M2Tech Vaughan 384/32 reference USB DAC
ceroxol
Asker
Denne virker meget spennende... ;)
Vaughan 384/32 Reference USB DAC
The new M2Tech Vaughan is a high performance stereo D-to-A converter in a stylish brushed aluminum case and grilled front panel measuring 440 x 80 x 440 mm. Features of this high-end DAC include:
input sampling frequencies (kHz): 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384
resolution: up to 32 bits (USB), up to 24 bits (other inputs)
inputs: USB (B-type female), S/PDIF (2 x RCA and 2 x 75 Ohms BNC, dual AES for 384kHz), AES/EBU (2 x XLR dual AES for 384kHz), Toslink (2 x for dual AES), ST (2 x for dual AES), straight I2S, external master clock
outputs: single-ended on RCA and balanced on XRL, headphone on 6.35mm jack socket
supply: 115-230VAC, optional high current lythium battery with battery changer
controls and display: standby and select buttons, encoder, dual large matrix display to show locked frequency and selected input.
The M2Tech Vaughan will be our reference DAC and features 8 D/A IC's (4 per channel in mono mode). A digital dithered volume control will allow for using the Vaughan as a preamplifier. The headphone output is made with a discrete components amplifier.
M2Tech kommer også med en mindre modell Young 384/32 USB DAC. Noe info finnes bla. her. Ryktene sier en pris på 30-35kkr. Går ut ifra at dacene benytter en ESS chip. Er dog litt usikker på bruksområdet for 384/32..
Ellers skal det også komme en ny versjon av den vekjente HiFace:
hiFace Evo
USB-to-S/PDIF interface, based on the same technology as hiFace, but with many improvements. Hosted in a stylish brushed aluminum case (105 x 100 x 46mm), with B-type female USB connector.
Main features
input for external supply (7 to 11VDC)
input for external Master Clock (BNC with transformer)
2 x S/PDIF outputs (RCA and 75 Ohms BNC)
AES/EBU output with XLR connector and settable format (consumer and professional) by an internal jumper
Toslink output
ST output
direct I2S output with 3.3V interface.
Some customers complained because of the lack of sampling frequency encoding in the S/PDIF stream of the present hiFace. The new model will have this fixed, for full compliance with the standard.
All outputs (except I2S) are transformer-decoupled to avoid ground noise and EMI interference. Three LED's indicate power, data stream in input and external clock presence.
wizard
Priser
Hiface Evo ca 2400.,-
Young Dac - 7100,-
Vaughan Dac - 30500,-
tweakMan
ceroxol skrev:
hiface.com.au/index.php/news]her[/url]. Ryktene sier en pris på 30-35kkr. Går ut ifra at dacene benytter en ESS chip. Er dog litt usikker på bruksområdet for 384/32..
Zat is Dat... tape filer... (8x48...)
R
Roysen
Jeg synes også disse virket svært spennende. Er det en spesiell type hardware eller kun drivere/software som gjøre at disse kan støtte så stor oppløsing over USB når de fleste andre sliter med å levere noe over 24/96?
Roysen
LMC
Drøbak
tror det er driverne; det er ingen andre som har tatt seg bryet med å skrive drivere for hi-rez usb
det er tydeligvis ingen tekniske begrensninger så vidt jeg har forstått
bare kommersielle,som så ofte ellers
har nå sendt min HIFACE til JK i Irland for tilpasning for separat batteri-psu til klokker mm
så få vi se,men den spiller temmelig overbevisende i std også
neste blir vel å tappe I2S til BUFF II
Leif
ceroxol
Asker
wizard skrev:
Priser
Young Dac - 7100,-
Absolutt spennende dette. Ser at den også har dukket opp på hjemmesidene hos den danske forhandleren, Vassago Hi-Fi. Der ligger den på 30kDkk. Tror jeg tar meg en tur innom butikken i morgen og hører om når den kommer og muligheter for demo/hjemlån.
Ellers så virker også W4S dac'en meget spennende, til en langt rimeligere pris. Den er basert på ES9018 og sannsynligvis en hiFace, les om den her.
Leif
Buff II - er den basert på ES9018?
mvh,
Edit: ser at den er det her.
ceroxol
Asker
Fant en bilde av hiFace EVO
Til prisen på ca. 2400,- så må dette være en Weiss INT202-killer.. ;)
Ellers har jeg snakket med min lokale hifipusher, vassagohifi.com, regner med å ta Vaughan med på hjemlån når den kommer. Spennende å teste den opp mot Ayre..
Edit: lagt til et bilde til..
tore_v1
Finnes det en norsk forhandler for disse super-produktene? Når blir Evo lansert og tilgjengelig?
ceroxol
Asker
Jeg ville tatt kontakt med Vassago Hi-Fi i Odense, DK. Dette er en meget seriøs og hyggelig forhandler med særdeles gode priser, sender også til Norge.
