VPI NOMAD har både riaa, pick-up og hodetelefonforsterker LYRIC HI-FI
Denne er ALT du trenger for å spille av og lytte til dine LP skiver ,
enten med hodetelefon eller koples rett til forsterkerens linjeinngang.
Tonearm:
  • New 9” vertical Yoke type tonearm with lateral turntable type bearing.​
  • Pivot to spindle: 223mm​
  • Effective length: 240.7mm​
  • Overhang: 17.7mm​
  • Offset angle: 22.85 degrees​
  • Average RMS distortion: .36%​
  • VTA adjustable arm mount.​
  • Damped stainless steel armtube.​
  • Very pure copper wire, twisted with special insulating jacket.​
  • The armbase is upgradeable to a standard JMW 9 arm.​
Additional Specifications
Type​
Belt drive (manual turntable)​
Motor​
24v synchronous AC motor​
Turntable Platter​
Machined MDF​
Diameter​
11.81” (30.0 cm)​
Turntable Speeds​
33.3 RPM and 45 RPM​
Wow and Flutter​
0.06% WOW (in accordance with DIN specification)
0.04% Flutter in accordance with DIN specification)​
Rumble​
< - 80dB (IEC 98A unweighted)​
Cartridge​
Ortofon 2M Red​
Output​
5 mV @ 1 KHz​
Tracking Force​
1.5 grams (recommended)​
Input Load​
47K​
Weight​
5.5 grams​
Power Supply​
24 VAC @ 50 – 60 Hz​
Power Consumption​
7.7 watts at full output​
Safety Approvals​
Built to meet UL6500 and EN 60065​
Dimensions​
18.5” (470 mm) W x 13.5” (343 mm) D x 4.3” (109 mm)H​
Weight​
12.9 lbs. (5.9 kg)​
Nomad Reviews
Nomad Press
Pris VPI NOMAD ikke fastsatt ennå i påvente av hvor USD " tar veien" Kontakt oss !
Lyric HiFi , Torggata 28 , 0183 Oslo
Tlf 22411984 mellom kl 12.00-17.00
Velkommen
Tor Aamodt Haug
Auditor
Se der! Kan være spennende ,den. Er pris fastsatt ennå?
LYRIC HIFI
LYRIC HIFI sine annonser
SOLIDSTEEL eksklusiv import og salg tilbake hos LYRIC HIFI , Torggata 28 Oslo
  • 1
Since their introduction in 1991, Solidsteel audio tables have established a new level of technical and aesthetic refinement for audio and video component support and isolation...
Nye STAX SRS-5100 = SR-L500 elektrostat hodetelefon & SRM-353X driver ankommet
  • 5
STAX SR-L500 elektrostat hodetelefonen og SRM-353X transistor driver/forsterkeren bringer musikk til ørene med detaljer og kvalitet som er fantastisk med stor opplever en fyldig og dyp...
Helt ny modell ProAc DB-1 ankommet. Kom, lytt og glem hverdagen ! LYRIC HIFI
  • 15
Stewart Tyler's magi igjen på sitt beste. Ord blir overflødig, må oppleves ! Herlighetene kan erverves for kr 24 950 pr par for Standard finish og kr 27 560 pr par for Premium finish. For...
WhestAudio THREE Signature riaa - NY ALVORLIG "TRUSSEL" hos LYRIC HIFI Torggt 28
  • 4
WhestAudio THREE Signature riaa - NY ALVORLIG "TRUSSEL" hos LYRIC HIFI Torggt 28 For MC pick-up’er med høy oppløsning Som alle Whest Audio' s design har whestTHREE Signatureblitt laget for...
Vi inviterer til demokveld med FOCAL La SCALA mk 1 tirsdag 2. fra 16.00-20.00
  • 2
Seansen vil foregå i våre lokaler i Malmskriverveien 11 eller Torggata 28 Vi informerer nærmere om hvor dette vil skje avhengig av hvor mange melder ifra at de vil komme. Mail påmelding om du vil...
Vi inviterer også til demokveld med ProAc D-48R torsdag 28. januar fra 16.00-20.00
  • 8
Seansen vil foregå i våre lokaler i Torggata 28 med enkel servering og den største musikalske opplevelse ! ProAc har i alle år fått kun glimrende skussmål av musikkglade brukere som ikke så...
