Ny utgave med common mode choke på begge sider. Vilkårlig hvilken vei filteret settes inn, fungerer like godt begge veier.
Dette filteret har høykvalitetskomponenter i alle ledd. Isolasjonstransformator og common mode choke coil er designet av Sellarz, mu metall skjerming, 0,1 %/10PPM, 0,05uV motstanderog kondensatorer av høy kvalitet. Prisen er 3300,- inkl. 30cm cat8 LAN kabel.
This is a LAN Noise Filter for Network Players that removes LAN transmission noise. It has a built-in isolation transformer and a choke coil for common mode noise to remove noise that occurs between Internet lines and various network devices (PC, router, NAS, Network Player).
In addition, LNF-10GCMF is a non-directional LAN noise filter that does not have a specific directionality to remove LAN transmission noise while maintaining the bi-directional characteristics of the ETHERNET signal . By installing a common mode choke on both ends of the isolation transformer as shown below, the confusion about directionality has been eliminated.
Spesifikasjoner
1. Ethernet IEEE802.3ae: 10GBASE-T/10Gbps(compatible with 1GbE, 100Mbps)/500MHz
2. Recommended Ethernet Cable: CAT.6a, CAT.7, CAT.8 (EIA/TIA 568B)
3. EMI Shielding by Aluminum(-98dB @10MHz ~ 1GHz)
4. CMRR (Common Mode Rejection Ratio): -64dB min./10MHz ~ 500MHz
1. 10Gbpa (10G BASE-T, 00Mbps, 1Gbps compatible)
2. Common Mode Choke Coil
3. Ultra Low Noise Thin Film Resistor
4. Ultra Low THD Capacitor
5. EMI Shield
6. Size: 73 x 31 x 25(L x D x H: mm)
www.andervikaudio.no
post@andervikaudio.no
+47 92012111
Spesifikasjoner
5. EMI Shield
+47 92012111
70.6 KB Visninger: 31.575
80.8 KB Visninger: 38
388.9 KB Visninger: 47
423.3 KB Visninger: 48
73.2 KB Visninger: 46
