Meridian EXPLORER 2 TIDAL HIFI Edition !This product is MQA-ready!
Explorer₂ Tidal HIFI Edition inkluderer 3 mnd voucher til TIDAL HIFI til KUN 2.500,- ( Oppkrav legges til 300,-)
BESTILL HER
The Meridian Experience in your hand
Explorer₂ replaces a computer’s audio outputs with a USB-powered DAC (Digital to Analogue Converter) featuring over 30 years of Meridian’s digital expertise in high-quality audio circuitry. Explorer₂ includes digital clocking derived from Meridian’s award-winning Reference Series components, for precise timing of digital signals.
Meridian has paid as much attention to the analog circuitry as the digital. Explorer₂ features a pure analog volume control with a powerful headphone amplifier and a line output. This provides sophisticated volume control with an extended range of 100dB – ideal for sensitive headphones. Whatever you listen to, Explorer₂ makes it sound its best.
Meridian Resolution Enhancement
Explorer2 includes significantly more DSP power than its predecessor, allowing the full suite of Meridian audio enhancement technologies to be included, which was not previously possible. Thus the Explorer2 upsamples all input signal to 176.4/192kHz (4x standard sample rates) – 4x streams are played at full resolution with no downsampling. It includes Meridian’s proprietary Apodising upsampling filter, which minimises pre-ringing for a clearer, more transparent sound, while at the same time removing digital filter artefacts from earlier digital recordings, audibly improving overall smoothness of sound and stereo imaging.
The Explorer2 also features Meridian’s approach to noise-shaping. This moves noise out of the audio band, increasing the audible signal to noise ratio.
Superior clocking
Explorer2 features full audio performance at sample rates up to 192kHz, 24-bit resolution. It doesn’t downsample 176.4/192 kHz signals to lower levels, delivering instead the full bandwidth of the original. Explorer2 is completely asynchronous – it does not rely on the computer’s clock for timing. Instead, it uses precision on-board low-jitter crystal oscillators for the base sample rates. These were developed from those used in Meridian’s premium home entertainment systems.
These oscillators provide the master clocking for the entire playback system, and eliminate all USB interface jitter. ‘Isochronous’ transfer ensures maximum bandwidth and low latency. This is particularly significant, for example, when playing videos on the computer, for which audio and video must remain in sync.
Dual auto-sensing outputs
Two outputs are provided: one for headphones and the other a line output for connection to a hi-fi system. Explorer2 automatically senses which is in use and deactivates the heaphone amplifier when the line output is connected, reducing noise.
The 3.5mm headphone socket delivers up to 130mW of high-quality audio – capable of driving plenty of level for even low-efficiency headphones.
The volume is controlled from the host computer. The volume control is an advanced design with an extended range of 0 to –100dB. This level of variability suits all kinds of headphones including the most sensitive.
The second 3.5mm socket provides a fixed-level analogue (2v RMS) output for connection to an external audio system. This is connected directly to the DAC for bit-precise performance. It delivers a fixed, full-level signal with no volume control. This is exactly what you need for an audio system: driving full level ensures both maximum signal to noise ratio and maximum use of digital resolution right through to the audio system’s own volume control, which controls the level for all sources in the system.
A Higher Class of DAC
Explorer2 is a USB Class 2 device that works with the newer (2009) USB2 specification. This supports a transmission speed of 480Mb/s – 40 times faster than Class 1 – allowing Explorer2 to play 192kHz audio streams. You can also plug it into any available USB port – including a hub. You’re not required to plug it direct into the computer.
Whether replaying an mp3 or a high-resolution lossless file, Explorer2 will make any content sound its best. It delivers a level of audio quality essentially limited solely by the source material.
Master Quality Authenticated (MQA)
Three indicators show the status of the Explorer2. The LED furthest from the headphone socket illuminates white to indicate that the unit is operating (and playing PCM at 1x standard sample rates – 44.1/48kHz). The middle LED (2x standard rate) indicates 88.2/96kHz operation and the third LED 176.4/192kHz operation (4x).Explorer2 includes a powerful decoder and audio renderer for Meridian’s exclusive ‘Master Quality Authenticated’ system. This ensures that MQA-encoded lossless audio files and streams sound exactly like the source. The 1x LED glows green to indicate that the unit is decoding and playing an MQA stream or file, and that the sound is identical to that of the source material. It glows blue to indicate that the Explorer2 is playing an MQA Studio file – one based on a new, exclusively sourced, artist/producer-approved studio master. In all cases you hear exactly the sound the production team intended.
DOWNLOAD BROCHURE
FEATURES:
MASTER QUALITY AUTHENTICATED (MQA)
Sourced from the original studio master recording as approved by the creative team, MQA combines an advanced new digital sampling technology that captures extremely high frequency timing and detail in an audio signal with an equally novel system to “encapsulate” that data into a form for delivery using any lossless file format or streaming. The listener’s decoder reconstructs the entire original signal, bringing up an indicator confirming that what they are hearing is exactly the same as the original master. Without the decoder, the listener enjoys CD quality reproduction. Its most advanced form, “MQA Studio”, uses the technology in the studio to generate an even higher quality master recording as the source.
