Hvor mange audiokabler kan du se på bildet?
J. Brünnhilde
Unøytidelig førjulsquiz: Hvor mange audiokabler kan du se på dette bildet?
aam01
Sandvika
Vel, du kan jo sende digitalt audiosignal over USB.
H
Hardingfele
De Reference strømkablene koster jo bare USD 4000/1,5m, og ifølge Absolute Sound er resultatet formidabelt!
Løp og kjøp. Gjerne kjøpe en kabelkoker samtidig, siden det tar uker før strømkablene er innkjørt, selv med kokeren.
All cables take time to season and settle, but the MasterBuilt Reference cables seemed to require a longer run-in time than I’ve come to expect, even when using my cable cooker. As a reviewer who must routinely substitute cables and other components, I’ve invested in a cable burn-in device. The unit I own, the AudioDharma Cable Cooker 2.5 EFS, runs a continuous square-wave frequency sweep of about 1 VAC for interconnects and 22 VAC for speaker and power cables, oscillating from 0Hz (DC) to ≈ 40kHz, and back. Several days on this device is more effective than many weeks or even months of routine play. And in my estimation, it affords more effectual, not just more expedient, results that are unattainable by simply dropping the cables in place and playing your favorite burn-in material.
Yet even after being cycled through my cooker for what I have found to be the optimum period for most cables, the MBA References still took weeks after installation to offer their best. To be fair, I could have tossed them back on the cooker for another 12–18 hours, but I really wanted to hear them, so into my system they went. (Because such a cook-in device may require an expenditure that you don’t feel compelled to make, be certain to speak with your dealer about auditioning fully run-in cables in your system, as it makes a significant difference, particularly with this loom.)
aam01
Sandvika
Baksiden på mitt rack.
...og jeg vet ikke hvor mange det er. Gidder ikke telle.
Vis vedlegget 1083746
Du kan jo håpe på at forsikringsselskapet ditt eller brannvesenet ikke ser det bildet. Strømpadder som er seriekoblet er ikke regnet for å være spesielt brannsikkert.
arild
Sogn og Fjordane
Det spørs vel kor mange ampère den padda tåler, og kor mange utstyret trekker…
Har vore på LAN (dataparty - slik ungdommen likar), der padder var blitt ukritisk seriekobla av deltakarane! 😱
Skulle ikkje tru nokre skarve pc’ar drog særlig straum, men jaggu var det blitt god lunk i dei paddene ja!
Mvh Arild 😊
alipax
Herja
INGEN. Kun tre plugger med noe slangeskinn som er hekta på...
