I sommer frem til 14 august 2015 tilbyr Linn deg en unikt forsterker tilbud. Hvis kjøper en 4 kanals forsterker betaler du kun for en for en 2 kanals forsterker. Du vil få 2 kanaler gratis. Velg mellom en Majik 4100, Majik 5100, Majik 6100, Akurate 4200.
LINN Majik 6100 kr. 30 633 nå 25 068
LINN Majik 5100 kr. 27 845 nå kr. 22 2800
LINN Majik 4100 kr. 25 068 nå kr. 18 200
LINN Akurate 4200 kr. 50 950 nå kr. 34 500
Hvorfor oppgrader
LINN vil gi deg mulighetene til pumpe mer effekt inn i dine høyttalere. Muligheten til oppleve bi-amping, tri-amping eller aktivforsterkning av dine høyttalere.
Les under LINN sitt nyhetsbrev.
Why Add More Channels?
Multi-amp
Adding more channels to a passive speaker set-up is a great upgrade in itself, as well as bringing you a step closer to the nirvana of an Exakt system.
Bi-amping uses 2 channels per speaker and increases efficiency while reducing distortion, giving you a more musical performance. The more channels, the better the performance.
When you have enough amps to supply one channel per drive unit in your speakers, you can then drive them actively using Linn Aktiv cards, or for the ultimate upgrade, a Linn Exaktbox.
Aktiv
Most Linn speakers can be driven in Aktiv configuration, using a channel of amplification for each individual drive unit. This uses active crossovers (using Aktiv cards fitted inside the power amps) instead of the speakers' built-in passive crossovers and produces far less distortion than a passive set-up, letting you hear more of the music.
If you're going Aktiv, you can choose to claim your 2 free channels or take advantage of our ongoing free Aktiv card offer. If you need more than one amplifier, why not use both offers?*
Exakt
This is the ultimate upgrade for your system, bringing you closer than ever before to what was actually recorded in the studio.
Exakt takes the Aktiv principle even further by using one channel of amplification per drive unit, this time using aLinn Exaktbox to perform the crossover digitally.
This enables a whole host of performance-enhancing capabilities, including the elimination of phase and magnitude distortion and correction for drive unit variation.
Learn more about Exakt.
How Do I Choose My Best Upgrade Option?
Talk to your Linn Specialist today and arrange a demonstration to discover what Linn power amps can do for your system - hear the difference for yourself.
*Terms and conditions apply.Tilstand: NyType: Stereopakker
Generell info
Med forbehold for feil i annonsen.
Åpningstider
Tirsdag til fredag, kl 12 - 17
Torsdag, kl 12 - 18
Lørdag, kl 11 - 15
<font color="#04253C"><span style="font-family: arial">
