Karan Master Collection POWERb mono
Karan Master Collection POWERb MONO, det nyeste produktet i Karans nye Master Collection-serien!
Den består nå av to effektforsterkere, to monoblokker og to forforsterkere.
Technical specifications
The following data were consistently measured on random test objects and are typical of the product in question. Nominal operating mains (AC) voltage of all our products is 115V or 230V. If the mains supply voltage drops approximately 10% below its nominal value, the power output of our amplifiers will reduce itself by approximately 15%.
INPUTS: 1 balanced (XLR) and 1 unbalanced (RCA)
INPUT IMPEDANCE: 30 kOhm (balanced/unbalanced)
INPUT SENSITIVITY: 2.0 V/RMS (for max output)
GAIN: + 36dB
XLR PIN LAYOUT: PIN 1-ground, PIN 2-positive signal, PIN 3-negative signal
(when use RCA input you need to insert XLR shorting plug!)
POWER OUTPUT: 1.200/2.100/3.600W at 8/4/2ohm
(peak power output: 1.500W at 8ohm)
FREQUENCY RESPONSE: 20 Hz to 20 kHz, +/-0 dB; (DC to 300kHz,-3dB)
DISTORTION: THD 0.03%
IMD 0.03%
TRANSIENT RESPONSE: Rise and Settling time < 450 ns
Slew rate 1.500 V/us (Amplification stages)
SIGNAL TO NOISE RATIO: > 120 dB (unweighted)
POWER SUPPLY: 2pcs of 2.100VA low noise toroidal transformers,
180.000uF custom made capacitors bank
AC VOLTAGE: 115 V or 230 V (nominal line voltage)
AC VOLTAGE RANGE: +/- 10% (from nominal line voltage)
WARRANTY: 5 years, parts and labor
NET DIMENSIONS: 504 x 292 x 521mm (whd); 19.8 x 11.5 x 20.5 inch (whd)
NETWEIGHT: 81kg / 178lbs (each)
PACKAGE DIMENSIONS: 720 x 410 x 738mm (whd); 28.3×16.1×29 inch (whd)
PACKAGEWEIGHT: 103kg/226lbs (each)
Karan Master Collection er nå komplett:
LINEa, PHONOa, POWERa og POWERa mono.
LINEb, PHONOb, POWERb og POWERb mono.
The LINEb costs (USD $29,000)
POWERb MONO priced at (USD $85,000)
Powerb stereo USD $43,000)
PHONOb USD $27,000
PHONOa USD $38,00
Alle priser uten moms!
Erdal Stereo
Erdal Stereo sine annonser
Karan Master Collection PHONOb
Another outstanding test of our preamplifier, this time it’s a phono preamplifier from the Master Collection series and model PHONOb. All those who want an even better phono preamp should think...
Karan Master Collection PHONOa
Karan Master Collection PHONOa et nytt produkt i Master Collection-serien fra Karan i Serbia.
Karan Master Collection POWERb effektforsterker
Karan Master Collection POWERa mono
  • 2
Nå er den neste gruppen av MASTER COLLECTION-produkter fra Karan på markedet! Det er to nye produkter med store forventninger til, etter den entydige globale anerkjennelsen LINEa- og...
Karan Acoustics Master Collection LINEb
Nå er den i Norge! Endelig er den nye forforsterkeren i Karans Master Collection på markedet. Den nye forforsterkeren kommer i et chassis. Her er det brukt løsninger og toppkvalitetsdeler som...
NEO Audio Racks
NEO Audio Racks
NEO Audio Racks Neo har forskjellige modeller; LIGHT TRIPOD, LIGHT TRIPOD DOUBLE, TRIPOD, TRIPOD DOUBLE, QUATTRON, QUATTRON DOUBLE og QUATTRON REFERENCE QUATTRON og DOUBLE Audio rack er et...