MERIDIAN APODISING FILTER
Filters are critical in digital audio. Commonly they introduce distortion and harshness because of "pre-ringing". Early digital recordings suffer from harshness too, due to primitive filters. After painstaking research, Meridian developed a special filter that avoids pre-ringing, so it can be steeper, cleaning up the effects of early filters. The result: a better, cleaner sound from recordings old and new.
SPECIFICATION:
Inputs
• USB mini type B.
Outputs
• 3.5mm analogue line out, fixed 2v RMS.
• 3.5mm headphone jack with variable-level output, impedance 0.47Ω.
Construction
• Extruded Aluminium shell with moulded plastic endcaps and rubber foot.
Power
• USB, nominal 5V at <500mA.
Processing
• Dual Tile XMOS DSP with 16 cores and 1000 MIPS
Indicators
• Three white LEDs (1x, 2x, 4x) show connected state and audio stream rate. 1x LED glows white for PCM, green to indicate MQA playback and blue to indicate MQA Studio playback. MQA indications will not show if the bitstream is altered in any way.
Implementation
• USB audio class compliant 2.0 HS 480Mb/s bandwidth.
• Asynchronous: device is the clock source for high quality.
• Firmware upgrade via USB.
• Windows drivers provided, no drivers required for Macintosh OS X or Linux.
• Analogue volume control for headphone output, controlled from PC, control law modified to match connected OS.
OS requirements
• Macintosh OS X 10.6.4 (Snow Leopard) or later
• Windows XP SP3, Windows 7 SP1, Windows 8 or later
• Linux kernel 2.6.37 or later and ALSA version 1.0.32 or greater
Dimensions (approx)
102 x 32 x 18mm (4.0 x 1.25 x 0.7in).
Weight (approx)
50g (1.76oz).
Meridian launch MQA at The Shard
Riktig God Jul
Per S
MDS Norway AS
Meridian Audio LTD. Importør
tlf 48 23 43 20
janfrt
Pt. Høvik
Hei,
i et forsøk på å gjøre det enkelt:
jeg har en Mac og streamer via en Dac fra Spotify, Wimp og Qobuz. Hvordan kan Tidal forbedre dette?
pers1
Asker
Introducing the first music streaming service that combines the best High Fidelity sound quality, High Definition music videos and expertly Curated Editorial.Currently access in your country is limited to HiFi Partner voucher holders only.
Tidal HIFI og Wimp HIFI er like, men TIDAL er lanseringen utenfor Scandinavia akkurat nå.
Når det gjelder Meridian Audio LTD. er det spennende nyheter i vente på CES i Las Vegas i Januar og utover i 2015
janfrt
Pt. Høvik
Javel, nei, ja? Kan du forklare? Vi kan ikke vente til CES-messen. Du må jo være i besittelse av hemmeligheten med bedre lyd. Bilde er ikke interessant. Fint hvis du redegjør. Foreløpig er jeg et stort spørsmålstegn. Og svært nysgjerrig. I all vennlighet.
pers1
Asker
Jeg kan ikke gi deg noe mere info om Tidal Hifi, Jeg er Meridian Audio Audio importør. Meridian er en av samarbeidspartnerene til Tidal. P.g.a dette er vi en av få som via Explorer2 kan tilby Tidal HiFI.
Når det gjelder CES 2015 og annen innformasjon om Meridian er vi som importør under NDA.
GunnarS
Et lite utdrag digitalaudioreview.net :
"Lossless streaming has been available in certain parts of Europe for some time now. Qobuz Hifi currently services Austria, Belgium, Germany, Ireland, Luxembourg, Netherlands, Switzerland, United Kingdom with CD-quality audio for 20GBP/month but its recent financial woes have no doubt slowed its roll out across the pond.
Norway’s WiMP has endured no such funding issues. Launched in 2013, its ‘WiMP Hifi’ lossless streaming service meets demand in Denmark, Germany, Norway, Poland and Sweden for €19.99/month whilst the rest of the world either gets with a VPN or looks on in envy…until now.
This week WiMP re-brands itself as Tidal for its UK and USA launch. Deezer’s Sonos-only partnership aside, Tidal is the first company to offer CD-quality music streaming Stateside; that’s 16-bit/44.1kHz FLAC for the more tech-savvy readers among you."
Vil dette si at Tidal bare er et nytt navn for Wimp for å få lansert seg i USA og GB.
GunnarS
mteinum
Øya
Det virker slik. Det er ikke mulig pt. å få Tidal i Norge, så den voucheren er ikke mye verd.
edit:
Vent nå litt, her var nytt siden sist:
TIDAL � High Fidelity Music Streaming
Det er Aspiro som står bak både Tidal og WiMP
http://www.aspiro.com/
mteinum
Øya
Hva er prisen på Tidal etter de 3mnd er brukt opp?
MusicInt2
Fersking
Hvor finner jeg riktig driver for Windows 8 Explorer 2. Jeg finner ikk den under meridian-audio.com.
