Instillinger Riia. Ortofon Quintet blue
nikosidis
Har en Holfi Riia som jeg ikke har fått nok gain til min MC pickup.
Nå har jeg kjøpt en brukt REGA Fono MC-only Riia.
Noen som vet hvor jeg bør stille inn den i forhold til min pickup?
nikosidis
Manual
Fono MC
The Fono MC diskstage is designed to amplify the signal
from a moving coil cartridge to a level which can feed
into a 200mV line level input on a standard hi-fi amplifier
i.e. with CD, Tuner and Tape Inputs.
The Fono MC Input sensitivity, capacitive and resistive
loading can be set to four different levels. These levels
should match most MC cartridges, which have an output
level of 150 to 600μV and a loading requirement of 70 to
400Ω in parallel with 1000 to 4200pF.
Method of connection
Input
Connect the tonearm leads and earth (if used) to the
input socket and to the earth terminal on the back of the
Fono.
To change the Input loading and Gain (sensitivity)
(1) Remove the two Pozidrive screws on the back of the
unit.
(2) Holding the Earth terminal, pull the back of the unit
away from the case.
(3) Withdraw the back and PCB by approximately 8cm
from the case.
(4) There are four "DIP" switches on the PCB with the fol-
lowing markings.
LEFT LOADING SWITCH
RIGHT LOADING SWITCH
LEFT GAIN SWITCH
RIGHT GAIN SWITCH
(5) These switches can be set to the following settings by
turning the switches to there ON or OFF positions (facto-
ry setting 100Ω and 4200pF input loading).
Gain Switch Settings (Input sensitivity)
1 Off and 2 off = 150uV
1 On and 2 off = 300uV
1 Off and 2 on =460uV
1 On and 2 on = 600uV
Power Supply
Connect the Rega PS1 to the AC socket on the Fono
back panel.
WARNING: We advise you to turn the Fono diskstage
on first and then the amplifier last. This is because
the power surge in the Fono diskstage could cause a
“power on” thump which may distress the speakers.
Specifications
Input sensitivity for 200mV output in to 50KΩ
150μV
300μV
460μV
600μV
Factory setting150μV
Input Resistance loading
400Ω
100Ω
150Ω
70Ω
Factory setting 100Ω
Input Capacitance Loading
1000pF
2000pF
3200pF
4200pF
Factory setting 4200pF
Maximum input level with 100Ω and 4200pF input
loading
150uV = 10mV
300uV = 20mV
460uV = 31mV
600uV = 40mV
Minimum Output Load Impedance = 10KΩ
Power requirements = 24VAC @ 140mA (Rega PS1)
Frequency Response (50KΩ Load) = 13Hz (-3dB) to
100KHz (-0.1dB)
RIAA accuracy (50KΩ load) = +/-0.1dB 100Hz to 100KHz
Power Supply Specifications
Loading Switch Settings
Resistance loading
1 Off and 2 Off = 400Ω
1 On and 2 Off = 100Ω
1 Off and 2 On = 150Ω
1 On and 2 On = 70Ω
Capacitance Loading
3 Off and 4 off = 1000pF
3 On and 4 off = 2000pF
3 Off and 4 on = 3200pF
3 On and 4 on = 4200pF
Output
Connect the output socket of the Fono to the line input
on the amplifier.
PS1 UK
Input....................................................230V ~ 50Hz 0.05A
Output.....................................................24V ~ 300MA AC
PS1 EU (Euro 2 pin)
PS1 UL (American)
Input................................................................115V ~ 60Hz
Output............
nikosidis
Jeg skjønner det ikke. 100 ohm er ok men gain?
Der står det dette.
Hva skal jeg bruke?
Lurer også på instilling her.
1000pF
2000pF
3200pF
4200pF
tkr
Nede i fjæresteinene
Prøv med 300 uv
Og med en MC så er ikke kapasitansen så viktig. Du kan jo ikke ødelegge noe som helst ved å ratte litt der, så jeg ville prøvd meg frem. Tviler i grunn på at du vil høre noe forskjell i det hele tatt.
LESSisdox@
Åkrehamn,karmøy
Prøv med 1 off
2 on
3 off
4off
Pr side
Mvh Roy
Auditor
Nikosidis: Bruker 100 ohm her- på Rondo Bronze. Det funker gull.
nikosidis
Takk for hjelpen gutter. Skal prøve når jeg kommer hjem.
nikosidis
Fikk testa litt. 100 ohm, prøvde ikke andre ohm instillinger. Prøvde 300uV men det ble lavere gain og synes lyden virket litt dau, udynamisk, gikk derfor tilbake til default som er 150uV. Testa forskjellig instillinger med Capacitance Loading. 1000Pf var toppen og overtoner daut mens 4200Pf var litt mye topp. Endte på 3200Pf som jeg synes var best balanse med musikken jeg testet.
Regaen er bedre enn min tidligere Holfi Riia. Den gir mer rom eller luft rundt vokal og instrumenter. Bassen er også mer nøytral og detaljert. Testa først med noen låter fra "Brothers in arms 180g" Synes det låt veldig bra men ikke fullt så nøytralt eller riktig som på CD eller SACD. Rush "Moving Pictures" låt helt magisk. Veldig imponert over hvor detaljert og riktig bassen hørtes ut på den skiva. Dypbassen var rå. Bedre balanse på denne skiva med vinyl enn CD.
Uten å helt vite om det er formatet eller mitt oppsett, er vinyl hos meg litt mørkere og behagelig enn CD. Toppen er en anelse tilbakelent og ikke så dynamisk som på CD og derfor trolig mer behagelig. Passer godt til rock og stort sett elektronisk musikk. Skal teste litt mer. Må bli bedre kjent med analog riggen. Mulig jeg må sjekke litt justeringer på pickup osv. Uansett fornøyd med lyden.
steinost
Lillestrøm
Sitter selv og digger vinyl i kjelleren akkurat nå.
Nå er det ho Kari som får kjørt seg Over en by:=)
nikosidis
Bra det Steinar :)
Kom innom en dag på en kaffe. Jeg er på jobb hver dag jeg vet du.
