Grunnet oppussing og andre prioriteringer selges et par Klipsch Palladium P39 i Natural finish.
Strøkent par.
Produsert i 2010 og var nye i emballasjen da jeg tok dem i bruk for ca 2 år siden.
Har original emballasje.
SPECIFICATIONS: FREQUENCY RESPONSE 39Hz-24kHz +/-3dB
LOW FREQUENCY EXTENSION 28Hz
HIGH FREQUENCY EXTENSION 30kHz
POWER HANDLING 400W continuous / 1600W peak
RECOMMENDED AMPLIFIER POWER 50 - 1000W
SENSITIVITY 99dB @ 2.83V / 1m
NOMINAL IMPEDANCE 4 ohms
MID-FREQUENCY CROSSOVER 500Hz
HIGH FREQUENCY CROSSOVER 3200Hz
MAXIMUM ACOUSTIC OUTPUT 126dB (2 speakers in-room)
HIGH FREQUENCY DRIVER 0.75" (1.9cm) titanium diaphragm compression driver mated to 90° x 60° Tractrix® Horn MID-FREQUENCY DRIVER 4.5" (11.4cm) aluminum diaphragm compression driver mated to 90° x 60° Tractrix® Horn LOW FREQUENCY DRIVERS Three 9" (22.9cm) high-output, aluminum / Rohacell® / woven synthetic fiber hybrid cone woofers
ENCLOSURE MATERIAL Constrained layer MDF (medium density fiberboard)
ENCLOSURE TYPE Bass-reflex via triple side-firing ports
HEIGHT 56" (142.2cm)
WIDTH 12" (30.5cm) (14.5" / 36.8cm at the base)
DEPTH 24.75" (62.9cm)
WEIGHT 165 lbs (74.9kg)
Strøkent par.
P-39F Floor Standing Speaker | Klipsch
Home Audio Products for Every Lifestyle, Application & Budget. Since 1946, no compromises in Legendary Sound. Free Shipping on All Online Orders in the US.
www.klipsch.com
- Originalemballasje
- Ja
- Forsendelse
- Må hentes
