SOtM - Soul Of the Music™
  • mteinum
    Øya
    Lykkelig eier av en snaisen liten nettversksstreamer (sMS-200), men ser at her mangler det en vennetråd.
    SOtM er et sør-koreansk selskap og nettsiden SOtM - Ultimate High Performance Audio ble opprettet juni 2008. I følge 6moons så var dette også da selskapet ble grunnlagt av Il-Won Lee (이일원). Moiz forhandler produktene her på berget.
    Produktene består i all hovedsak av musikkserver, nettverskspiller, dac, strømforsyning, og diverse pc-kort.
    Disse deles inn i to segmenter/prisklasser:
    Ultimate
    Ultimate – SOtM – English
    • sMS-1000SQ WE - Windows basert musikkspiller
    • sDP-1000EX - high-end D/A converter and pre-amplifier.
    • sPA-1000 - Class-D amplifier
    • sPS-1000 - high performance DC linear power supply
    Advanced
    Advanced – SOtM – English
    • sMS-200 - mini network player
    • sHP-100 - USB DAC & high performance headphone amplifier.
    • dX-USB HD - high performance DDC
    • mBPS-d2s - intelligent battery power supply
    Har vært på Horten-messa i 2012. Her noen bilder fra mitt kamera:
    Moiz Audio by Morten Teinum, on Flickr
    mteinum
    Øya
    sMS-1000SQ Eunhasu
    Ny hardware!
    Denne gangen fra Ultimate linjen:
    SOtM announces “sMS-1000SQ Eunhasu” is now available.
    - Eunhasu music player platform is now loaded on sMS-1000SQ.-
    SOtM has been released sMS-1000SQ series products, satisfying all the demand of sound quality, functionalities and technical requirements which are worthy of its own value of money.
    In this time, SOtM introduces the sMS-1000SQ Eunhasu, which is capable of following features by Eunhasu music player platform.
    - Easy system configuration
    - Selectable music player applications
    - Selectable and configurable USB audio devices
    - Network share folder and USB storage device setting
    - Roon Ready
    - Roon Server
    - MinimServer
    - DLNA audio renderer, OpenHome support
    - MPD(Music Player Daemon)
    - LMS(Logitech Media Server)
    - Squeezelite
    - HQPlayer Network Audio Adapter
    - Shairport
    - Multi-zone network playback
    sMS-1000SQ Eunhasu is a state-of-art music server and player equipped with the best technology capable of convenient use and budget. The sMS-1000SQ Eunhasu can offer the extremely satisfying sound quality no matter what sort of systems are to be configured.
    The price of sMS-1000SQ Eunhasu starts from US$3000 and is available with various features and options allowing the customers freely choose what they want per own favorite sound taste and system. Yet, the sMS-1000Q is providing high quality of sound with the basic default features, also can easily enhance sound quality by simple trick such as using a separate external power supply to the USB audio port.
    - Color : Silver or Black
    - Output : USB output, Digital output, Analog output
    - Storage Capacity : 64G SSD for standard feature, Max.4TB HDD or max.2TB SSD for extra storage.
    - Clock : sCLK-48.0 for USB output or sCLK-2224 for Digital or Analog output
    sMS-1000SQ Eunhasu – SOtM – English
    mteinum
    Øya
    Update news about sMS-200 Wi Fi
    Greetings,
    Finally we are able to update the news about WiFi support for sMS-200, thank you for your patient. We are still working on few more steps to be done and it will be ready shorty.
    Here we would like to inform you in advance that the WiFi feature will be slower than wired one and the Wifi dongle which uses RTL8812AU chipset should be used for sMS-200 WiFi support.
    We will keep you posted about sMS-200 Wifi support shortly.
