HELOX reflex record clamp
the HELOX reflex record clamp - creating an unique contact between record and platter surface. Providing a sonically outstanding step forward with ANY turntable. High contact pressure combined with the all-new concept of liquid dampening clamp
The Helox reflex clamp combines some of the most important functions and features arising around the tracking process.
The Helox does so by offering new features and a sophisticated contruction unlike any other record clamp on the market.
The benefits:
1)Sophisticated mechanical advantages and solutions.
The Helox' function and construction ensures an etremely good contact pressure.
This is provided by the Helox' new reflex clamp principle.
It does so by creating a higher contact pressure than any vacuum suction.
This is done with a unique reflex-function without adding much weight to the bearing.
Further the liquid dampening inside the Helox - situated in a sealed inside chamber around the spindle - works wonders on micro resonances inside the record occurring during the tracking process.
2) Better sound - instantly.
Resulting in more clarity and higher low level detail resolution.
Giving you more "air" and fine soundstage detail in the sonic pricture.
3) Even better sound - by fine-adjusting turntable speed with stylus drag taken into account.
The Helox offers the serious audiophile the option to fine adjust the speed with stylus drag - i.e. while the sytlus tracks the record and inevitably slows down the speed ever so slightly.
Resulting in accurate speed under real working condition - which gives you much more correct pitch, transient timing and natural micro-dynamics.
4) Truly universal.
The Helox works on all turntables with a standard spindle diameter - even on turntables with an unusual long spindle.
The benefits in performance are instant and clearly audible on all turntables.
Easy user-exchangable strobe rings 50 hz/60 hz - 331/3, 45 or 78 rpm
Pris 4455,- NOK
tom@endpointaudio.no
47832922
The benefits:
4) Truly universal.
Pris 4455,- NOK
47832922
