Meridian Audio introduserer Tidal Hifi til Sooloos early 2015
Meridian Audio, the Cambridgeshire (UK)-based technology company, is delighted to announce its partnership with TIDAL, the high-resolution audio music streaming service. From early 2015, TIDAL will be available on Meridian’s Sooloos digital media system, enabling seamless streaming of TIDAL’s extensive library of CD quality music.
TIDAL will also be integral to Meridian MQA demonstrations at the International Consumer Show (CES), streaming MQA music files via a Meridian Sooloos digital media system. Meridian will be based at The Venetian Hotel in Suite 30-335 and the exclusive demonstrations will allow listeners to experience the full extent of the new TIDAL integration. The TIDAL integration brings a lossless audio streaming experience to Meridian Sooloos system owners old and new, all of whom can now enjoy unlimited access to over 25 million tracks.
Commenting on the announcement, John Buchanan, CEO at Meridian Audio said, “The partnership with TIDAL is significant for a company such as Meridian which prides itself in delivering a super-quality digital signal throughout the path from the studio to the home, using advanced digital signal processing technologies".
Mere nyheter kommer fortløpende fra CES.
PerS
MDS Norway AS
Meridian Audio LTD. importør
O.P.K.
Hei ! Ville det ikke være mulig å presentere denne informasjonen om Meridian på norsk - eller har dere store problemer med det ??
Mvh O.P.K
pers1
Asker
Bruker TRANSLATED by Google enklere kan det vel ikke gjøres ; )
Meridian Audio, Cambridgeshire (UK ) -basert teknologiselskap , er glad for å annonsere sitt samarbeid med TIDAL, den høyoppløste lyd musikkstreamingtjeneste . Fra tidlig 2015 vil TIDAL være tilgjengelig på Meridian Sooloos digitale medier system , slik at sømløs streaming av TIDAL's omfattende bibliotek av CD-kvalitet musikk .
TIDAL vil også være en integrert del av Meridian's MQA demonstrasjoner på International Consumer Show ( CES ) , streaming MQA musikkfiler via ett Meridian Sooloos digitale medie system . Meridian vil være basert på The Venetian Hotel i Suite 30-335 og de eksklusive demonstrasjoner vil tillate lyttere til å oppleve den fulle omfanget av nye TIDAL's integrering. TIDAL's integrering bringer en tapsfri audio streaming erfaring til Meridian Sooloos systemeiere gamle og nye , som alle kan nå nyte ubegrenset tilgang til mer enn 25 millioner låter .
I en kommentar til kunngjøringen, John Buchanan , administrerende direktør i Meridian Audio sa: " Samarbeidet med TIDAL er viktig for et selskap som Meridian som er stolt i å levere en super - kvalitet digitalt signal hele veien fra studio til hjemmet, ved hjelp av avansert digital signalbehandlings teknologi".
O.P.K.
Hei igjen ! Skjønner jo nå hvorfor dere sendte denne informasjonen på engelsk ! Den norske oversettelsen dere presenterer er til dels meget dårlig språklig !! Særlig gjelder dette siste avsnittet. Kanskje dere burde konsultere noen som behersker
engelsk litt bedre, og som kan uttrykke dette litt bedre på norsk. Dessverre er nok dette fenomenet svært vanlig i bransjen!
For ordens skyld nevner jeg at jeg har Master i engelsk språk. ( Men heri ligger det absolutt ingen arroganse.)
Med vennlig hilsen
O.P.K.
skorob
Brumunddal
Med vennlig hilsen
O.P.K.
WTF! Da fikk du iallefall frem at du har master i engelsk språk (og godt var vel det!). Hva var det du egentlig lurte på? Hadde det kommet ifra et "bondeknøl" som ikke skjønte et skarva ord engelsk så hadde det vært greit.. men dette blir litt arrogant ifra din side for min del...
Tittentei
What are this?
Only in Hifisentralen on Norway! ;D
pers1
Asker
Med vennlig hilsen
O.P.K.
Beklager OTP, men jeg trodde utifra måte du spurte på at du ville ha dette oversatt - da engelsk kanskje ikke er din cup of tea. Det er faktisk brukere som ikke kan engelsk så godt. Derfor brukte jeg Google Translate. Lykke til videre
PerS
Hvis vi er ferdige med den språklige digresjonen kan det være på sin plass å gratulere både Wimp/Tidal og Meridian med dette samarbeidet. Det er et solid fotfeste i den seriøse høykvalitets-enden av markedet, og ser ut til å være en perfekt match mht posisjonering av respektive merker.
ottone
Spennende.