    Update news about sMS-200 Wi Fi – SOtM – English
    Regner med at dette blir et kretskort som monteres i sMS-200.
    mteinum
    Øya
    Ny firmware for sMS-200 kom 28.12.16
    Version : V0.3.0
    - Date : 28-12-2016
    - Fix not change background image bug
    - Fix raat_watch daemon bug
    - Fix broken icon for openhome
    - Fix volume issue for MPD
    - Add EFI mount disable only for sMS-200
    - Add wifi connection feature
    - Add RTL8812AU driver
    - Update kernel to 4.4.14
    - Modify UI
    Oppgradering er veldig enkelt å greit:
    1. System upgrade
    2. Upgrade Now
    3. Reboot
    Og etter dette så har det kommet nye menyvalg under Network config, bla. wifi
    Mangler wifi-modulen i min enhet, så denne kan ikke koble til det trådløse nettet enda.
    mteinum
    Øya
    Eunhasu_ Native DSD support
    Siste nytt :)
    Greetings,
    SOtM announces that Eunhasu supports native DSD with certain audio function: RoonReady, Squeezelite, MPD/DLNA and HQ player NAA, from F/W version 3.2.
    And the native DSD support on Eunhasu is available with certain DACs. If your DAC is not listed below, you can continue to play DSD via DoP. If you think we may miss to update your DAC on the list below, please contact us to check whether your DAC is supporting native DSD with sMS-200. we will proceed some test with you and try to update your DAC on the list.
    Audiolab M-DAC+
    Aune X1S 32BIT/384 DSD DAC
    AURALiC VEGA
    Bryston BDA3
    CH Precision C1 DAC
    DIYINHK DSD DXD 384kHz USB to I2S/DSD
    Eastern El. MiniMax Tube DAC Supreme
    Engineered Electronics Stereo Playback Interface
    Gustard DAC-X20U
    Holo Springs Level 3 R2R DAC
    iFi Audio micro/nano iDSD
    JLsounds I2SoverUSB
    LH Labs Geek Out 1V5
    LH Labs Geek Pulse X Inifinity 2V0
    LH Labs VI DAC Infinity
    Matrix Audio Mini-i Pro
    Matrix Audio Quattro II
    Matrix Audio X-Sabre
    MSB Technology
    Mytek Brooklyn DAC
    NuPrime Audio DAC-9
    NuPrime Audio HD-AVP/AVA
    NuPrime DAC-10
    NuPrime IDA-8
    OPPO HA-1
    OPPO HA-2
    Playback Design
    PS Audio NuWave DAC
    Singxer F-1 converter board
    Soekris dac1101
    Unison Research Unico CD Due
    WaveIO USB Audio 2.0
    Wyred 4 Sound DAC-2 DSD
    Also currently, we are modifying the Eunhasu manual, nd it’s almost ready. Once it’s available, we will put the manual in the sMS-200 and sMS-1000SQ product page to download or see.
    mteinum
    Øya
    Da har jeg oppgradert min sMS-200.
    Under Roon-oppsettet kan man velge hvilken DSD modus denne skal bruke. Velger Native og lagrer.
    Og slik ser Roon ut. Gjorde ingen endringer i oppsettet på denne siden.
    mteinum
    Øya
    Mye spennende som kommer på High End -messen i Munchen
    For the show, SOtM planned to bring the numerous new products such as sMS-200Ultra, sPS-500, mT-1000, sPA-1000 and the dCBL-U10, etc, every SOtM products will be static displaying and demoed during the show.
    https://www.sotm-audio.com/sotmwp/english/plan-for-2017-high-end/
    sMS-200 Ultra er en forfinet utgave av dagens sMS-200 med oppgradert klokke
    I also currently own the SOtM sMS-200 Ultra, which should be formally released sometime next month at a price point of about $1,300. At least in my system, this Ultra is in a class of its own and easily surpasses the 3 that you have on your list. The only thing that sets it apart from the standard sMS-200 is a better clock, however, this clock makes a pretty significant difference.
    https://www.computeraudiophile.com/forums/topic/31498-which-endpoint-for-roon/#comment-652008
    mteinum
    Øya
    https://www.sotm-audio.com/sotmwp/english/press-release-sms-200ultra/
    Her er det mulighet for oppgradering av eksisterende enheter
    Greetings,
    We proudly announce that sMS-200ultra will be finally available in the next week and we sincerely apology for the long waiting.
