Et par 5 år gamle JBL 4365 i strøken tilstand.
Denne høyttaler bruker samme HF driver som den mye dyrere JBL K2 S9900.
HIGHLIGHTS
1501FE Low-Frequency Driver
A 380mm (15-inch), three-layer woofer cone with a 100mm (4-inch) voice coil, damped accordion
surround and Vented Gap Cooling? heat-dissipation technology generate high-impact bass that is
extremely faithful to the original input signal.
476Mg High-Frequency Compression Driver
A 100mm (4-inch) magnesium-alloy dome diaphragm with an aluminum voice coil delivers
extremely accurate high-frequency performance with minimal distortion and power compression
for explosively realistic dynamics at all listening levels.
045Ti-1 Ultrahigh-Frequency Compression Driver
A lightweight, 25mm (1-inch) titanium diaphragm produces realistic dynamics far beyond the
range of human hearing, with ultrasmooth response that is ideal for SACD? (Super Audio CD) and
other high-resolution audio formats.
SonoGlass® HF and UHF Horns
Dense, mechanically inert high- and ultrahigh-frequency horns with extremely precise Bi-Radial®
horn flares eliminate horn resonances for clear, distortion-free sound. A large HF horn creates a
huge, realistic 3-D soundstage.
Key Features
? Extremely rigid, heavily braced enclosures of 25mm (1-inch) MDF
? Dual front-mounted ports for optimal bass response
? Charge-Coupled Linear Definition? crossover system for improved dynamics at low
listening levels
? HF and UHF switch attenuators let you tailor high-end output to suit room acoustics or
personal preference
? Bi-wire capability for use with multiple amplifiers
HIGHLIGHTS
Key Features
listening levels
personal preference
