Selges som rep. objekt. Displayet dør ut etter et par sekunder. Kan være bare en bagatell, da det ble skiftet display i 2014. Da ble også laser og belter byttet.
Testet med CD og SACD, spiller fint
Original fjernkontroll følger med.
Info fra Linn :
"From viewing our records, the serial number of your Unidisk 1.1 was originally manufactured in December 2003 and the product was last serviced at Linn in November 2014 where the laser, mechanism belts and the display were replaced."
Selges kr 4000,- eller et fornuftig bud
Og for de teknisk interesserte :
Stereo / multichannel universal disc player.
Formats played: CD, CD-R, CD-RW, SACD, DVD-Audio, DVD-Video, DVD-R, DVD-RW, DVD + RW, VCD, SVCD, data discs with MP3 and MPEG files (Left / right downmix of Dolby Digital and DTS datastreams).
S / PDIF digital outputs: TosLink, BNC. Analog audio outputs: 5.1 RCA socket outputs (front L and R are double connectors), stereo XLR balanced. Control connections: RC5 I / O, RS-232 I / O (RS-232 & Flash Upload).
Onscreen and front-panel text display for SACD. Video outputs, progressive-scan: RGBHV, Y-Pr-Pb (BNC).
Video outputs, interlaced: Y-Pr-Pb (BNC), RGB (SCART), 2 S-video, 2 composite (RCA), with HDCP (DVI) to be activated.
Aspect ratios: 4: 3 pan & scan, 4: 3 letterbox, 16: 9.
Power: switching power supply with auto-ranging (90-240V AC, 50-60Hz).
Dimensions: 381mm W by 80mm H by 368mm D.
Weight: 4.9kg.
Info fra Linn :
Weight: 4.9kg.
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Avtales nærmere
