Gold Note - DS-10 på lager
Gold Note - DS-10 på lager nå
DAC, Streamer, Forforsterker ( kun digitale innganger ), Hodetelefonforsterker
For mer informasjon: https://butikk.pmaudio.no/produkt/elektronikk/da-convertere-dac/ds-10-2
Epost: kontakt@pmaudio.no
Tlf.: +47 38 18 31 15
Mob.: +47 917 13 655
“The DS-10 presents mature, audiophile sound, but what is most surprising, at the level we
can expect from expensive, specialized CD players! There is also the icing on the cake for people who like streaming music via Bluetooth. The DS-10 showed off a perfectly balanced and
rich sound of a quality not differing from what we can get in combination with a classic CD
HIFI CLASS
TECHNICAL SPECIFICATIONS
D/A Converter AKM AK4493 PCM up to 32bit/768kHz and DSD512 native
Network Connectivity: LAN/WLAN (WiFi): 802.11b/g via RJ45 10/100Mbps socket
Streaming in High Quality: AIRPLAY, ROON Ready, TIDAL & MQA via Tidal, QOBUZ, SPOTIFY &
Spotify Connect, DEEZER, V-Tuner
Smartphone App: available for iOS and Android
Digital Inputs:
Ethernet LAN and Wi-Fi DSD64 (DoP) Resolution: PCM up to 24bit/192kHz;
Bluetooth 5.0;
RCA S/PDIF coaxial PCM asynchronous up to 24bit/192kHz;
2x TOS-optical PCM asynchronous up to 24bit/192kHz;
COAX asynchronous up to 24bit/192kHz;
AES/EBU balanced PCM asynchronous up to 24bit/192kHz;
USB-A port to feed USB flash memories, FAT32/NTFS formatted playing DSD64 and PCM up to
24bit/192kHz;
USB-B asynchronous up to DSD512 and PCM up to 32bit/384kHz
3 Audio Outputs: 1 RCA; 1 XLR; 1 headphone 6,3mm Jack on the front panel
Display & SKC: clear and easy to read display and single knob to control every function
pmaudio
pmaudio sine annonser
OSLO HIFI SHOW - VI FIKK IKKE ROM
  • 65
I år skulle vi for første gang på noen år, slå på stortromma igjen. Vi ønsket større rom enn i fjor, så vi kunne makse, med bl.a. Alsyvox BOTTICELLI høyttalere. Ønsket var rom på +/- 60m2 og...
Nyhet fra Metronome - DSAS - Server / Nettverkspiller / Streamer m/Audirvana
Siste medlem i produktserien DIGITAL SHARING er på plass og på lager, DSAS, Metronome`s og vår første server for optimal presentasjon av digitalt lagret musikk. Inkludert 3 års avtale med...
Hifimessa Horten 20-21 September 2025
  • 4
I år kan vi av forskjellige årsaker dessverre ikke bygge opp den sedvanlige butikken vår på messa, som vi har gjort i alle år. Ingen plater, ingen Furutech produkter etc... Men det blir en liten...
Metronome: DST CD-transport / drivverk
Siste produkt i Digital Sharing serien, CD Transport Minimalistisk design Sammen med f.eks Metronome DSC MINI ( DA Converter ) i Digital Sharing serien får man plass til begge disse enhetene på èn...
Oslo HIFI Show 22-23. mars 2025
Så er det på tide å takke alle som var innom rommene våre på hifimessa sist helg, og TAKK til alle som ga oss supre tilbakemeldinger. Og meget hyggelig er det å treffe igjen sjeler vi er blitt...
Hifimessa i Horten 05 - 06 Oktober
  • 1
Takk for besøk på Løvøya ( demo ) og Grupperom 1 ( salg ) i helgen - og takk for alle godord på lyden vi fikk Etter et par stressende år privat greide vi endelig å gjennomføre en messehelg igjen...