Betyr dette at TIDAL vil tilby streaming i MQA format?
Såvidt jeg forstår er dette et nytt format/codec fra Meridian ekslusivt for dem. Da er det naturlig å spørre om de har en plan for å dele/spre dette.
Jeg har ikke satt meg inn i teknikken, men er dette (MQA) noe liknende det som Naxos bruker i sin nye HD streaming?
pers1
Asker
Spennende.
Ja leser man gjennom linjene så stemmer det, det er opp til Plateselskapene i gi Tidal den rettigheten til å streame deres MQA Filer. Fordelen her er at både artister, produsenter og platesselskaper er med.
Meridian står bak bl.a MLP (Meridian Lossless Packing) som blir brukt i DVD-Audio , MLP er også i Dolby True HD og Meridian er også bak med Dolby på selve codecen til Dolby Atmos.
Det som har vært det største problemet med filer størren enn 96Khz er at de tar my plass og skaper problemer ved streaming (krever høy båndbredde).
Utfordringen er at i eks. en 768Khz / 24 bit fil er at musikk og intet signal/stillhet tar like stor plass.
Bare se her på et 96Khz Signal.
Jo høyre en kommer opp i Khz desto mindre plass tar signalet og desto større del innholder ingen ting, så på en 768Khz/24Bit fil så la oss si at total størrelsen er 14GB, da er ca 11GB stillhet under -80dB.
Ved å pakke inn alt over 96KHZ å det legge det ned/Pakke sammen (Se merket Encapsulation) så vil filen ikke ta noe plass. kan streames mellom 1,5MB/s -2Mb/s for en 768KHZ /24Bits fil!
NAXOS er kun basert på brukeres Internett linje, samme som Netflix. Hastighet = kvalitet.
"The adaptive streaming system monitors the bandwidth available on the user’s network connection, and adjusts the quality of the
feed from the ClassicsOnline HD•LL servers to ensure continuous playback without buffering problems."
Mere info her også:
http://www.hifisentralen.no/forumet...-never-same-again-mqa-meridian-audio-ltd.html
PerS
pers1
pers1 sine annonser
Meridian Audio MQA Software Announcement
  • 6
MQA Ltd have now issued full public release specification decoding libraries to their partners, which as you know include Meridian Audio. The Meridian Engineering team is currently working on...
Meridian Audio LTD. introduserer 808V6 og 818V3
  • 1
808V6 SIGNATUR REFERANSE CD-SPILLER / 818v3 CORE AUDIO REFERANSE PRE-AMPLIFIER Meridian har lenge vært assosiert med avspilling av høyoppløste lyd- og videokilder. I daghar vi bare sett starten...
Meridian Audio Sooloos: Hva har skjedd og hva har vi i vente fremover?
Sooloos I 2009 la vi til streaming-tjenester, men måtte vente til 2014 for å tilby lossless lyd egnet som et alternativ til fysiske medier eller nedlasting. TIDAL HIFI er det siste som nå er...
Meridian Audio LTD. *gir Tidal Hifi 3 mnd.
  • 2
Meridian Audio LTD. gir kunder *gratis 3 mnd. Tidal Hifi *I sammarbeid med Tidal, High fidelity Streaming tjenesten, gir nå Meridian Audio LTD. 3 mnd (90 dager) gratis Tidal Hifi til alle som...
Meridian EXPLORER 2 TIDAL HIFI Edition !This product is MQA-ready!
  • 19
Explorer₂ Tidal HIFI Edition inkluderer 3 mnd voucher til TIDAL HIFI til KUN 2.500,- ( Oppkrav legges til 300,-) BESTILL HER The Meridian Experience in your hand...
Meridian Audio LTD. introduserer Explorer2 med MQA støtte.
Explorer2pris er 2.500,- inkl 3.mnd med "Julegave". Kun igjen 20 på lager. Dersom det skal sendes i oppkrav kommer det 300,- i tillegg. Explorer2 Meridian’s Explorer2 is a portable, compact and...