    The first shipping would be available on 9th, June but we are trying to make the shipment available earlier.
    Please check more information about sMS-200ultra on our website, click here.
    sMS-200ultra – SOtM – English
    And many world users whom own the sMS-200 have been waiting for and requested to hear about the upgrade path of their current sMS-200 to be upgraded to the sMS-200ultra, and here we prepared the special upgrade path.
    Please read the details of how to join, and shoot an email to go to the next step properly. But, please remember that your local partner or the shop you bought would help you to arrange this upgrade path much easily.
    Subject :
    The upgrade path to be the sMS-200ultra for whom owns the sMS-200
    Period :
    A month. Starting from 7th, June to 7th, July.
    For whom :
    current sMS-200 users
    Benefit :
    1. Purchase the sMS-200ulta at the very special price, US$900
    2. The sMS-200ultra includes the master clock connector for free.
    Condition :
    1. The sMS-200 should be returned to us in Korea.
    The sMS-200 with the serial number should be provided and sent to your local partner or the shop you bought or us directly. We and our partner would take your sMS-200 to be upgraded to the sMS-200ultra in the list and waiting for it to be returned to Korea for the upgrade. The shipping and handling cost should be paid by you or our local partner or the shop.
    2. Take 3 business working days and a round trip shipping period.
    The upgrade would be made with your sMS-200, so the round trip shipping time plus 3 business working days for the upgrade should be required to complete the upgrade to the sMS-200ultra.
    3. Take the big advantages.
    SOtM offers more than USD300 discount for this upgrade path and all this upgrade unit would have the master clock connectors included. But if your current sMS-200 condition is not good, SOtM would not be responsible of any service or faulty. (Depending on the situation, the repair cost would be charged additionally.) And, SOtM wouldn’t be responsible to any accident during the shipment.
    To proceed the upgrade path, please contact your local dealer or email us to get more information.
    deleted
    Fikk sMS-200ultra og sPS-500 i hus i dag. Denne komboen tar over for en Bluesound Node 2. Har bare fått et par timer spilletid foreløpig, men det låter meget bra allerede. Må få testet enda litt mer på kjent musikk, men har trua på at dette blir bra. :)
    mteinum
    Øya
    Penger ut, boks inn.
    Speed unboxing
    Ny eske samt pose
    Posen inneholder en splitter
    Reklame, strømkabel, manual
    PSU
    Kabelkaos. Den enkle følger med sPS-500; dobbel ekstra.
    Forsiden på sMS200 ultra, tX-USBultra og sPS-500 er svært like, baksiden naturligvis ei.
    Familiebilde
    Og her med strøm tilkoblet
    Med Tidal HiFi/Roon/SOtM/Mytek begynner jeg å stille meg spørsmål ved om det er noe poeng med platespiller i det hele tatt... neida, den ryker ikke ut, men jeg ser jo hva som blir prioritert.
    deleted
    Hvilken spenning har du satt sPS-500 på? Jeg har min på 9V, og det ser ut til å funke bra.
    mteinum
    Øya
    12V (trinn nr. 3). NB! Bildet viser trinn nr.1; 7V, dette ble tatt før jeg satt denne til 12V.
    Både sMS200-ultra og tX-USBultra er 12V utgaver (dvs. mine er)
    Har man planer om Advanced II serien til SOtM så kan det være lurt å huske på at komponentene kommer i flere varianter ref. spenning.
    tX-USBultra
    Input voltage : 9Vdc (Optional 12Vdc or Optional 6.5Vdc ~ 8.5Vdc)
    tX-USBultra – SOtM – English
    sMS-200ultra
    sMS-200
    Denne har variabel input
    Input Voltage : +6.5 ~ 12Vdc
    sMS-200 – SOtM – English
    sCLK-OCX10
    Input voltage : 12Vdc
    http://www.sotm-audio.com/sotmwp/english/portfolio-item/sclk-ocx10/
    deleted
    Måtte dobbelsjekke min 200ultra. Har standardutgaven, så da er jeg på rett innstilling.
