Produktlansering fra GoldenEar Technology: Bookshelf Reference X
Amerikanske GoldenEar Technology lanserer nå en stativhøyttaler i referanseserien, og denne har fått navnet Bookshelf Reference X, forkortet til BRX.
Listepris havner for tiden på NOK 17 600,- og leveringstiden er typisk på rundt 2 uker (fra det nye Europa-lageret i Nederland). En introduksjonsrabatt vil bli gitt på denne prisen ut mars. Etter introduksjonsperioden vil rabatten være på 15%.
Her er noen utdrag hentet fra pressemeldingen:
GoldenEar Technology is pleased to announce the introduction of a new ultra-high-performance compact bookshelf/stand-mount loudspeaker, the BRX. The goal of the BRX development project was to create a gorgeous, luxuriously finished, ultracompact loudspeaker which would incorporate the latest advanced technology developed for GoldenEar’s Triton Reference and Reference One.R, in order to achieve truly superb sonic performance typical of larger, much more expensive units.
The BRX was engineered to simply be the best sounding true bookshelf/standmount loudspeaker on the planet. It incorporates a 6" cast-basket bass/midrange driver with a focused-field magnet structure. The cone is formed with a proprietary curve, from a special formulation of polypropylene, which combines superior internal damping with a high speed of wave transmission through the cone (Young’s Modulus).This is basically the same driver used in the award-winning Triton Reference tower. The tweeter is the same Reference High-Gauss High-Velocity Folded Ribbon used in both the Triton Reference and Triton One.R as well as the SPS. The two drivers are perfectly blended with a unique “balanced crossover” with a floating configuration that incorporates high quality film capacitors. New internal speaker wire, which has a unique twist as in the Triton Reference, is utilized. A pair of inertially balanced 6.5" planar infrasonic radiators located on either side of the cabinet, acoustically load the active 6" driver as well as couple the internal bass energy to the room for tight, quick, extended bass response. The beautifully styled 12"H x 8"W x 12.25"D cabinet is luxuriously finished in hand-rubbed piano black lacquer.
The BRX has been engineered to deliver superior reference level performance for both two channel as well as home theater systems of the highest quality, with extraordinary three-dimensional imaging and high-resolution clarity. It has been voiced to match the Reference towers, with a tremendous sense of you-are-there lifelike immediacy. Overall frequency response is 40-35 kHz, efficiency is 90 dB and recommended associated amplification is 10-250 watts/channel.
An incredible value...bass was solid and impactful...when fired up, these new speakers put out a sound that was dramatically opposite to their small size with a huge enveloping soundfield that put a big smile on my face. –Carlo Lo Raso, Secrets of Home Theater
I was amazed...like all GoldenEar products, they punch way above their weight and deliver fantastic sound with detailed and airy highs, cymbal strikes that decayed beautifully and guitar plucks with textural detail.” –John Sciacca, Residential Systems
Waqar
Dette må være litt av et hifi kupp, jeg tar kontakt med deg angående disse. Kan ikke unngå å kjøpe disse 😁 Goldenear har overrasket meg meget positivt, de her har reference komponenter.
Gjallarhorn Audio
Gjallarhorn Audio sine annonser
Prisøkning fra ProAc den 1. mai
For de som for tiden vurderer å gå til innkjøp av høyttalere fra ProAc, så kan det være nyttig å vite at ProAc øker prisene med 7,5% den 1. mai (2025). Fra og med denne prisendringen, så vil for...
Takk for besøket på OHFS 2025!
  • 1
En stor takk til alle som var innom vårt rom (108). Det var en jevn strøm av besøkende under hele messen, så kanskje ble det en ny besøksrekord for Oslo HiFi Show i år? Vi må også få takke Stefan...
Clearaudio kommer til Oslo HiFi Show
Stefan Kmuch fra Clearaudio kommer til Oslo HiFi Show for å delta på norgespremieren av deres Master Jubilee platespiller som ble utviklet i forbindelse med deres 45 års jubileum. Clearaudio's...
Norgespremiere av SPEC's nye flaggskipsmodell på Oslo HiFi Show
RSA-EX1000 er japanske SPEC's nye toppmodell innen kategorien integrerte forsterkere. Denne kan høres for første gang i Norge på Harbeth's nye Monitor 40.5 XD2 høyttalere på rom 108 under hi-fi...
Harbeth's nye XD2-serie får sin norgespremiere på Oslo HiFi Show
Harbeth's nye XD2-serie er her! Første modell ut er Monitor 40.5 XD2 som vil bli demonstrert under Oslo HiFi Show den 22.-23. mars. Velkommen! Veiledende pris for M40.5 XD2 starter på kr. 223...
Gjallarhorn Audio velger AnalogLAB
Alle platespillere levert av Gjallarhorn Audio vil nå bli satt opp av AnalogLAB i Asker med mindre du har glede av å gjøre jobben selv eller at du ikke kan hente platespilleren hos oss og...
