- Ble medlem
- 31.12.2004
- Innlegg
- 2
- Antall liker
- 0
Hei,
noen som har prøvd noen av modifiseringene på http://www.tonearm.co.uk (Origin Live)?
Jeg ble litt interessert i motvektsmodifiseringen, tenkte på å kopiere den og lage selv, men klarer ikke helt å forstå forskjellen i festemetoden for "ende-røret" som loddet sklir på.
"The upgrade involves removing the rear end stub. This stub is just screwed into the end of the arm - far from ideal! Origin Live then replace the old stub with a new stub. The new stub is torqued onto the arm by a thin high tensile bolt. The new stub is also designed such that it presents a low contact area onto the arm tube and is therefore decoupled, yet far more rigid than the original. This change also allows the counterweight to be rigidly clamped onto the stub using an Allen bolt. An unmodified arm should not have the counterweight rigidly coupled in this way, due to the old vibration characteristics of the standard arm / rear stub joint. This ingenious modification elevates a good arm into the same league as the super arms and at an insignificant outlay."
Her er et bilde: http://www.tonearm.co.uk/images/rb300diag2.gif
Noen som har erstattet den interne kablingen?
