Nyhet - YBA nå i Norge !
  • Sound of Heaven har blitt importør og har gleden av å kunne gjenintrodusere YBA, på det Norske markedet.
    Dette Franske high end merket som Yves Bernard Andre grunnla i 1981 har en portefølje på 4 forskjellige
    serier , Heritage , Genesis, Passion og Signature. Hvor de kan tilby både integrert forsterker, forforsterker, effekt forsterker, phono forsterker og cd spiller til MEGET konkurranse dyktige priser i sine respektive klasser. Vi kommer i første omgang til å satse på Heritage og Genesis serien.
    Vi søker referanse kunder på YBA.
    Ta kontakt for info.
    JWK Audio/Sound of heaven
    Tlf:+47 464 29 861
    E-mail: kontakt@soundofheaven.as
    Hjemmeside: www.soundofheaven.as
    sound of heaven
    Yves Bernard André – the Founder and Designer
    I have been designing audio products since 1971 and hold several patents.
    My company operations commenced in 1981 with just one amplifier and one preamplifier.
    YBA products have always been and still remain my absolute passion and I believe this passion is evident in the design of every product bearing the YBA name.
    YBA diagrams are the elegance of simplicity.
    They consist of a differential input of a current source transistor, two complementary transistors in each of the two stages of voltage gain A class, followed by output transistors (2 to 6), for a total of 8 to 12 transistors per channel.
    All transistors used are selected for their auditory qualities. The difference is evident due to the selection of low noise transistors. The drivers have a very wide bandwidth (40 Mhz) and the output transistors are high current (30 amps).
    My designs rely on the following criteria
    Electronic components without compromise
    Great care is taken in choosing not only the value of components used in the assembly, but also the type of components and even the manufacturer of these components. Most of them – such as connectors, transformers, cables, the solder and resistors are specially manufactured for YBA in France.
    Simplicity and reliability in the design
    This is the heart of the products. Special care is taken to ensure that the devices used are devices with high efficiency and minimal heat dissipation.
    Innovation
    Indium is used in particular and specific places in order to decrease the variations of temperature and to improve conductivity. YBA audio products are truly innovative, based on “Memory Free Design Technology” to avoid thermal vibration, electromagnetic and electrostatic distortions.
    BritFi
    Tilbake i Oslo, igjen.
    Som eier og daglig bruker av Heritage A100 og ut fra dette blitt fan av merket: Gratulerer, merket fortjener virkelig å bli hørt her på berget også!
    Sjeldent blitt så gledelig overrasket over et produkts kvaliteter.
    hvalross
    Finner ikke disse YBA produktene på ders Hjemmeside .
    sound of heaven
    Hei Hvalross
    YBA produktene med priser vil bli å finne på våres hjemmeside snart.
    YBA vil bli MEGET hyggelig priset i Norge i forhold til land som Frankrike og England
    som det er naturlig å sammenligne seg med.
    1 eksempel:
    YBA Heritage A200 18.800 NOK 2.390 EUR 1.850 GBP
    sound of heaven
    Hei Britfi
    Svaret er Ja:) (y)
    Her ser du baksiden på Heritage A200
    BritFi
    Da er det en meget god pris ja, vs. A100 som jeg har.
    Et spm til om jeg får: Den iA3 integrerte -blir ikke klok på om den opererer i A eller A/B, evt annet. Sett noen franske tester som nevner klasse Alpha.
    Vet du?
    sound of heaven
    YBA's α-Class A
    Yves-Bernard André:
    "The power supply works in class-A, but the output stage delivers only the power required by the music signal."
    "Therefore, you have the sonic quality of Class A operation — linear output with current on demand —
    without the negatives."
    "Therefore, our amplifiers run cool, which improves reliability and avoids thermal stress on the components and the resultant parasitic vibrations."
    sound of heaven
    YBA's α-Class A
    Yves-Bernard André:
    In fact many people think that class A sound is better because less distortion.
    In fact, it is not the real reason. I state and tested 3 main reasons:
    1. The memory distortion coming from the variation of temperature on the output devices, giving different curves.
    In fact a transistor with a small signal has a curve and with a big signal another one, because its inside temperature will change from 30°C to 100°C very rapidly. We can then easily imagine that this has an effect on the sonic result and a non linearity. Until now, nobody took care of this phenomena.
    2. In class A, the output stage is active always sucking current and then, the power supply is working always, particularly the rectifiers which are working in there linear portion. This is the important factor and not the distortion at the output stage. YBA finds a way to follow this aspect in his design.
    3. The big disadvantage of heat dissipation in class A is the reliability, which is divided by a factor 2 each increasing of 10°C of the temperature.
