ORTOFON 2M PICKUPER
  • ru-jo
    HARSTAD
    Fant ikke noe om Ortofon 2m Pickup`er så jeg lager en tråd.
    Fint om dere kan skrive litt om hvilke egenskaper hver enkelt Ortofon 2M har, lydkarakter ect.
    Liker selv 2M Red med den varmen og den runde lyden den har på enkelte plater.
    ru-jo
    HARSTAD
    Her er 2M RED Specs og data. Enjoy :cool:
    Output voltage at 1000 Hz, 5cm/sec. - 5,5 mV
    Channel balance at 1 kHz - 1,5 dB
    Channel separation at 1 kHz - 22 dB
    Channel separation at 15 kHz - 15 dB
    Frequency range at - 3dB - 20-22.000 Hz
    Frequency response - 20-20.000 Hz + 3 / - 1 dB
    Tracking ability at 315Hz at recommended tracking force - 70 µm
    Compliance, dynamic, lateral - 20 µm/mN
    Stylus type - Elliptical
    Stylus tip radius - r/R 8/18 µm
    Tracking force range - 1,6-2,0g (16-20 mN)
    Tracking force, recommended - 1,8 g (18 mN)
    Tracking angle - 20°
    Internal impedance, DC resistance - 1,3 kOhm
    Internal inductance - 700 mH
    Recommended load resistance - 47 kOhm
    Recommended load capacitance - 150-300 pF
    Cartridge colour, body/stylus - Black/Red
    Cartridge weight - 7,2 g
    2M PnP MkII cartridge with integrated headshell weight - 20 g
    2M PnP MkII cartridge with integrated headshell length - 52 mm
    Replacement stylus unit - 2M Red (interchangeable with 2M Blue and 2M Silver)
    ru-jo
    HARSTAD
    2M BLUE SPECS OG DATA :rolleyes:
    2M Blue Technical data
    Channel separation at 1 kHz - 25 dB
    Frequency range at - 3dB - 20-25.000 Hz
    Frequency response - 20-20.000 Hz + 2 / - 1 dB
    Tracking ability at 315Hz at recommended tracking force - 80 µm
    Stylus type - Nude Elliptical
    Cartridge colour, body/stylus - Black/Blue
    Replacement stylus unit - 2M Blue (interchangeable with 2M Red and 2M Silver)
    ru-jo
    HARSTAD
    2M BRONZE SPECS OG DATA
    2M Bronze Technical data
    Output voltage at 1000 Hz, 5cm/sec. - 5 mV
    Channel balance at 1 kHz - 1 dB
    Channel separation at 1 kHz - 26 dB
    Frequency range at - 3dB - 20-29.000 Hz
    Frequency response - 20-20.000 + 2 / - 0 dB
    Compliance, dynamic, lateral - 22 µm/mN
    Stylus type - Nude Fine Line
    Stylus tip radius - r/R 8/40 µm
    Tracking force range - 1,4-1,7g (14-17 mN)
    Tracking force, recommended - 1,5 g (15 mN)
    Internal impedance, DC resistance - 1,2 kOhm
    Internal inductance - 630 mH
    Cartridge colour, body/stylus - Black/Bronze
    Replacement stylus unit - 2M Bronze (interchangeable with 2M Black)
    ru-jo
    HARSTAD
    2M BLACK SPECS OG DATA
    2M Black Technical data
    Frequency range at - 3dB - 20-31.000 Hz
    Stylus type - Nude Shibata
    Stylus tip radius - r/R 6/50 µm
    Cartridge colour, body/stylus - Black/Black
    Replacement stylus unit - 2M Black (interchangeable with 2M Bronze)
    ru-jo
    HARSTAD
    Slenger på Silver og white se også for di som bruker noe slikt ??
    2M MONO WHITE
    2M Mono Technical data
    Output voltage at 1000 Hz, 5cm/sec. - 4 mV
    Compliance, dynamic, lateral - 18 µm/mN
    Stylus type - Nude Spherical
    Stylus tip radius - R18 µm
    Internal impedance, DC resistance - 700 Ohm
    Internal inductance - 350 mH
    Cartridge colour, body/stylus - Black/White
    Cartridge weight without screws - 7,2 g
    Replacement stylus unit - 2M Mono (interchangeable with 2M 78)
    2M MONO WHITE SE
    2M Mono SE Technical data
    Output voltage at 1000 Hz, 5cm/sec. - 3.5 mV
    Frequency range - 20-25.000 Hz
    Frequency response - 20-20.000 Hz + 2 /- 1 dB
    Stylus tip radius - r/ R 6/50 µm
    Tracking force range - 1.4-1.7g (14-17 mN)
    Tracking force, recommended - 1.5g (15 mN)
    Internal impedance, DC resistance - 600 Ohm
    Internal inductance - 300 mH
    Recommended load resistance for stereo/mono connection - 47 kOhm/23.5 kOhm
    Recommended load capacitance for stereo/mono connection - 150-300 pF/300-600 pF
    Cartridge body material - Lexan DMX Piano White
    Coil wire material - Silver plated copper wire
    Cartridge colour, body/stylus - White/White
    Cartridge weight - 7.2g
    Replacement stylus unit - 2M Mono SE
    2M SILVER
    2M 78 Technical data
    Frequency range at - 3dB - 20-20.000 Hz
    Stylus type - Spherical
    Stylus tip radius - R 65 µm
    Cartridge colour, body/stylus - Black/Grey
    Replacement stylus unit - 2M 78 (interchangeable with 2M Mono)
    ru-jo
    HARSTAD
    Takker og bukker, fant den ikke ved å søke.
