Hifi Stasjonen
- Ble medlem
- 02.05.2007
- Innlegg
- 293
- Antall liker
- 59
VTL TL 5.5 Series 2 er en helt ny forforsterker basert på TL 6.5.
VTL TL 5.5 Series 2 er en fullbalansert forforsterker med rør.
Man har mulighet til å bestille forforsterkeren med riaa trinn for MM/MC eller ettermontere dette.
RIAA trinnet er også rørbasert.
VTL TL 5.5 Series 2 informasjon etter siste oppdatering :
Line Stage:
All-tube, with lower gain hi current 12AU7 circuit and 12AT7 buffer, minimal negative feedback
2 balanced /single-ended inputs, 5 single-ended inputs, 1 tape in, 1 bal / Single-ended out, 1 buffered record out
Soft-touch relay input select
128-step chip-based differential volume control, with 3-digit display
Higher resolution via single higher-resolution attenuator, and software control for balance and offset
Switchable gain between normal and low gain
Mono control on front panel
All TL-6.5 functionality, with fully bi-directional RS-232 control: First two inputs balanced or single ended, programmable input offset, any input programmable as pass-through, and input disable, tape monitor and Mono control on front panel
2 programmable trigger outputs
Metal remote
TP-6.5 chassis size with all precision machined aluminum cosmetic
Phono stage(kan ettermonteres):
JFET/parallel 12AU7 design from TP-6.5: 68dB gain balanced (23dB MC, 45dB MM)
Split-pole Passive RIAA with paralleled 12AX7 and 12AT7 gain stage
MM / MC select via jumper
MC Gain settings via jumper: 3 steps of 6dB: 68dB, 62dB, 56dB.
Loading: MM 47k, MC: 100 ohms, 500 ohms, 1k, 4.7k, UDF, 47k (parallel for more values) via jumpers
Enhanced RIAA (selectable via jumper)
Rumble filter setting via front panel
Selectable bal/ S/E output via jumper
Dual-use buttons on front panel for phono-only functions
MC and MM gain trims
Transformer option for MC stepup
VTL TL 5.5 Series 2 gir mulighet for en eksepsjonelt god forforsterker og riaa i en pakke til uslåelig pris!
For mer info :
WEB : www.hifistasjonen.no
Email : mail@hifistasjonen.no
Telefon : 62416121
Mobil : 40850814
Hifi Stasjonen
Line Stage:
Metal remote
For mer info :
Telefon : 62416121
Mobil : 40850814
Hifi Stasjonen
