KUZMA har lansert en forbedret utgave av den renommerte 4POINT armen, som er mye større enn før.
4Point 14 is 4Point tonearm with 14 inch ( 353 mm) effective length which is fitted on 12 inch ( 291mm) distance position on the turntable
4Point 14 inch- New from July 2015 - Kuzma Professional Turntables, Tonearms and Accessories
http://www.kuzma.si/media/uploads/files/BROCHURE%20%204POINT%2014%20%20150601.pdf
Veil.pris blir Kr.89 000-.
Hjem
Technical data | Mass |
Effective length | 353 mm ( 14 inch ) |
Mounting distance | 291,50 mm( Kuzma cut- 291 mm ) |
Offset angle | 15,35 degrees |
Distance from spindle to | |
horizontal bearing | 342 mm |
Effective mass | 19 g |
VTA adjustment | yes |
Azimuth adjustment | yes |
Bias adjustment | yes |
Vertical damping | yes |
Horizontal damping | yes |
Detachable headshell | yes ( one extra supplied) |
Cables | silver |
Arm mount | Kuzma cut ( 12 inch position) |
Optional | extra headshells, headshell containers, different wiring option |
Hjem
37.2 KB Visninger: 2.216
