SUPRA Cables First in World to Prove Directionality in Audio Cables?
ymir
Hvorfor silver plated strømkabel?
So it’s now time to ramp it up a bit and Supra are making a limited production run using SILVER-PLATED OFC conductors
http://www.indulgenceshow.com/supra-launch-new-silver-plated-lorad-2-5-mains-cable/
SUPRA Cables - Experience High Quality HDMI, DVI and HI-FI Cables & adapters.
[h=3]Useful to know about...[/h][FONT=&quot]Tin plating
A Supra concept for cleaner sound. The tin is of higher resistance than copper and also protects copper from bad sounding corrosion. It also mini-mises the current jumps from wire to wire over corroded copper sur-faces while more of the signal passes through the pure copper inside the wires. The tin layer also minimises the skin-effect, by acting as a semi-Litz.[/FONT]
[FONT=&quot]Silver plating
Only when the frequen-cies are very high, as in digital signals, does it seem wise to go the opposite way, i.e. to silver plate for a lower surface resistance. At such high frequencies it is hard to keep the signal inside the wire, so instead we design for an easier surface current flow.
[/FONT]
[FONT=&quot]SUPRA Cables First in World to Prove Directionality in Audio Cables
Supra Cables have taken part in pioneering measurements developed and conducted in a joint venture by Ben Duncan Research and Jenving Technology.[/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]Directionality in audio cables has been controversial, particularly as no other cable maker in the world has previously been able to say what the mechanism is, let alone measure it.[/FONT]
[FONT=&quot]Using regular lab equipment and test signals, the measurements show measurable, and repeatable quite large differences, when cables are reversed. The bottom line is the direction in which the wires inside were last 'drawn' at the copper factory. The tests even revealed conductors that had been reverse-spooled by the copper wire maker![/FONT]
[FONT=&quot]A proof of the forward thinking in Jenving's Supra Cables, the new test has been able to show that the conductors in all Supra production are not only already optimally 'directed', but that optimal directionality is also already correctly identified
Ben Duncan Research
Ben Duncan Research*-*Startsiden*søk[/FONT]
[FONT=&quot]
[/FONT]
bengt
Mo i Rana
Ben Duncan: Holistic designer, prolific author & inventor. ;D
Siden du åpenbart bare bare copy paster alt mulig uten kritisk gjennomlesning og forståelse. Kan du hjelpe til med å finne bevisene det henvises til? Duncan og supra har jo et samarbeid som innebærer et økonomisk og markedsføringsmessig tilsnitt så troverdigheten av å bare ytre påstander er mildt sagt veldig liten..
Jeg er oppriktig interessert i bevisene og sannhetsgehalten i slike påstander..
Eller er det et copy paste kjørdebattventpåsvar innlegg?
osc
