Nyrpris for spiller og heavy kit er 29990 kr. Restylet EMT HSD 006 pick up kan medfølge for en rimelig pris. Arm kan bestilles.
NAS Ace Spacedeck med heavykit returvare 40% avslag | Moet Audio Hi-Fi Simplicity - Hifi - Stereo - Kudos - Davis Acoustics - Leema Acoustics - Revival Audio - Marantz
ACE SPACEDECK:
Looks exactly like the Spacedeck but has a few hidden extra features. The bronze bearing has the carbide/bushed type internal workings, the motor housing and armbase are manufactured from a heavy dense steel. All these features add greater stability to the turntable. Upgrade and colour options are the same as for the Spacedeck.
This is one of our most popular turntables. The 37mm platter is mounted onto its own chassis and runs on our classic bronze bearing. The motor/pulley assembly is mounted in its own housing which sits separately from the turntable chassis, the only connection is the drive belt, this helps to avoid audio resonances being transferred through the chassis of the turntable. Upgrade options available are: Second arm mount for left side, HD (heavy duty) upgrade kit comprising of the 25mm graphite ‘mat’. High gloss black finish (colour options at extra cost).
ACE SPACEDECK:
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
