Vi selger en eldre optisk (TOSLINK) kabel fra Tara Labs.
Kan sendes for kjøpers regning i boblekonvolutt og uten oppkrav for å holde fraktkostnader på et minimum.
NB! Dette salget er privat da gjenstanden ikke tilhører vårt firma.
The 201d fiber optic cable is polished in 3 stages to give you the clearest optic cable. Since the cable transmits light, it needs to be free of cracks or dents in the cable. When it is polished and smooth, the cable can transmit the light directly without obstacles. This will ensure that your optic signal uninhibited during transmission.
Fiber optic cables are immune to electrical interference; therefore you get a clear signal every time. Typical copper cables are subject to radio interference and even electrical interference that can cause blurred sounds or background noise. This makes fiber optic cables the best option fro true high definition digital audio.
The 201d is manufactured with chemically stabilized polymer cladding material. The outer jacket is made with SVPE material. SVPE is a special insulator made to reduce resistance and to improve strength. This will protect your cable and ensure that your cable will last and provide true clear signals every time.
Don't settle for less than the best for your digital audio needs. These fiber optic cables are produced to provide the best signal from end to end.
