Nypris: 24995!
Brooklyn AMP er en referanseffektforsterker med Myteks signaturlyd - musikalsk, detaljert og gjennomsiktig. Den låter ikke som en typisk Klasse-D forsterker; Målet har vært å konstruere en forsterker som låter som en Klasse A rørforsterker kombinert med krefter nok til å drive hvilken som helst høyttaler. Ifølge eiere av brooklyn, låter produktet som en røramp! Kan brokobles til 600 watt og bi-amp modus er tilgjengelig ! Enheten har sort finish.
Brooklyn AMP is another brand new, amazing sounding product from Mytek, launched at 2017 Munich HiFi Show. Mytek golden ear expertise was used to design world?s most likely best sounding Class D amplifier. Mytek engineers with the lead designer, Michal Jurewicz, have demonstrated that a carefully executed Class D can sounds like triode, with beautiful midrange and depth while maintaining deep bass and fast transient and detail. Mytek extensive expertise with DSD, technology similar to digital amplifiers was used in this project. This architecture allows for packing a lot of power (300W/ch) into small 1/2 rack chassis, small and light enough to be carried around in a briefcase.
SPECIFICATIONS : POWER RATINGS AT 1% THD: at 16 Ohm - dual mono 2 x 130 W at 8 Ohm - dual mono 2 x 250 W at 4 Ohm - dual mono 2 x 300 W at 2 Ohm - dual mono 2 x 400 W Peak - dual mono 2 x 1200 W OUTPUT SWING: 70 Vp / 140 Vpp (unloaded) SNR: >121 dB FREQUENCY RESPONSE -3dB: 10Hz - 30kHz THD REGULAR USE: <0.01% PROTECTION CIRCUITRY: Short circuit protection, DC protection, under voltage protection, temperature protection, overload protection DAMPING FACTOR: >400 DC POWER ON TRIGGER: 12VDC minijack WORLDWIDE POWER SUPPLY: 100-240VAC 50/60 Hz DIMENSIONS: WxDxH=8.5x9.5x1.74? =216x241x44mm WEIGHT: 6lbs, 3kg WARRANTY: 2 years