    lille hiawata
    Harstad
    Hei har en 2M Black på en Rega og det er den beste MM puen jeg har hørt.
    Medlem-
    Har selv en Bronze den låter veldig fint den til en rimelig pris.Sikkert andre i samme prisklasse som er like bra.Smak og behag.
    lille hiawata
    Harstad
    Vil si at har du en dårlig innspilling så hører du det .Den spiller jazz, rock, blues, klassisk osv like godt.En god allround pu. 2M BLACK er også veldig tilgivende mht platestøy. Mvh Geir.
    ru-jo
    HARSTAD
    Syntes 2M RED`en er rund og veldig behagelig å høre på men rund og fin loadness og en varme jeg syntes alle plater skulle hatt, Så det blir mest til at jeg ønsker å kaste halve vinyl samlingen og elsker resten ekstra mye ;D
    ru-jo
    HARSTAD
    Den er nokk drit bra og spiller nokk med mer varme og dybde enn 2m blue uten at den blir mindre detaljert?? Hva synes du ??
    lille hiawata
    Harstad
    Som oftest vasker jeg de før jeg spiller. Støv kan vel forekomme noen ganger.:)
    X
    X186841
    Går ann å leve med 2M Black hvis man ikke har vært så dum å høre på en god MC pick-up.
    ru-jo
    HARSTAD
    Det er klart en god MC er bedre, men en 2M Black spiller godt til prisen.
    Mens vi er inn på MC så undrer jeg på hva son er på Moving Coil og Moving Iron, for det har jeg ikke tengt på før nå. ??
    Her er et bilde av moving iron prinsippet.
    ru-jo
    HARSTAD
    Vis vedlegget 488001
    Jeg fikk vist svar av meg selv her :cool: Men ikke helt da bildet av moving Iron er litt uklart forklart. Så kom igjenn å forklar :rolleyes:
    Husk å svare med sitat.
    Og her er Moving Magnet og Moving Coil.
    ru-jo
    HARSTAD
    Jeg banner litt til i Kirka (Er jo 2m tråd) da trådstarter synes det må være lov.
    Ps! Er tillhenger av fet lyd med varm mellomtone.
    Denne lydkarakteren handler vel mer om lyden på platen enn pickupen, men den kan vel være en med virkende orsak til ekstra varm og frodig lyd. Noen Tips ??
    Kom Med Moving Coil og Moving Iron favorittene fra ca 10-14000.- og nedover Pros and Cons.
    lyntoft!
    Kløfta
    Pro: Veldig bra på musikk.
    Con: Nos eller sas nål er dyrt.
    Gunnar_Brekke
    Jeg syntes tegningen av moving iron prinsippet over, ikke er særlig god. Da er denne mye bedre:
    Her ser vi jern(iron)-korset/platen som er montert på cantileveret - som når den beveger seg - dirigerer
    den magnetiske fluxen gjennom respektive magneter - som genererer en spenning i (de fastmonterte)
    spolene som omslutter (de fastmonterte) magnetene.
    (Akkurat denne tegningen viser B&O forfinede versjon av MI; MMC (Moving Micro Cross). I en konvensjonell
    MI-pickup, tenk deg en kvadratisk jernplate - i stedet for den korsformede jernplaten).
    Fordelen med moving iron prinsippet er at man generer en spenning på høyde med den fra en MM-pickup
    (opp mot 5,0 mV), samtidig som den (invendige) bevegelige massen er like liten (eller mindre) enn det man
    finner i en low output MC-pickup. Som her:
    Det gjør at Sound Smith Carmen, han være et (meget godt) alternativ til Ortofon 2M Black.
    (Unngå Sound Smith Otello, da dennes butte nålesliping i kombinasjon med dens lave beveglige
    masse kan føre til at den plukker opp litt for mye overflatestøy fra (slitte) plater)...
    Reaksjoner: ptb
    ru-jo
    HARSTAD
    Vis vedlegget 488007
    Vis vedlegget 488010
    Enig at her var det bedre bildeli forklart enn ovenfor. Snaisen patent :rolleyes:
    Takk for innlegget Gunnar :cool:
