Accordo Essence is the newest speaker from the Franco Serblin family. The Essence combines a perfect finish in combination with a sublime sound. The Accordo line started with the Franco Serblin Accordo and now expanded with the Essence floor stand. The new loudspeaker is characterized by a rhythm and tonal sound perception that you become directly involved with the music. In the words of Franco Serblin the essence of music.
The design of the Franco Serblin Accordo Essence can be seen as an instrument in itself. The special curved design eliminates standing waves in the housing. The housing is handmade by artisans in Italy. The uniquely designed fronts of Franco Serblin ensure that there is no obstruction in the sound and are visually a beautiful finish. The wooden cabinet is located on aluminum feet with the spikes included. In this way the housing can optimally use the energy without resonating in the floor.
The name Accordo comes from the foundations of music, essential for tuning a musical instrument: an agreement. If we consider a large orchestra, a single instrument or a piece of music, without prejudice, an agreement is at the basis of all this. The realization of the loudspeaker involves the tuning and harmonization of the various parts in something unique and expressive: from the drivers to the crossover parts, from the cabinet to the support, the individuality of each element merges into a whole. This offers the listener a sound image or the "quality of illusion".
Specifications
Type: 3-way floorstanding speaker
Housing: Super stiff, arched solid wood structure, handmade by master craftsmen.
Tweeter: 29 mm silk dome - designed by Ragnar Lian, one of the greatest masters of the transducer designer.
Middle woofer: legendary, custom made, 150 mm middle toner
Woofer: 180 mm woofer with aluminum dust cover
Cross-over: phase-coherently completed to achieve precise soundstaging, focus and image depth
Frequency range: 35Hz - 22KHz
Nominal impedance: 4 ohm
Sensitivity: 88dB / 2.83V / 1m
Minimum power: 20 W / channel
Dimensions: 1100 x 230 x 430 (HxWxD)
Weight: 60 kg per pair of speaker, 70 kg per pair (including packaging)
Finish: solid walnut - metal parts in chrome and aluminum
Pris: 152.000.- ink. mva.
Vi sender fraktfritt over hele landet.
JWK Audio/Sound of heaven
Tlf:+47 464 29 861
Mail: kontakt@soundofheaven.as
Hjemmeside: www.soundofheaven.as
Cato G.
Har fått fantastisk omtale i tysk hifi-presse: Stereoplay 06/2020: "HighEndig", på linje med Magico A3, "hifi & records" 1/2020: "..tryller fram den fineste gjengivelse". Den som kunne fått hørt den....
sound of heaven
sound of heaven sine annonser
Opera Prima V2 - Secrets of Home Theater and High Fidelity
Strålende test av Opera Prima V2 fra deres nye Classica Line serie (y) Noen utdrag: Opera’s Classica Prima v2 Loudspeakers play easily to high volumes without harshness. With a massive sound...
Nytt merke hos Sound of Heaven - SHANLING
  • 1
Sound of Heaven gjenintroduserer Shanling på det Norske markedet med deres splitter nye modeller CT90 og SM90. Når det kommer til ytelse, pris og kvalitet så mener vi at Shanling har satt en helt...
Indian Line Utah serie
  • 1
Indian Line sin nye serie Utah med modellene Utah 5 og Utah 8 står nå ferdig innspilt og klare for demo i våres show rom (y) Tilbakemelding fra fornøyd kunde:) Hei Jess! Ja dette var herlige...
Franco Serblin Accordo Unica - test i Hi-Fi Plus
Strålende test av Franco Serblin sin nye topp modell Accordo Unica i Hi-Fi Plus :) Noen utdrag: This is a loudspeaker that treats music with ` generosity ` . That sounds quite abstract, but a...
Introduksjonstilbud - Takumi
Introduksjonstilbud på Takumi platespiller og pick up ut mars mnd. Vi vil nå tilby en ferdigsydd pakke fra Takumi bestående av dere kritikerroste TT 2.1 DC platespiller med deres Kuro mc pick...
Takumi Moving Coil Cartridge Series - priser klare
Takumi Moving Coil Cartridge Series The Takumi range of moving-coil cartridges is designed and hand-assembled with one clear purpose: to extract music from the groove with precision, stability...
