Pen formfaktor integrert med dac på 56w, vanvittig strømsterk. Driver det meste med bravur, opptil et visst lyttenivå. Organisk og naturlig lyd. Bygget for å vare en evighet.
Står oppkoblet i demo, og kan høres på forskjellige høyttalere. Kom innom for demo! - Tilgjengelig for hjemlån.
https://www.moetaudio.com/produkt/f...coustic-1/integrert-forsterker-element-serien
Integration
The Leema Elements Integrated Amplifier continues Leema’s strong tradition of producing some of the best amplifiers that money can buy. Not only does the Elements Integrated Amplifier include the most comprehensive set of inputs and facilities of any Leema product to date, it manages to fit all this into a compact and beautiful enclosure built to the same exacting standards as the larger Leema amplifiers.
Delivering a very healthy 56 Watts into 8 ohms, more than 100 watts into 4 ohms and around 150 watts into 2 ohms, the Elements Integrated Amplifier will get the best out of any speaker.
The on-board digital to analogue converter is one of the most flexible available. One 24 bit/192 kHz SPDIF co-axial, three 24 bit/192kHz SPDIF optical inputs and a 24 bit/192 kHz asynchronous USB input make the Elements Integrated Amplifier the perfect onebox solution, allowing all digital sources to perform with astonishing results.
Full LIPS® implementation allows for easy system integration with other Leema products and home automation systems. The Elements Integrated Amplifier also features an onboard headphone amplifier, mute button and infra-red remote control.
Acclaim
"The sound is astonishingly deep and lush, while retaining a crisp responsiveness right across the spectrum"
Andy Stout, Redshark
In their exclusive 'Beautiful Systems' feature, partnering the Elements Amp, CD Player and Xero speakers, HiFi Choice conclude:
"This is what 21st century audio should be. We live busy, crowded and complex lives and the limited time we have for something as decadent as sitting down and listening to music needs kit that can deliver the goods with everything we throw at it.
This is one company’s complete vision of how that should be achieved and my word, it’s a very beautiful system indeed."
You can download the full article here.
Specification / Features
(See User Manual for full specification)
Output Power: 56W rms 8 Ohms/Ch
Output Power: 110W rms 4 Ohms/Ch
Output Power: 160W rms 2 Ohms/Ch
THD: 0.015%
Noise: < -105 dB
Freqency Response: 5 Hz - 80 kHz (+0/-3 dB)
Number of Balanced Inputs (XLR): 1
Number of Un-Balanced Inputs (RCA): 3
MP3 Inputs: 1 (Front Panel 3.5mm jack)
Digital Inputs
Coax S/PDIF: 1
Optical S/PDIF: 3
USB: 1
Headphone Outputs: 1
Pre-out Outputs: 1
Mute Buton: Yes
Thermal Protection: Yes
LIPS® system: Master or Slave
Dimensions: 220*340*88mm
Carton: 370*450*210mm
Mass: 11Kg
Integration
Acclaim
THD: 0.015%
Noise: < -105 dB
Digital Inputs
Coax S/PDIF: 1
Optical S/PDIF: 3
USB: 1
Pre-out Outputs: 1
Mute Buton: Yes
Mass: 11Kg
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
