Dali Epicon 8 og NormAudio spiller her hjemme nå da
Norma Revo IPA-140
- Extreme low noise, high speed schematic topology and wide band ( >2 MHz ).
- High current MOS-FET power device (150 A output peak current).
- 12 power device for a total rated 1.500 W power handling capability.
- Separate power supply for Gain, Driver and Output stage.
- High speed and low noise regulated power supply for gain and driver stage.
- High filtering capacity (70.000 uF) with numerous (24) low impedance capacitors.
- Full aluminium non-magnetic frame.
- Toroidal power transformer specially designed for audio applications, low dispersion flow. low mechanical noise, high permeability magnetic core with consequent low output impedance, 2 x 400 VA.
- Input configurable as Direct Inputs, for Home Theater use
- Outputs configurable as Pre Out, Active or Passive, for use with Power Amp and/or with Active Subwoofer
XLR balaced input
- Remote control of all functions with NORMA RC-4 remote control.
- Two-speed volume control (Fine and Fast).
- Possibility of set the PHONO board inside, by 2 mono board for Left & Right channel.
- High quality phono stage, for MM and MC pick-up
- Protection for DC signal sensitive speakers.
- Inputs selection by relay with GOLD/PALLADIUM contacts.
- RCA solid core gold plated plug connector for any signal connections.
- Stand-by mode switches off the microprocessor one the command is executed, so as to annul any interference towards analogue signal.
Nye lydkasser i hus..
Dali Epicon 8
Kan si at de kan om de må,flytte masse luft
Benken
Denon DCD S1 cdspiller
Denon PMA S10mk-2 Forsterker
Denon TU S10 tuner
Lyttekroken
Denon DCD-S1
Gromspilleren er endelig kommet i hus...
Denon DCD S1
Slik byggekvalitet finner du ikke lengre... unntaket er i 100K klassen da
STS strømfilter
Dette er ombygd til et akktivt filter..med 100% skjerming...
Blåsern
Kablene..
Dette er Sense Reference Statement...
Forsterkeren..
Har fått nye terminaler.. de originale var i messing.. kobber er tingen her nå
Kablene gjør seg godt også...
Bak cd-spilleren...
Sense Reference Statement XLR... med extra skjerm fra jord...
Høyttalerene..
Montert samme terminaler som på forsterkeren...
"Pucken"
Kan vel kalle dette for platestbilisatoren... er vel en 300gram denne... det er tungt i cd sammenheng.
Coincident Total Eclipse
Glemte nesten disse.. Har et sett liggende nedpakket.. dette er en ABSOLUTT musikformidler på øverste hylle.. store med to 10"ere i hver ht..
Bildet er tatt med mobil.. kommer bedre bilder når det NYE lytterommet er ferdig
Stooore disse..
De er på 14 Ohm og 94 db..75 kg tunge og strekker seg 133cm oppover...Denon forsterkeren driver disse med bravur
Samme terminalene som resten jeg har...
Denon PMA-S10 mk2
Her er den integrerte forsterkeren.. Denne er et lite festfyrverkeri på 30 kg...
Denon DCD.S10 mk2
Tilhørende cd spiller på 12 kg.. byggekvaliteten på disse produkten fra midten av 90 tallet er bare GROM
Denon TU-S10 og Philips BDP-9500
Tuneren og filmformidleren..
Goldmund DSIX SPDIF Digital signal forbedrer..
En liten boks jeg bruker mellom PCM signalet på Philips BDP-9500 og digitalinngangen på cd spilleren min.. fjerner jitter/støy på digitalsignalet.. Kan vel kalle det en aktiv digitalkabel..
Rotel RB-850
Vinylsnurreren.. En hærlig sak som spiller stort..
Hanss SA-23
Har ikke prøvet så mange riaer, men denne er kommet for å bli.
Pioneer SE-30A
Øreklokker fra det herrens år 1972... strøkne sådan.. spiller flott,men litt tette/varme over tid.
Sense Acoustic mk3
Dette er høytalerene jeg har bygget.. Er meget fornøyd med formidlingen av musikk med disse.. absolutt ingen flaskehals disse nei..
Seas elementet
Seas bass/melomtonen..
Norma Revo IPA-140
Da er min kjære Denon byttet ut til fordel for denne Italieneren..
