likner på en elna silmic verdi /6,3volt?
kryss sjekk diameter og sammenlikn så finner du verdien
ELNA Miniature RFS SILMIC II series with Silk fiber
for audio use New
Features:
Same as SILMIC ARS Series with Silk Fiber using Audio Purpose Capacitor
Series RFS is Miniature High Grade Capacitors for Audio (SILMIC II)
All lead wires oxygen-free copper for extremely low distortion. (Third high frequency distortion 10kHz, 0.1A,-120dB or less)
Vinyl sleeve is of brown finish gold SILMIC II mark.
Working Voltage(V) / Capacitance(uF), Dimension (D x L)
6.3/33 5 x 11mm
6.3/47 6.3 x 12mm
6.3/100 8 x 11.5mm
6.3/220 10 x 12.5mm
6.3/330 10 x 16mm
6.3/470 10 x 20mm
6.3/1000 12.5 x 20mm
