Gradient lanserer ny modell: 1.4
Så lanseres Gradient`s siste kreasjon som heter 1.4
1.4 er en fortsettelse og videreutvikling av de tidlige modellene, 1-serien
Som før - kontrollert spredning
1.4 er nå første modell med det spesialkonstruerte coax-elemetet, designet i et samarbeid mellom Gradient og SEAS, kun for Gradient
Kontakt for info:
e-post: kontakt@pmaudio.no
Telefon: 38 18 31 15
https://pmaudio.no/nyheter/gradient-142018/4/24
Gradient beskriver tingene best selv:::
GRADIENT 1.4
It was just 35 years ago when we decided to take our own way and not to follow anyone else. Not to fallow industry conventions and evident solutions. With one single goal: to design a loudspeaker that sounds excellent in all kinds of rooms.
During the centenary of Finland's independence Gradient added another chapter to the legendary Gradient 1.-line.
The sprit of the Gradient 1. - speakers combined with the inventions we have made during these years make the 1.4 a real unique loudspeaker, destined to become an instant classic.
THE LATEST COAXIAL DRIVER WITH NO COMPROMISES
The first coaxial structure in our speaker elements was carried out in Revolution model, launched in 1993. Thereafter, several versions of the coaxial speaker elements developed together with Seas have been used in our loudspeakers.
The new Gradient 1.4 is the first speaker utilizing our latest coaxial technology made exclusively for Gradient in Norway. A 176mm pre-coated reed paper cone cone handles frequencies up to 2500Hz. High frequencies from 2500Hz to over 20kHz are reproduced by a 25mm Al/Mg-dome tweeter placed at the apex of the midrange cone. Such a point source is generally accepted as an ideal sound source for its excellent phase and amplitude response. The end result is an extremely accurate, stable and three dimensional soundstage.
SPHERICAL ACOUSTIC RESISTANCE ENCLOSURE
To minimize reflections from the speaker cabinet, the coaxial element is mounted in a spherical enclosure. The sphere is an ideal form with no structural interfaces and discontinuities.
Still Gradient is not Gradient without something completely new and unique. From the very beginning it was clear that the new Gradient 1.4 will utilize our acoustic resistance enclosure - technology, like used in many previous Gradient models. Now this is made as ideal as possible: Symmetric spherical housing leaks “anti sound” from the opening behind the sphere, cancelling back radiation and early reflections from the surfaces behind the loudspeaker.
The backward radiation of the Gradient 1.4 is attenuated by 20dB at mid frequencies which is only one percentage of the total sound energy.
In a nutshell: the room influence to the sound remains very small giving the Gradient 1.4 a very similar sound characteristic in many different rooms.
BASS DOWN TO 30HZ
Low frequencies below 200 Hz are reproduced by a bassreflex enclosure tuned at 27Hz. Large crossection area of the reflex tunnel guarantees no breathing noise even at high sound levels.
220mm long throw woofer made by Seas in Norway is facing towards the floor. The woofer has an extremely stiff aluminium cone giving tremendous bass precision.
FUNCTIONAL DESIGN
Every aspect of the speaker form has a meaning. Acoustic design and function determine the shape. There is nothing more to add - there is nothing left to take away.
The cabinet of the speaker is made of advanced technopolymer in Finland. Together with the ideal form of the speaker exceptional combination of stiffness and rigidness is obtained to eliminate cabinet vibrations.
The finishing of the speaker cabinet, available in graphite black and white, is durable providing easy to clean and long-lasting surface. For years to come.
pmaudio
Veldig sober design!
Gradient`s høyttalere er stort sett av litt spesiell design - men som Gradient sier:: Every aspect of the speaker form has a meaning. Acoustic design and function determine the shape.
Altså - funksjonen som Gradient alltid er ute etter - bestemmer formen på deres høyttalere.
Og funksjonen Gradient alltid er ute etter er å minimere rommets og høyttalernes egen påvirkning av lyden - sånn at høyttalerne lyder mest mulig likt i alle slags rom.
De lager ikke spesielle design for designet sin skyld.
