Remote controlled W7 enterprise 64 bit halts when remotecontrolled
LMC
Drøbak
hei
poster her og
legger det ut på engelsk idet jeg også har søkt etter hjelp på Thewinforums
Leif
hello
have this peculiar problem:
I have several PCs with W7 enterprise 64 installed
one is a Lenovo laptop, remote controlling a maxitower pc serving as a "musicserver"
the musicserver is equipped with 8TB of harddiscs with Wav musicfiles
OS disc is SSD Kingston Hypex 120gb
asus motherboard with quad 6600 cpu and 8gb ram
Musicfilesplayer is Foobar 2000 feeding usb to asyncronious usb receiver in external d/a converter and then into stereo system
Laptop is hooked up to wireless home network through D-Link 855 router
Musicserver is hooked up with wired LAN to router
Remote desktop is set up to play sound out from remotecontrolled pc.
the usb receiver in the dac has its own asio driver installed in the pc
the problem:
recently, when being remotecontrolled the "musicserver" has started halting/freezing randomnly for up to between 2-15 seconds and subsequently the sound stops
thought it might be just Foobar, but when watching the task manager under performance I can see that the whole pc halts all activity, then restarts all activity by itself
think the problem have increased for the last couple of days
this does not happen when I work directly on the musicserver
installed teamviewer and all is fine, same with logmein, so it´s obviously linked to the Windows remote desktop function
any ideas
by the way; windows update is on, but needs my acceptance to install; I normally install all except IE9 ( I use Firefox)and new languages
have installed microsoft security essentials , no other security programs, firewall is in recommended settings
user account control is off!
the OS is a new fresh install due to SSD failure yesterday, problem still the same as the day before
I really prefer the user interfase of the remote desktop compared to the others
all suggestions are welcome
best
Leif Christensen
Norway
Problemer med interferens i det trådløse?
Prøv å oppgrader firmware i dlink routeren og kanskje skift kanal (Jeg har samme dir 855)
Reboot og test på nytt.
Ellers er oppsettet ditt veldig likt mitt.
LMC
Drøbak
hei
takk for forslag
men virker usannsynlig siden teamw og logmein går samme veien
skal prøve kablet også, for å sjekke
Leif
ja - men de er gjerne ikke like utsatt for korte "dropouts". Og da spiller ting evt. fint i bakgrunnen. Det gjør det ikke med RDP......
Selv bruker jeg rdp og ultravnc (med en proprietær skjermkortdriver til akkurat det programmet). Det er også nice. Nesten like kjapt som rdp (men ikke helt)
Man kan f.eks. ikke kjøre video ut på prosjektor via RDP desverre. Eller spille spill via prosjektor etc. Det fungerer fint med andre remote løsninger.
LMC
Drøbak
det rare er at det stopper hele maskinen!
og jeg har kjørt i månedsvis uten at dette har skjedd
lurer på om det er noen jævlig MS windows update/"fix" som har trigget det?
Leif
nma
Hvis det er en nyinnstallering, så er det enkelt å isolere problemet.
Prøv med en annen desktop, hvis det samme skjer, er det muligens et hardware-problem i serveren, evt en eller annen innstilling i BIOS eller noe som har trigget. (Det kan også være skjermkortet og/eller driverne til den mener jeg...)
Hvis RDP fungerer helt fint fra den andre laptopen, så er det noe i Lenovo-laptopen din som er problemet.