    In fact YBA claims to have the advantages of class A without having the inconvenient. Same for Class AB. YBA has the advantages of both classes: smooth and dynamics. Dynamics does not mean loud, but respect the life of the music.
    The result is that we can listen at lower volume and keep the tonal balance of the music.
    corey
    Sandefjord
    Er dette produktet "designed in france" men "made in Cina", Altså hele produksjonen av produktet er laget i kina?
    sound of heaven
    Hei Corey
    Det stemmer at YBA har flyttet sin produksjon til Kina men som Yves Bernard Andre påpeker så blir det kun brukt Franske komponenter.
    corey
    Sandefjord
    Produktet ser helt fantastisk ut å høres sikkert like bra som det ser ut, men pengene mine går til europeisk arbeidskraft av etiske grunner så da blir det nok ikke noe på meg dessverre.
    hvalross
    Tull og tøys. For eks.hvis denne forsterkeren hadde verdens beste lydkvalitet ,kan vi si .så hadde ikke du kjøpt den pga.at dine penger går til europeisk arbeidskraft av etiske grunner og ikke til Kina .:rolleyes:🤣 Kanskje mye av utstyret du allerede har er produsert i Kina.
    corey
    Sandefjord
    Man kommer ikke utenom Kina når det gjelder dagligdagse produkter. Vet at min ps5 står i Kina og venter på og komme hjem til meg, skulle nok ønske den var laget i Japan. Hadde Mcintosh flagget ut til Kina så hadde merket mistet all troverdighet og følsesmessig kapital for de som kjøper uansett hvor bra lyden måtte være. Når det gjelder vår hobby så vil jeg velge produkter som er så etisk som mulig. Kunne kjøpt (og har gjort) for.eks Decware. Men må si at YBA har noen meget vakre produkter, legger spesielt merke til en meget for seg gjort bakside, ikke ofte man ser det er lagt like mye flid med bakside som fronten.
    BritFi
    Vi skal vel ikke ødelegge en god nyhetstråd med diskusjon om produksjonsland.
    Du har jo hatt en rekke lyd produkter som er satt sammen i østen selv Corey.
    Ingen skam i det, er vestlige selskaper sin jobb å sørge for at fabrikk de benytter oppfyller alle krav, som at de er grønne og etiske.
    Ang.utførelse: er ikke så verst at de har fått med logoen sin heller, sett ovenfra. Men lurer på alle de trebitene som er limt på div.komponenter.
    Er det vibrasjonsdemping eller noe som er formålet..?
    yahooboy
    Sydhavsøerne
    YBA er ejet af Shanling. De købte YBA i 2009 og i 2012 blev alle serier genintroduceret efter at være genudviklet af Shanling's ingenører. Læs YBA's hjemmeside, alle referencer til Yves-Bernard André er i datid. Som i har været
    sound of heaven
    Det er riktig at Shanlig er på eiersiden av YBA men at Yves Bernard Andre ikke er en del av YBA fremdeles er fullstendig feil.
    Sound of Heaven
sound of heaven
sound of heaven sine annonser
Nyhet! YBA Design Line YM302 Streamer DAC
Da kan vi meddele om at YBA sin YM302 Streamer/Dac fra deres Design Line serie er klar for markedet:)(y) Pris 40.900.- Introtilbud ut juli 35.800.- Sound of Heaven Tlf:+47 464 29 861 E-mail...
Opera Prima V2 - Secrets of Home Theater and High Fidelity
Strålende test av Opera Prima V2 fra deres nye Classica Line serie (y) Noen utdrag: Opera’s Classica Prima v2 Loudspeakers play easily to high volumes without harshness. With a massive sound...
Nytt merke hos Sound of Heaven - SHANLING
  • 1
Sound of Heaven gjenintroduserer Shanling på det Norske markedet med deres splitter nye modeller CT90 og SM90. Når det kommer til ytelse, pris og kvalitet så mener vi at Shanling har satt en helt...
Indian Line Utah serie
  • 1
Indian Line sin nye serie Utah med modellene Utah 5 og Utah 8 står nå ferdig innspilt og klare for demo i våres show rom (y) Tilbakemelding fra fornøyd kunde:) Hei Jess! Ja dette var herlige...
Franco Serblin Accordo Unica - test i Hi-Fi Plus
Strålende test av Franco Serblin sin nye topp modell Accordo Unica i Hi-Fi Plus :) Noen utdrag: This is a loudspeaker that treats music with ` generosity ` . That sounds quite abstract, but a...
Introduksjonstilbud - Takumi
Introduksjonstilbud på Takumi platespiller og pick up ut mars mnd. Vi vil nå tilby en ferdigsydd pakke fra Takumi bestående av dere kritikerroste TT 2.1 DC platespiller med deres Kuro mc pick...