    mteinum
    Øya
    Omtale av sMS-200ultra/sPS-500 i 6moons
    6moons audioreviews: SOtM sMS-200ultra
    Software [...] and Roon Ready Endpoint. The latter is promoted with a 60-day comp trial code. Because I have long since tagged my iTunes library just so; and because I don't stream subscription services in the big system, just on the desktop - I didn't wish to install then uninstall Roon.
    "Å-nei" var første tanke. Dette burde være hovedgrunnen til å ta i bruk en nettverksstreamer. Separasjon av PC og Hi-fi. Roon er den beste softwaren jeg har kommet over innen digital avspilling av lokalt innhold samt streaming (Tidal). LMS var et hyggelig minne, men jeg kommer aldri til å gå tilbake til denne.
    mteinum
    Øya
    Det ble en lang arbeidsdag :)
    Da var man hjemkommet og oppdatert litt mykvare.
    Dette mener jeg er nytt siden 1.3 - det at man kan se at det er en MQA stream som er kilden ved avspilling. Ref. https://www.flickr.com/photos/mortenteinum/31770930900/in/dateposted/
    Denne var faktisk litt fiffig
    Koble til en https://mytekdigital.com/clef/ som har MQA støtte så burde det være mulig å få portabel godlyd i huset.
    Well, this has been a long time coming. Starting today, Roon supports playback to iOS devices!
    iOS devices will now automatically exposes a private zone that acts like a System Output in some ways. However, iOS’s infrastructure is careful enough that when only one app is playing, the output is bit-perfect. Thus, external DACs, 24bit output, MQA, and DSD are all possible. Signal path will reflect playback quality accurately, and will also display the output path (headphones, speakers, bluetooth, usb, hdmi, …).
    deleted
    Mener å huske at det var mulig å se MQA stream i signalveien på 1.3 også.
    mteinum
    Øya
    Lars™
    OK, verden går videre selv om Logitech Transporter er den tøffeste med VU-meter og ku-fanger ;)
    Må vel gjøre endringer ser jeg....
    HoJ
    En glad amatør.
    Dette er jo bare lekkert!!
    mteinum
    Øya
    Ny firmware for sMS-200/ultra ute:
    Last version information
    Version : V0.4.14
    - Date : 29-01-2018
    - Update HQplayer NAA to 3.5.2(with configfile)
    - Add MPD audio output mixer type option
    - Shairport supports all Ethernet ports and WiFi dongle
    - Add all Ethernet ports’s static IP setting feature
    - Upgrade Ethernet ports automatic reset to DHCP feature
    - Update Russian language.
    - Update French language
    - Add two more DACs for supporting native DSD
    - Various small bugs fixed
    - Add the kernel check feature for native DSD upgrade
    Updated info for the V0.4.14
    -Add MPD audio output mixer type option
    mixer_type (hardware|software|null|none)
    Specify which mixer should be used for this audio output: the hardware mixer (available for ALSA, OSS and PulseAudio), the software mixer, the “null” mixer (null; allows setting the volume, but with no effect; this can be used as a trick to implement an external mixer) or no mixer (none). By default, the hardware mixer is used for devices which support it, and none for the others.
    https://www.sotm-audio.com/sotmwp/english/latest-eunhasu-fw-v0-4-14/
    Atlerovik
    Digger min sMS-200 Neo! Enormt løft i den digitale lyden hos meg. Noen som vet om sPS-500 også kommer i sølv-farge (så den matcher sMS-200)?
    Dharmabum
    Snasent oppsett Atle 😊veldig fin stereobenk også, kan jeg spørre hva den heter og hvor du har kjøpt den? Har selv usm haller, men sliter med resonans /vibrasjoner. Sorry ot.
