K
iBasso D12 Anaconda Solgt
Denne annonsen er utgått.
Hodetelefoner
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Nordland
Pris
Kr 1.000
Kjøpt av
davit
Annonse beskrivelse
Annonse nummer: 43094
iBasso D12 dac/headamp selges for 1000 med frakt. Signal-, usb- og optisk kabel følger med, samme gjør standard opamp-kit (se bilde). Enheten er 1,5 år gammel, og jeg er andre eier. Send PM ved interesse.
Produkt-info: ibasso, head-fi.org
iBasso D12 Anaconda
High performance Stereo DAC and Headphone Amp
Introduction:
iBasso D12 Anaconda is the successor of the D10. The size of the D12 is almost same as the D10. They share the same functions. The main advantages of the D12 are the dual WM8740 DAC section, and the new amplification section that allow single OPAMPs. The D12 is a Self powered DAC and Hi-Definition headphone amplifier with many input options, which includes digital inputs from optical, coaxial, USB, and analog input from AUX IN/OUT. It not only works as DAC/AMP combo, but also works as a stand-alone AMP, DAC, or USB soundcard. Also, the D12 has a new pulverization finish and split case, which is convenient for OPAMP rolling.
Main Features:
- PCM2906B, converts USB into a S/PDIF signal
- CS8416, DA-receiver chip
- Dual WM8740s, D/A chip
- OP+BUF structure for amplification.
- 2-Setting Gain Switch for impedance matching (+3/10dB)
- Dedicated MCU (Micro Controller Unit) to manager inputs, outputs, and functions.
- Flexible input and output compatibility. It has USB, optical, coaxial, stereo inputs, line out, and stereo output
- Works as a combo or a stand-alone AMP, DAC, USB soundcard
- Built-in rechargeable Li-polymer battery plays up to 30 hours (30 hrs for AMP, or 18hrs for combo)
- Measures 55*24*103mm, and weights 160g
- Comes with power adapter, leather pouch, optical cable, USB cable, 3.5 to 3.5 interconnect, rubber feet, OPAMP rolling kit, and warranty card.
ketilb
Torget karakterer
Vurderinger (13)
