2x1,5m solgt 3stk igjen.
Har for mye kabler liggende og selger derfor unna noen strømkabler.
Har 5stk i varierende lengde 1,5m, 2m og 3m
Kjøpt hos Moiz Audio for ca 1år siden, pent brukt.
800,- + evntl oppkrav PR STK
[FONT=open_sansregular]The Project ended.[/FONT]
[FONT=open_sansregular]After many test on entry level to really high end equipment we couldn't find a component that cannot be improved by replacing the OEM AC cable with this.[/FONT]
[FONT=open_sansregular]We take advantage of interaction capacity we achieve through the choice of materials and a special implementation technique. The LAB12 KNACK AC Power Cable suppresses the largest percentage of the EMI and supplies (3x6mm² conductors) as much current your wall socket can give.[/FONT]
[FONT=open_sansregular]Three double insulated, tinned pure copper conductors all stranded, with steel shield for live and neutral conductor, inside braided polyester (PET) sleeving. High quality plugs with tight connections and silver/rhodium plated conductors.[/FONT]
Specifications
Specifications
- Rating 220-240Vac 10 Amp continues current, 16 Amp max
- Total conductor thickness 3x6mm²
- Cable resistance : 3,38 m?/m
- Internal Capacitance 700pf
