Endpoint Audio
Butikk Lockwood MINI
Stativhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Vestfold
Pris
Kr 139.500
Annonse beskrivelse
Annonse nummer: 248942
Lockwood har vært en Englands mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så, ønsker du å høre musikken slik artisten gjorde så er dette høyttaleren for deg!
Lettdrevent, dynamisk - pointsource! Bedre blir det ikke. Nytt for Lockwood er satsingen mot privatmarkedet, og første batch er beregnet ankomst sent mai!
Pete Townshend fra The Who er stor fan og en av Lockwoods faste kunder. Par nr. 1 av den nyeste serien er reservert nettopp Pete Townshend.
Over the years, Pete Townshend has acquired numerous pairs of Lockwood speakers for his home studios and various commercial studios, including Ramport and Eel Pie Studios. Andrew Timms, our 2nd generation CEO, fondly recalls personally delivering Lockwood’s to Pete’s home and studios.
Notably, The Who recorded 10 albums using Lockwood speakers!
Lockwood Mini
Bookshelf Loudspeaker with 10” Dual Concentric Driver
The Lockwood Mini, a compact marvel of audiophile engineering, brings exceptional sound quality to your space. This stylish, 2-way stand-mount loudspeaker has received critical acclaim for its accurate and musical performance. Despite its small size, the Lockwood Mini delivers an immersive audiophile experience that will exceed your expectations. Don’t let its compact design fool you – the Lockwood Mini packs a powerful punch in terms of sound quality and musicality.
The Mini provides outstanding musical involvement, originally developed to provide accurate and reliable monitoring in smaller locations, with reach-out and touch imaging that is faithful to the original recordings. The Mini delivers outstanding dynamics and is famously used by the BBC, ITV and Neve Electronics
Dual concentric point source drive units have set the standard for natural sound and pinpoint acoustic accuracy for over half a decade. The Lockwood Mini deploys a 10-inch dual driver that is capable of impressive dynamics, sublime midrange, and a beautifully natural high-frequency presentation.
Hand-built with premium components, the crossover design of the Lockwood Mini remains true to its original concept, delivering an exceptionally clean signal path.
Unleash the Power of Audiophile Sound with the Lockwood Mini Compact Loudspeaker. For audiophiles who appreciate both style and sound quality, the Lockwood Mini is a perfect choice. This compact loudspeaker delivers exceptional sound performance, despite its small size. With its accurate and musical sound, the Lockwood Mini brings a truly immersive audio experience to your space.
Technical Specs
Dimensions
Width: 398mm | Depth: 314mm | Height: 570mm
Loudspeaker Drive Unit
10 Inch (295mm) Lockwood Green HPD/SL
Cabinet / Design
Bookshelf Infinite Baffle 18mm Birchwood
Frequency Range
40-20,000 Hz
Crossover Network
Lockwood A Series Crossover
Input Connectors
Tom Evans Audio Design Pure Copper Binding Posts
Power Rating
50 Watts (Integrated Material)
Impedance
8 Ohms
Weight (Approx)
18.5kg
Decorative Finish
Unique Walnut Veneer
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Avtales nærmere
Endpoint Audio
Torget karakterer
Vurderinger (37)
Andre annonser av Endpoint Audio
