Ny volum kontroll-pot?
Har forsket endel på forskjellige potmeter, attenuatorer, TVC etc.
Grunnen er at jeg ikke er sikker på hva jeg skal gå for til preampen. Har tkd cp2511 idag som er glimrende, men vurderer en motorisert versjon av denne slik at remote kontroll på volum er en mulighet.
Evt. tkd sin stepped attenuator (41 steps) - skal være kjempebra og koster 250usd fra www.percyaudio.com
I min søken kom jeg over denne: (Ser snaisen ut)
http://www.tribute-audio.nl/
Gå inn på news.
Inductive Volume Control
The TRIBUTE volume control is an inductive control, which means that unlike "normal" volume controls (which use some sort of resistive element) an inductive element is used.
The main advantage of using an inductive element is the low DC resistance of the windings.
A standard resistive volume control is 10k, 50k or 100k. The Tribute inductive volume control has a DC resistance of only 33 ohms, which results in a more transparent and dynamic sound, especially at low volume sinductive volume controlettings.
The AC resistance can be calculated and is frequency dependent. The Tribute volume control has an AC resistance of about 20k at 20Hz and 1Mohm at 1kHz.
Most inductive volume controls are wound as transformers with primary and secondary windings.
In contrast, to reach the ultimate in dynamics, bandwidth and transparency, the Tribute volume control is wound as an autotransformer, which means that a single, tapped coil is used.
The pictures show that the volume control is a complete stereo control by mounting the coils on a 24 positions ELMA switch, also to keep connections as short as possible.
Mono controls are also available.
Further specifications:
* inductance 150 Hy's;
* DC resistance 33 ohms;
* maximum input 6 VRMS at 20 Hz;
* width / height 5cm (2 inches);
* required mounting depth 10 cm (4 inches) for the stereo control;
* required mounting depth 5,5 cm (2,2 inches) for the mono control.
Kommentarer?
Erland
Denne tribute-saken ser da teknisk sett ut som en "mini-TVC".
Siden denne kommer som en "ferdig pakke" som du slipper å lodde, er det helt genialt.
Vær så snill og kjøp den og fortell oss hvordan den funker.
Personlig har jeg ikke brukt for flere, men dette er jo et høyaktuelt tema for tiden.
VegardW
Kolsås
Enig med Erland.Noen som ser ulemper/svakheter ut ifra specs?
slarssen
Den TVCn så jo svært intressan ut! Løp å kjøp! Tribute er kjent for å ha svært høy kvalitet! Det ligger et lite shoot-out av det som kanskje var en tidlig utgave av denne på www.vt52.com under "DIY corner" og "Projects" og "TVC shoot-out"
Den eneste bakdelen er vel muligens at Tribute er ganske kjent for svært lange leveringstider (før i allefall, det kan h forbedret seg de siste årene).
- Stig
jbc
Odd
Jeg nevnte på mail at jeg hadde en TVC liggende ubrukt. Om du skulle finne ut at du vil oppgradere utgangstrafoene i AN preen kan jeg være åpen for et bytte av de gamle mot min TVC. :)
Jørgen
VegardW
Kolsås
Sendte en mail til tribute.Ikke den kjappeste til å svare, men hyggelig.Leveringstiden er ca 3 uker.prisen er 365 euro.transport i tillegg:Da får man komplette kontroller:Integerert med 24 pos elma swithces.Prisen er den samme for 2x mono og 1x stereo.
whistler
bambadoo skrev:
Kom over en ny attenuator for de som er interessert i slik.
48 steps - ladder type
http://www.khozmo.com/index.html
Prisen skal ligge på 99$ for stereoversjonen.
Fint bygget opp er de ihvertfall.
Den var veeeldig sexy! 8)
Jeg har også en slik ALPS RK-50 liggende som skal inn i en preamp... én eller annen gang. ;)
Diy Duke
Shit det ser godt ud. Er det en attentuator ? Er det rigtigt det har 4 dæk ? Hvor kan det købes ?
whistler
Gjør et Google-søk på "Lightspeed attenuator".
Spennende for å si det mildt! Hvis det virkelig funker så bra som mange hevder, er det jo en liten revolusjon. 8)
wilbur-x
Sjekk: SKA-audio OptiVol
Disse "frikobler" akkurat som en trafo, men uten hysteresetap.
Med predefinert utgangsimpedans skulle disse være mer enn intr. for ICE-forsterkere.
whistler
Tror dette er en forenklet og dårligere variant enn Lightspeed-versjonen.
OptiVol er diskutert på en av Lightspeed-trådene på diyaudio.com.
Diy Duke
Jeg syntes alt fra Gregg Ball er junk.
wilbur-x
Takker for info, skal sjekke tråden på diy.com.