MusicInt2
Fersking
Beklager fant den ved meridian hjemmesiden
MusicInt2
Fersking
Noen kommentarer etter min første dag med Meridian Explorer 2:
1)Driver skal hentes ved Meridian hjemme side, jeg pleier å søke fri på net da jeg trenger driver etter navn, det var feil her, da får du lureri lang på vei, og noen prøver å laste reklamer med nedlasting.
2)Lyden som er saker her, bare kommentere at jeg er imponert om lyd kvalitet fra så liten dac som denne. Selve format MQA er ikke tilgjengelig enda, så lenge jeg vet, jeg bare brukte de vannlig formatter fra iTunes, Spotify,osv. Til å med youtube video som pleier å være flat på stereo mitt med Krell/Martin Logan, var veldig behagelig å lytte til.
Min konklusjon er at DAC teknologi utvikle seg i et tempo som ingen andre component i stereo.
Kjendis
Norway
Så sant Meridian explorer er bedre enn denne: | NOMONO Densen: 24/96 fabeldac.
så kan det være interessant å slå til. :cool:
pers1
Asker
DAC du sikter til er en til å bygge inn i Densen integrerte eller forforsterker. Explorer 2 har USB inn og analog ut ment som et lydkort til Mac eller PC med mulighet for tilkobling opp til de mest ekstreme hodetelefoner eller til RCA inn på eksisterende anlegg.
Kan anbefales for å si det sånn
PerS
pers1
Asker
Da er vi over på nytt år, p.g.a kraftig svekkelse av Norske kronen mot Engelske Pund må prisene på Meridian Produkter settes opp :(
Explorer₂ Tidal HIFI Edition inkluderer 3 mnd voucher til TIDAL HIFI er justert til 2.985,-
BESTILL HER
bluesbreaker
Hundeeier
Blåskogen
Det står litt om Meridian/ MQA i siste nummer av svenske HIFI&Musik.
Redaktøren er relativt begeistret og lover at temaet skal følges opp.
Kjendis
Norway
Min første meridian var en Meridian 506 cd spiller som spilte musikk så ørene flagret sammen med Krell Kav 300i mk2 og audiovektor M2 som nok er en av de beste anleggene jeg har hatt...i 1998. Men det måtte gå som det måtte gå. Innbyttesyken gjorde at forsterker og høyttalere ble byttet inn i noe annet og an laang hi-fi karusel sammen med dårlig studentøkonomi førte til at jeg satt igjenn med en rar følelse av at jeg hadde tabbet meg ut.
Nyttårsaften i år.....:confused: bestilte jeg Meridian Explorer 2. Med medfølgende usb kabel og en minijack to usb jeg fikk av Tor på Lyric, har et førsteinntrykk dannet seg. Denne bittelille dacen funker kjempefint. Det første som slår meg er at man kan høre på poppmusikk også og ikke bare Kari Bremnes. Den har rytmisk forståelse og den har en elegant topp Jaaa!:D
Hodetelefonutgang testet jeg også med Bose around ear, låt som ei kule.
pers1
Asker
De som har fått seg Explorer 2 er meget fornøyde :) Å mye skjer fremover som tar den til enda nye høyder.
Vi ser fremover til mye spennende nyheter i 2015.
PerS
MDS Norway AS
pers1
pers1 sine annonser
Meridian Audio MQA Software Announcement
  • 6
MQA Ltd have now issued full public release specification decoding libraries to their partners, which as you know include Meridian Audio. The Meridian Engineering team is currently working on...
Meridian Audio LTD. introduserer 808V6 og 818V3
  • 1
808V6 SIGNATUR REFERANSE CD-SPILLER / 818v3 CORE AUDIO REFERANSE PRE-AMPLIFIER Meridian har lenge vært assosiert med avspilling av høyoppløste lyd- og videokilder. I daghar vi bare sett starten...
Meridian Audio Sooloos: Hva har skjedd og hva har vi i vente fremover?
Sooloos I 2009 la vi til streaming-tjenester, men måtte vente til 2014 for å tilby lossless lyd egnet som et alternativ til fysiske medier eller nedlasting. TIDAL HIFI er det siste som nå er...
Meridian Audio LTD. *gir Tidal Hifi 3 mnd.
  • 2
Meridian Audio LTD. gir kunder *gratis 3 mnd. Tidal Hifi *I sammarbeid med Tidal, High fidelity Streaming tjenesten, gir nå Meridian Audio LTD. 3 mnd (90 dager) gratis Tidal Hifi til alle som...
Meridian Audio introduserer Tidal Hifi til Sooloos early 2015
  • 11
Meridian Audio, the Cambridgeshire (UK)-based technology company, is delighted to announce its partnership with TIDAL, the high-resolution audio music streaming service. From early 2015, TIDAL...
Meridian Audio LTD. introduserer Explorer2 med MQA støtte.
Explorer2pris er 2.500,- inkl 3.mnd med "Julegave". Kun igjen 20 på lager. Dersom det skal sendes i oppkrav kommer det 300,- i tillegg. Explorer2 Meridian’s Explorer2 is a portable, compact and...
