Moiz Audio
Butikk Grandinote Shinai -50% Solgt
Integrert forsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Pris
Kr 57.000
Annonse beskrivelse
Annonse nummer: 227566
Vi tar inn Supremo, Shinai Demomodell selges!
Referanseprodukt blant mange hifi journalister. Shinai er en fullbalansert ( 4 forsterkere totalt ), klasse A integrert forsterker med
utgangstransformator. Kretsen er lineær uten tilbakekobling (Single ended mosfet) . Ampen leverer 37 Watt ( 45 watt før klipping) og driver alt høyttalere.
Høy dempingsfaktor sikrer full kontroll! Låter som en røramp (uten begrensningene)
Produktet er tilgjengelig for demo.
Tubes or Semiconductors? Magnetosolid®.
The name of this technology borns from the combination of ?ferromagnetic? with ?solid state?.
Solid-state components are used in typical circuits for tube amplifiers..
We managed to combine the advantages of solid state and tube amplifiers, overcoming their respective limitations.
The result is a tight, precise and dynamic sound, yet gentle, airy, warm and pleasant: natural.
All polarisations are in Class A and without feedback.
All low signal stages are direct coupled: without capacitors.
For every device, we use a dedicated independent power supply circuit.
Each component is carefully selected.
When you listen Grandinote, you forget to listen tubes, you forget to listen solid-state, you listen only music.
A refinement of Magnetosolid® technology is represented by the use of precious ferromagnetic components capable of bringing the listener the entire slightest nuances of the musical message, combined with a disarming naturalness
This new technology has created a new line called Magnetosolid-VHP; the excellence we believe in sound reproduction.
The exclusive products of Grandinote, masterpieces of style and technology, make them also a preference for the most demanding audiophiles:
?it is almost impossible to take off, this amplifier connects you simply and purely to music. This feeling of addiction is quite rare and we?ll see why??
Lionel Schmitt ? 03/2014
?The best of solid state.?
Ruud Jonker ? 06/2013
?a word occurred often to me: energy. This sensation of energy never fades away and gives to the whole reproduction a dynamic sensation, violent at times where the partition requires??
Domenico Pizzamiglio ? 04/2013
?We did not hear never the fineness of the notes?
?The harmonic density and dynamic distribution allow for each partition, each note, each sound to be interpreted in a credible manner??
Dominique Mafrand ? 12/2012
?A disarming naturalness: great! Who you were never present the opportunity to listen to the SHINAI, perhaps at a trade show, you should definitely do it.?
Wilfried Lardenoit ? 07/2012
?An amplifier with absolute quality level, able to offer the best quality that you can expect from tube technology and from solid state.?
Alfredo Di Pietro ? 12/2010
?It?s like listen a sound by McIntosh MC230 or a pair of MC30, which had stolen the muscles, from a not so small Krell.?
Bebo Moroni ? 12/2007
?I could not reasonably think that a tube integrated had the same authority of a transistor, or that one transistor had the same feeling of a tube. Then I listened the Grandinote A Solo??
Andio Morotti ? 10/2006
?Refinement like small power tube amplifire?
Andrea Della Sala ? 02/2006
?We seem to listen a modern tube amp, one of those properly designed, with tight bass, without difficulty in driving strong speakers. Has instead, all the advantages of a solid state??
Vittorio Vitti ? 09/2005
??the result of a careful search for more natural, grace, sweetness typical of valuable tube productions, combined with the tight, precision and dynamics of the solid state of exception.?
Andrea Della Sala ? 09/2005
?Why have I been so impressed by the sound of these amplifier? It ?s simple, because they sound great tube amp, without suffering the limits?
Bruno Fazzini ? 01/2004
Originalemballasje
Nei
Orig. kvittering
Ja
Forsendelse
Kan sendes
Moiz Audio
Torget karakterer
Vurderinger (126)
Andre annonser av Moiz Audio
