Har en Benchmark DAC1 (den anbefales!!). I manualen står det:
"REMOVING TOP COVER:
The DAC1 has a removable cover. This cover provides access to the jumper settings on the PCB. The DAC1 contains static sensitive components and should only be opened by qualified technicians. Static discharge may cause component failures, may affect the long-term reliability, or may degrade the audio performance. Use a static control wrist strap when changing jumper settings."
Hvor kritisk er dette egentlig. Er faren stor for å ødelegge elektronikk om jeg går inn og flytter på "jumper-settingene" med "rene" hender?
Hilsen Jone
Hilsen Jone
6.4 KB Visninger: 338
