Rørforsterker selges med et ekstra sett små rør. Psvane 12ax7,Telefunken ECC85
Ca 300 timer brukstid,en liten skramme rund et skruehull,sjekk bilder.
Specifications:
Power Output: Class A MAX 25W per channel
Power Input: MAX 150W
Frequency Response: 20Hz-40kHz (+/-0.5dB 1W)
Output Power Distortion: 0.05% (4W 1kHz)
Input Sensitivity: 220mV
Input Impedance: 100k ohms
Inputs: Line 1, Line 2, Line 3, AUX, USB DAC
USB DAC Spec.: 32Bit 384kHz
Speaker Output Impedance: 4ohms or 8ohms
Headphone Output Impedance: 32-600ohms
Overall Negative Feedback: -39dB
Overall S/N Ratio: 85dB
Power Consumption: Max. 220W
Damping Factor: 6 (Distortion: 0.1%)
Voltage Range: 100-120V, 220-240V
Operation Method: Single End Class A
Remote Control: RF Remote for Volume Control
Power Tubes Required: Matched pair KT-150
Preamp & Driver Tubes Required: 12AX7 x2 (ECC83x2), ECC85 (6N1) x2
Tube Bias: Manual adjustable with bias monitor meter
Dimensions: 380x295x160mm / 14.96?x11.61?x6.3? (WxHxD)
Weight: 18kg/39.7lbs
Specifications:
