TUBE TALK XIII
Rør med sotbelegg? Kan det være bra da?
Et relativt ofte stilt spørsmål. Til og med om dette kan være grunn til reklamasjon.
Google kan svare på det meste. Og hvis svaret finnes på Wikipedia kan en stort sett stole på informasjonen.
Getter - Wikipedia
Kortversjonen:
A getter is a deposit of reactive material that is placed inside a vacuum system to complete and maintain the vacuum. When gas molecules strike the getter material, they combine with it chemically or by absorption. Thus the getter removes small amounts of gas from the evacuated space. The getter is usually a coating applied to a surface within the evacuated chamber.
A vacuum is initially created by connecting a container to a vacuum pump. After achieving a sufficient vacuum, the container can be sealed, or the vacuum pump can be left running. Getters are especially important in sealed systems, such as vacuum tubes, including cathode ray tubes (CRTs), Vacuum Insulating Glass (or Vacuum Glass)[1] and vacuum insulated panels, which must maintain a vacuum for a long time. This is because the inner surfaces of the container release absorbed gases for a long time after the vacuum is established. The getter continually removes residues of a reactive gas, such as oxygen, as long as it is desorbed from a surface, or continuously penetrating in the system (tiny leaks or diffusion through a permeable material). Even in systems which are continually evacuated by a vacuum pump, getters are also used to remove residual gas, often to achieve a higher vacuum than the pump could achieve alone. Although it is often present in minute amounts and has no moving parts, a getter behaves in itself as a vacuum pump. It is an ultimate chemical sink for reactive gases.[2][3][4][5][6]
Getters cannot react with inert gases, though some getters will adsorb them in a reversible way. Also, hydrogen is usually handled by adsorption rather than by reaction.
Audiomix
Audiomix sine annonser
GOD JUL FRA A&M VACUUM TUBES
Alle musikk, rør og DIY entusiaster ønskes en riktig God Jul. Til ryktet om at rørbutikken er overtatt av en herværende konkurrent: Det er absolutt feil. A&M Vacuum Tubes lever i beste velgående...
LM ERICSSON 6761. Kvalitetsrør fra Sverige
Et medium effekt rør fra LM Ericsson. I klasse med EL84, men ikke direkte kompatibelt. Et rimelig alternativ for en DIY'er. 6761 LM Ericsson – Audiomix
NOS 2C51 - 5670 - 396A
Rør har som de fleste vet forskjellige typebetegnelser noe avhengig av hvem som har produsert, til hvem de er produsert og i noen tilfeller etter spesielle spesifikasjoner. Til audio / HiFi vil de...
LM ERICSSON - Kvalitetsrør fra Sverige
  • 10
LM Ericsson var blandt pionerene som bygde ut kommunikasjonsystemer. Både med og uten tråd. Systemene var ofte plassert på fjelltopper og andre steder som var vanskelig tilgjengelige. Derfor var...
TUBE TALK XIV
TUBE TALK XIV
Knapt noen nyhet, men datablad fra juni 1942 kan være interessant nok. Dette gjelder power trioden VT-4-C eller 211 i sivil betegnelse. Les videre. Helt til slutt noen tips om "INSTALLATION".
NOS RCA 811 + skjema
Et flott DHT rør til svært gunstig pris. https://audiomix.no/shop/power-tubes/jan-811-rca/ Ikke spesielt komplisert å bygge en Single Ended forsterker med dette røret. En Shishido konstruksjon...