Lightspeed link:
http://diyaudioprojects.com/Solid/DIY-Lightspeed-Passive-Attenuator/
kjetinho
Ikkje meininga å stele tråden, men den virkar jo litt dau no uansett.
I min Copland CTA 305 har eg ALPS RK2711 pot. Nokon som kjenner til dette og kan gjette litt på kva som må til for å få ein merkbar betring i kvaliteten?
Det frå khozmo virka jo litt interessant.
PS: bambadoo, gje meg ein lyd viss eg skal starte eigen tråd.
Diy Duke
Først må du melde ud i hvilken retning du ønsker din lyd skal bevæge sig.
kjetinho
Kunne godt tenke meg endå opnare lyd, med god kropp og fylde og mykje indre detaljar. Seier ikkje nei takk til endå meir dynamikk og tilstedeværelse heller.
Bare fortsett her du :)
Det potmeteret du har. Det har vel en motor for fjernbetjening. Er dette et "must" eller kan du klare deg uten?
Har god erfaring med tkd sine potmeter. cp2511 tror jeg de heter? Er ikke sikker på navnet.
kjetinho
Takkar!
Fjernbetjening ikkje eit must, men kjekt å ha. Hugsar du prisen på det? Eg har prøvd å søke, men finn ikkje forhandlar..
Diy Duke
Alps giver krop og fylde men camouflerer mellemtone og diskant. TKD er bedre men en Seiden omskifter med Takman modstande giver meget mere dynamik.
kjetinho
Diy Duke
Prøv den sidste den ser god ud og de SMD modstande KAN være udmærkede. Den første GLASSHOUSE omskifter synes jeg ikke om. Den ødelægger de ellers gode Takman modstandes gode egenskaber.
andreas
Har også hørt, fra en som var forhandler selv, at de blåhvite kinaproduserte venderne ikke holder særlig høy kvalitet.
Har en sånn billig kinesisk med smd motstander liggende. Har også et noble potmeter i kassen.
TKD var bedre enn noble i min preamp. Noble potmeteret var bedre enn alps blue.
Men her
http://www.acoustic-dimension.com/resistors/TKD.htm
Finner du et utmerket tkd pot med motor. Er du heldig så er det drop inn for det du allerede har i preampen.
whistler
Men her
Har et slikt TDK motorpot liggende og kan bekrefte at det funker fint med en ALPS motorstyring jeg testet det med.
Så da kan du spørre whistler fint om han er villig til å selge det tkd potmeteret :)
Du kommer ikke til å angre på det..
PS! Mye snaisent du i skuffen din whistler.
Diy Duke
Eller den frå http://www.khozmo.com/index.html 99$ Resistors: 1% 100ppm , 1/10W, low noise, non-inductive, metal film. Står ikkje kva fabrikat det er på motstandane..
[/quote]
Tror det er Panasonic der laver dem. Tilsvarende sidder i mine Holton Amps og det ændrer ikke engang noget at skifte dem til de bedste på markedet : Charcroft til ca 200 kr stk.
whistler
He, he... tror nok jeg har lyst til å beholde det... i tilfelle jeg får brukt for det en gang. ;)
Et bra pot forøvrig!
Jeg har det på bildet under også... i tilfelle jeg får bruk for det en gang. ;D
whistler
Jojo det ser godt ! Endnu bedre tror jeg den dyreste Seiden omskifter er.
Ja, det er jeg nok enig i. Jeg har selv hatt den dyreste Seiden venderen. Det er et smykke!
Ellers det jo mange som har bygget opp attenuatorer med Shallco vendere. Her er muligens selve kontaktarrangementet bedre enn det vi finner på Seiden.
Jeg har bestilt et par sett av de matchede optokoblerene som brukes i Lightspeed-attenuatoren. Er spent på om dette virker så godt som rapportene sier. Denne kan enklet fjernstyres med en 100k ALPS-løsning. Kvaliteten på potet spiller ingen rolle, siden potet kun brukes til å styre spenningen til optokoblerene! (For de som ikke kjenner prinsippet, så er det kun to lysfølsomme motstander i signalveien (ingen kontakter!). Verdien på disse endres ved å endre spenningen til lysdiodene som belyser motstandene. Dermed endres også signalnivået.)
243 sider på www.diyaudio.com!
http://www.diyaudio.com/forums/showthread.php?t=80194&page=242
Diy Duke
Spændende -- venter på dine erfaringer, selv er jeg MEGET skeptisk.
kjetinho
Men her
Så eg kan kjøpe det utan motor og montere på alps-motoren, eller betyr det at det med motor kan styrast i min pre?
