Høyttalerkabel med ledere med ulike tverrsnitt - noe for seg?
P
parafinoksen
Er det noen som har testet/eksperimentert med HT-kabler à la dette?
Eksempelet er en Purple Rain-kabel fra polske Melodika. De skriver:
Description:
Construction: 110x0,15mm and 1x0,85mm
BassCore Technology: unique cable construction, distinguishing between cores to low and high-mid tones (more below)
Geometry: conductors twisted with each other in order to reduce their interference
Dielectric: Perfect cable for concealed wiring (unique external shielding made from modified PCV with higher resistance, thanks to that cable can be laid under plaster or concrete without any concern of damaging it).
Wires resistance: (DC w 20°C): 6,5 Ohm/1000m or less
Insulation resistance: >=1 G Ohm/km
Voltage test 1kV
Research has shown that low frequencies run faster inside the guide, and the higher frequency signals on the surface of the guide. Thanks to BassCore technology - special bass conductor 0.85mm dedicated for low frequencies and bundle of 110 x 0.15mm dedicated for mid and high frequencies - we can obtain more balanced, dynamic and deep sound with controled more precise bass. Additionaly conductors twisted with each other eliminates their interferences, thanks to that sound is more detailed and lucid - thanks to that geometry we can also put speaker cable near the power cables without risk of sound degradation.
Specification:
Lenght: by the meter
Conductor material: OFC: 99.99%
Shape: Round
They can be applied to the installation: Yes (double isolation)
Directional: No
Wire flexibility, diameter of the cable breakdown: 52mm
Cable thickness: 7mm
Construction: Standard
Isolation: double PVC
Bi-wiring/Bi-amping: No
Gauge: 13AWG
Pros: quality/price ratio, flexible, shielding, deep bass, controled bass, treble, timbre
Cons: Color
OTHERS: Construction: 110x0.15mm and 1x0.85mm
:: Perfect cable for concealed wiring (unique external shielding made from modified PCV with higher resistance, thanks to that cable can be laid under plaster or concrete without any concern of damaging it).
:: Wires resistance: (DC w 20°C): 6.5 Ohm/1000m or less
:: Isolation resistance: >=1 G Ohm/km
:: Voltage test 1kV
Tanken er altså at den tykke lederen i midten skal håndtere bassignalet bedre.
C
cruiser
BassCore Technology.. Høres ut som noe Distinctive, kiwibob og andre tullebukker står klar til å kaste tusenlappene sine etter :)
P
parafinoksen
Hva vet jeg? Eg berre spyr :) (Er ikke mer enn en 60-lapp for meteren med 2,5 mm2, så ikke så mange pengene å tape.)
nat
Kimber Cable har sitt "VariStrand" system.
Morten N.A.T
Eirik84
Drammen
Nå er dette en strømkabel da, men PS Audio bruker også en blanding av forskjellige ledere i samme kabel:
PS-Audio-PerfectWave-AC-12-Power-cable-2-0-Meter-US-Version-New-in-box.jpg_640x640.jpg
Det korte svaret er nei, det har ikke noe for seg. Det finnes noe som heter skinneffekt som gjør at høyfrekvente strømmer går i overflaten av en leder, men med de frekvensene og tverrsnittene vi holder på med kan du gå ut fra at hele tverrsnittet leder strøm like godt.
Ut fra bildet består denne dessuten av uisolerte kobbertråder i kontakt med hverandre, og da vil den uansett opptre som en tykk leder, ikke som fler småledere. Det er ingen ting som forteller de ulike frekvensene hvilken tråd de skal gå i, bare en flertrådet kobberleder med 2,5 mm2 tverrsnitt tilsammen. Funksjonelt gjør ikke denne noe annet enn en bit RKUB fra Biltema.
Olav E
En hybrid kabel
Hei!
LFD Audio er en anerkjent produsent av forsterkere, men også kabler. Jeg har deres Hybrid Ribbon høyttalerkabel. Den består av en flat leder og en rund leder. Hvordan hver leder er bygget opp, kan jeg ikke si noe om. Kanskje ikke helt konstruksjonen du tenkte på da du opprettet tråden, men en interessant kabel jeg fikk lyst til å trekke fram.
Mener å ha lest konstruktøren sine tanker om kabelen, men husker ikke mye om det, annet enn at han mente ørene gav god nok begrunnelse for at det funket. Noe jeg selv kan bekrefte. Den funker faktisk meget godt, ikke minst ut fra hva den koster. Om valget av to forskjellige konstruksjonsprinsipper er årsak til den vellydende kabelen, vil jeg ikke mene noe om.
Her et bilde av min kabel:
Mvh Olav E
WayAhead
Sky No Limit....
Har denne tykke kobberkablen som er Audio kabel, husker ikke type/navn. Den har tykke kordeler i midten og tynnere ytterst, husker ikke om det er progressivt men den har luftig diskant og bra bass men mangler noe i mellomtone sammenlignet med mer nøytrale (ensartede) løsninger.
Balle Clorin
Det som er mest viktig her er hvilken vei kabelen er tvunnet . Kabelen blir påvirket av den lokale corioliskraften og om tvinningen ikke kompatibel med den påvirker det Strouhal frekvensen med påfølgene tap av diskant og gir ullen bass
WayAhead
Sky No Limit....
Jeg får splitte den og endevende den ene lederen så jeg nuller ut drefusjonsforretningen...
