IS-10 er den nye alt-i-ett-forsterkeren i Gold Note sin kompakte 10-serie. IS-10 er et komplett High-End stereosystem i en kompakt utførelse med en kraftig integrert forsterker på 90W ved 8Ohm (140W ved 4Ohm). Musikk-streamer og D/A-konverter støtter høy oppløsning opptil PCM 32bit/384kHz og DSD256. IS-10 er sertifisert Roon Ready, den er kompatibel med Tidal, Tidal Connect, MQA, Qobuz, Spotify og Deezer (via LAN, Wi-Fi og Bluetooth).
IS-10 kan kombineres med en PA-10 EVO effektforsterker for øket effekt. Ved å brokoble den interne forsterkeren i IS-10 og kombinere denne med en brokoblet PA-10EVO øker utgangseffekten til hele 280W ved 8Ohm.
![the-ear.net](https://the-ear.net/wp-content/uploads/2024/02/gold-note-IS-10_G.jpg)
All For One Gold Note IS-10 Streaming Amp | The Ear
Ease-of-use has become something of a priority, and I don’t’ miss the tangle of interconnects. For me, the IS-10 embodies all there is about modern-fi.
![the-ear.net](https://the-ear.net/wp-content/uploads/2022/09/cropped-favicon-32x32.png)
Gold Note have clearly nailed it. Their IS-10 all-in-one creation provides a single-box solution catering for most digital and streaming requirements. The inclusion of Internet radio and storming headphone circuitry is an added bonus.
The bass and midrange are exemplary; the sound produced is detailed and engaging; the soundstage deep and wide with immaculate imaging. I was also struck by the dynamics and speed that this compact design can create. There’s real grunt when needed from a sound that’s potent without becoming harsh or edgy. The attention to current delivery and self-adjusting damping factor, dependent on the connected load, has paid off such that it can be partnered with a wide range of loudspeakers to create a satisfying sound. If the IS-10 is portent of what’s to come from Gold Note, this is a brand to keep a very close eye on."
-the ear
![malaaudio.no](https://webimg.blob.core.windows.net/analogsenteret/prodimages/cardthumb/111114254.webp)
![viewer.joomag.com](https://app.joomag.com/Frontend/WebService/getThumbnailSocial.png?mID=2737041&1718395193&spread=49&width=1200&height=627&hq)
Stereo+ stereopluss.no 10/2023 | Page 50
I denne utgaven er det høyttalerbonansa hva angår tester: Audiovector QR5 SE, Børresen X2, Klipsch Cornwall IV, MoFi SourcePoint 8. I tillegg tester av Naim NPX 300 PSU, Gold Note IS-10, JBL Spinner BT. Hjemme-hos-reportasje, nyheter, musikk.
![viewer.joomag.com](https://viewer.joomag.com/assets/img/app/Icon-60.png)
"Konklusjon
Jeg tror du skal jobbe litt med å finne en separat integrert forsterker,
en digital-til-analog-konverter og en streamer, pluss det du
måtte trenger av kabler for å koble dette sammen med tilsvarende
lydkvalitet for tilsvarende pris, som det Gold Note IS-10 kan tilby.
Dette er et av de produktene som gjør det moro å være hifijournalist.
IS-10 viser nemlig at du kan få gnistrende god lyd, uten at du må
opp i et sekssifret beløp for å bli fornøyd. Da blir det lekre designet
og brukervennligheten med å kunne styre alt fra telefonen eller
nettbrettet bare toppen av kransekaka. Til denne prisen er det vanskelig
å ikke anse IS-10 som en innertier av et produkt."
- Roy Ervin Solstad | Stereo+
