Nye fantastiske hornhøyttalere på veg fra dc10audio.
THE KABUKI OHAKU
Available april 2014.
While keeping the proven dc10audio innovations intact, we have re-created the horn loudspeaker all over again with totally new horn configuration. The Kabuki Ohaku includes upgraded drivers and modified RAAL ribbon tweeter, wire, and crossover components.
SPECIFICATIONS:
• dc10audio's unique horn loading (all drivers port through the horn)
• 12-inch full-range driver with AlNiCo motor with +/-30dB adjustable output
• RAAL ribbon tweeter loaded in the horn
• Massive 12-inch bass driver with zero interfering grills
• Exclusive back-mounted tonewood external & internal resonators
• Solid core 6N cryo-copper in cotton wiring with second run in pure silver
• Minimal crossover, no circuit boards
• Beeswax paper stacked cryo-copper foil capacitors
• Exclusive horn blades in heirloom woods (See wood choices)
• Frequency response: 18 Hz-80,000 Hz (+/-2dB)
• Sensitivity: estimated 97 dB
• Impedance: 8 ohms
• Overall size: 53" high x 16-19" wide x 22.5" deep each
• Weight: 170 lbs each
Price for pair: $24,500
dc10audio horn loudspeakers: Stand-mount & floor-standing
LEVERES I NORGE AV:
HagtoAudio
https://www.facebook.com/pages/Hagto-Audio/422954197779681?ref=hl
THE KABUKI OHAKU
SPECIFICATIONS:
• Impedance: 8 ohms
LEVERES I NORGE AV:
HagtoAudio
