Lindemann Phono II
Lindemann har nå lansert en oppgradert og bedre versjon av sin lille RIAA.
Med dipswitcher i bakkant kan man lett stille inn ønskede verdier, og man har gått bort ifra den tidligere løsningen med balansert signal via RCA, noe som krevde en spesialkabel.
Dette er en knallgod riaa i en liten boks.
PRIS: 6.990,-
Info fra produsenten:
Get the max with LINDEMANN! We have once again revised our highly successful and popular phono preamps.
In the version II the MC input is now unbalanced. Here we’re using the probably best amplification chip on the market. At only 0.6 W of current drain a noise level of -73 dBV is achieved with MC. An absolute top value! Moreover, setting the input impedance is now conveniently done on the rear of the Limetree. This makes our phono stage more universal and now also allows to connect older turntables with grounding via the RCA cable. Therefore a conversion of these models is no longer necessary. In particular the devices from Rega and Project can now be run in “plug and play“ mode.
Soundwise everything remains the same: not without reason the Limetree PHONO has already won numerous prizes and awards. A true “giant killer“.
The Limetree PHONO II is now available and will replace the previous version with immediate effect. The price remains unchanged.
The flood of excellent test reports of the Limetree PHONO simply won’t stop – and has reached a new peak with the latest award. The British AVTECH Media Award 2018/2019 for the best phono stage in ALL price categories does indeed speak volumes.
What did Jay Garett of Stereonet UK say again: "There would be no reason to be embarrassed by having a Limetree as your phono stage even if you owned a £10,000 turntable."
Link til test. https://lindemann-audio.de/wp-content/uploads/2018/12/AVT_18_Lindemann.pdf
U
utgatt25555
Den står vel i første delen av teksten!!
Focal
PRIS: 6.990,-
Endpoint Audio
Endpoint Audio sine annonser
Canor Virtus A3 - 8 utmerkelser på 1 år.
Canor Virtus A3 har mottatt en rekke utmerkelser og positive omtale, og jeg er enig. Dette er en suveren forsterker som gir ekstremt mye for pengene, og samtidig samler alt i en boks. Fire...
Canor Virtus I4S & Verto D4S
Canor Foundation: Når slovakisk rørtradisjon møter moderne transistorlyd *Verto D4S og Virtus I4S – to nye komponenter som markerer en ny epoke for Canor* En ny retning for et tradisjonsrikt...
Thales Elegance – Årets produkt i LP Magazine
  • 1
Thales Elegance – Årets produkt i LP Magazine. Micha Huber som eier HiFiction hvor man produserer Thales og EMT, er hele tiden fokusert på nyvinninger og hvordan man kan få max ut av analog...
Godt Nytt År!
Godt Nytt År!
2025 – Et fantastisk år for analog lyd hos Endpoint Audio 2025 ble et virkelig eksepsjonelt år for Endpoint Audio. Jeg opplevde et rekordår i salg av analogt utstyr – platespillere, pickuper...
Black Friday tilbud hos Endpoint.
Vi kjører Black Friday tilbud, og ønsker å fremheve spesielt varer fra Canor! -15 % på Performance og Premium Line, samt hele 20 % på Reference Line. Tilbudet gjelder fra i dag og frem til 14...
Canor A3 integrert alt-i-ett forsterker imponerer!
  • 1
Canor har siden lanseringen fått en rekke gode tester som samsvarer veldig godt med mine egne opplevelser - fantastisk lyd i en liten pakke for deg som ønsker et enklere oppsett uten en masse...