Bare for å ha sagt det, så har jeg ingen forbindelse til denne forhandleren. Jeg bor selv i Odense og er en meget fornøyd kunde der. :) Jeg regner med å ta en tur innom butikken hans på fredag, kan spørre om han vet noen dato på Evo..
tweakMan
Innen for usb til digital (spdif, aes, toslink etc) er det ett par til man kan vite om.
StyleAudio Carat-T2 og A.R.T legato for å nevne noen. Legato er meeeeget bra på spdif fronten!!!
ceroxol
Asker
Nyhetsbrev fra den danske forhandleren ligger ute på Hifi4all, se her.
tore_v1
Hvordan gikk testingen, Ceroxol?
Jeg ser Ayre ligger på brukten nå..
Det virker som det bare er Vaughan som har asynkron USB, finnes det andre rimelige alternativer som gir asynkron konvertering til AES/EBU eller coax sp/dif?
ceroxol
Asker
He he.. Jeg har faktisk ikke testet den enda, har fri fra studier i DK og på sommerferie i norge for tiden. 8) Ayre på brukt'en er en del av et annet prosjekt, men dette skrinlegges sansynligvis. ::)
Litt usikker på hvordan de andre produktene til m2Tech fungerer. Hadde egentlig et inntrykk av at de var asynkrone, men i Fidelity #46 står det at hiFace ikke er det. Jeg antok også at Weiss' FW produkter var asynkrone, men det er de ikke, en interessant diskusjon om emnet kan leses her (fom. inlegget til G.Rankin).
Sånn jeg husker det så er definisjonen av asynkron at det brukes to FFCO (fixed frequency crystal oscillators, en for 44.1/88.2/176.4 og en for 48/96/192) så nærme dac som mulig og den valgte FFCO danner I2S til dac. Samtidig skal det være en feedback kontroll som sikrer at det kommer data, altså en slaving av pc/mac. EVO burde vel da være perfekt til formålet, da den kan klokkeslaves, men jeg kjenner ikke til hvordan den fungerer.. Ellers kommer Wavelengt med sin Wavelink USB -> s/pdif snart (den skal støtte 24/192 og er selvfølgelig asynkron, samt plug-and-play).
Det finnes også denne fra Halide designs som benytter den asynkrone Streamlenght koden (samme som Ayre lisensierer fra Wavelenght).
yasman
Grenland
Noe nytt her?
Blir det Halide eller Evo?
ceroxol
Asker
yasman skrev:
Noe nytt her?
Intet nytt. Har selv valgt å beholde Ayre, da den spiller latterlig bra og kan oppgraderes til 24/192, hvis jeg en dag finner musikk i dette formatet det er verdt å høre på. :) Jeg regner dog med at jeg tar med en Vaughan på hjemlån, da forhandler ligger i Odense - men dacen har enda ikke dukket opp, kun den rimeligere Young.
Hvis jeg skulle valgt usb->s/pdif i dag, så hadde jeg gått for Halide (24/96) eller Wavelenght sin WaveLink HS (24/192), begge benytter Wavelenght sin sin Streamlenght kode, som er plug-and-play i motsetning til m2Tech m.fl.
yasman
Grenland
[/quote]
Nyttig info!
Eneste grunnen til at jeg har vurdert M2Tech evo er at den kan koples mot ekstern klokke.
Kommer du til å teste den?
Ludo
Sandefjord
Kjøpte HiFace fra Vassago Hifi, bare god erfaring derfra! Kan han skaffe Evo?
ceroxol
Asker
yasman skrev:
Nyttig info!
Kommer ikke til å teste den da jeg nå bruker Ayre QB-9, som er en ren usb-dac. Det er endel diskusjon rundt m2Tech produkter og sammenlikninger med andre usb->s/pdif på Computeraudiophile.com, virker som flere foretrekker Wavelenght sin StreamLenght fremfor m2Tech, da sistnevnte visstnok gir en grå/kjedelig/flat lyd... HiFace er også testet og får ikke akkurat god kritikk. Mange som mener at de asynkrone plug-and-play løsningene (Wavelenght sin StreamLenght, brukt av bl.a. Ayre, Halide og selvfølgelig Wavelenght selv, samt dCS sin løsning også brukt av Arcam) spiller langt bedre enn de løsningene som krever drivere, hvorfor aner jeg ikke. Hvordan/hvis dette evt. vil endres når du klokkeslaver en Evo vet jeg heller ikke.
Litt OT her kanskje, men hvis du skal benytte iTunes og mac så vil jeg virkelig anbefale deg å teste Pure Music.. ;) Ellers virker også AyreWave meget spennende.
Var innom der for noen uker siden og da sa han at han hadde noen Evo liggende.. :)
yasman
Grenland
Hei, jeg tror ikke jeg kommer til å benytte mac. med mindre de har den beste pad'en.... tror nok jeg vil forsøke halide design sin. Om ikke vassago kjører 30 dg returrett og overbeviser meg om at klokke eksternt tar denne til andre høyder....