Ett av målene ( virkemåten ) med formen på disse høyttalerne er å unngå all refleksjon fra en flat frontbaffel og fargingen av lyden derifra.
I tillegg er det noe med dette designet ( som ikke jeg kan forklare hvordan skjer pr nå ) som kansellerer bakoverutstråling ( akkurat som på andre Gradient høyttalere ) - og dermed unngå refleksjoner fra bakvegg - om man plasserer høyttalerne nær bakvegg.
Toppmodulen ( kula ) kan vris / vinkles uavhengig av bassmodulen under.
De første 1.4 kommer til lager og demo denne uka så det skal bli spennende å høre resultatet, om den kan konkurrere med REVOLUTION og HELSINKI 1.5
vrøvl
Dødskul! Er den dyr?
pmaudio
Den kommer på kr 56900,00
Leveres i sort eller hvit
Vi kommer antagelig til å legge ut et introduksjonstilbud i løpet av noen dager så er det interessant så følg med på hjemmesiden vår - inne på TILBUD siden
Paul Mortensen
busserulle
Når kan vi forvente en Revolution med det nye coaxelementet? Eller er 1.4 modellen å anse som den nye toppmodellen?
pmaudio
Nye REVOLUTION er snart klar!!!
Vi ( PM Audio ) er med i prosessen vedr valg av terminaler så når dette er bestemt så har vi REVOLUTION på plass i Kristiansand og forhåpentligvis mange andre steder i landet.
Hvilken modell som blir toppmodellen tør ikke jeg å spå om på dette tidspunktet i og med at jeg ikke har lyttet på 1.4 enda
Fraktselskapet melder at de skal leveres til oss i dag så da kommer forhåpentligvis 1.4 i spill denne helgen.
Paul Mortensen
busserulle
Paul Mortensen
Kunne jeg selv valgt terminaler på mitt neste sett med Revolution, ville det garantert falt på disse. Utrolig brukervennlige og skikkelig laget. Litt kostbare kanskje, men en høyttaler som Revolution burde vel ikke ha noe dårligere.
https://www.madisoundspeakerstore.c...sts/propeller-post-16mm-tc-binding-post-pair/
pmaudio
Paul Mortensen
Såfremt de passer så skal vi nok ordne dette. Hvilke terminaler er det du tenker på??
Paul
pmaudio
pmaudio sine annonser
Nye sendinger fra Analogue Productions og Mobile Fidelity ankommet
  • 1
Siste sending fra Analogue Productions ankom i går, med bl.a. Steely Dan Aja UHQR og The White Stripes - Elephant UHQR, Genesis, Phil Collins mm... Se her...
Ny sending fra Analogue Productions og Mofi har landet
Vi kjører på og bygger lager på Analogue Productions og Mobile Fidelity - og andre Undertittelen på PM Audio logoen i dag er: HIFI OG MUSIKK, som refererer til både hifi-utstyr pluss LP plater...
Enda en nyhet fra Frankrikes referansemerke - Metronome: AQWO 2
AQWO 2 etterfølger den første integrerte SACD/CD/DAC spilleren ( AQWO 1 ) hos Metronome AQWO 2 er en fullverdig DAC / CD / SACD spiller pluss Streamer Til mer info på nettbutikken...
Metronome NYHET igjen:: Le Streamer
Siste skudd på Metronome Classica serien - Le Streamer I motsetning til DSS 2 så har Le Streamer et tradisjonelt dimensjonert Metronome kabinett Le Streamer is the latest network player from...
NYHET igjen fra Metronome:: DSS 2 Streamer / nettverkspiller
Så er tiden inne for neste generasjon Metronome DSS streamer - DSS 2 Akkurat kommet i hus og vi er spent på resultatet Kontaktinfo: e-mail: kontakt@pmaudio.no Tlf.: +47 917 13 655 Til...
DEMOSALG av Gold Note XT-7 Gulvstående høyttalere
  • 3
Fantastisk italiensk finish Fremstår som nye Lydsignatur: Heller mot det varme En bånddiskant som for en gangs skyld ikke er skarp/spiss og ubehagelig for følsomme ører Meget lite brukt og har...
